Steering column fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TOYOTA 09, Apr 19, 2010.
  1. Jun 7, 2010 at 10:41 AM
    #41
    dalsmthme
    dalsmthme Well-Known Member
    Ithaca, NY
    '09 Double Cab 4X4 SR5
  2. Jun 7, 2010 at 12:58 PM
    #42
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    I did this mod but than removed it because it seemed to be worse. It wasn't the same sound though. It was more of a knock rather than a fast rattle.
  3. Jun 8, 2010 at 5:26 AM
    #43
    TOYOTA 09
    TOYOTA 09 [OP] Kicking Ass Since 1981
    Maine
    2009 SR5 MT 4x4 Access Cab
    Preview 2009 SR5 4x4 MT Black Sand Pearl (Access Cab) SUSPENSION ToyTec 5100 Billstein Coil Overs (3" Lift) Fox 2.0 Remote Res Rear Shocks Total Chaos UCAs Full Dakar Leaf Pack w/Extra AAL TIRES & WHEELS BFG AT KOs 265/75/16 load range E American Rancing AR-23 Wheels Borla CAT back exhaust AFE cold air intake w/custom TRD clear cover Satoshi grill w/Grill Craft insert Hella 500 behind grill lights Rigid Industries Backup lights Interior Custom LEDs and Bed Lights Backup Cam Anytime MOD Leather armrest and rear seat MOD Weathertech floor liners Custom rear gear/dog platform Cobra CB and Garmin GPS Bed Mat UWS low pro tool box with Custom LED lights Diff breather MOD Custom painted engine cover Wet Okole seat covers
    trying to debate if i should go get the tsb done. the zip tie fix worked fine for me and i have NO noise...
  4. Jun 8, 2010 at 6:51 AM
    #44
    dalsmthme
    Ithaca, NY
    I am in the same boat. I am happy with my fix, but at the same time it would be nice to have a properly engineered part....
  5. Jun 8, 2010 at 7:31 AM
    #45
    Ocean's
    Ocean's Well-Known Member
    Thanks for taking the initial flames for what turned out to be a great fix for all of us :D
  6. Jun 8, 2010 at 8:41 AM
    #46
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Nice Avatar! :D
  7. Jun 8, 2010 at 1:41 PM
    #47
    RevHard6
    RevHard6 Well-Known Member
    Nathan
    Sacramento
    11 DC OR 4x4
    I think this is one TSB i'll jump on. This was the first negative thing I noticed about the truck right after I bought it and the first time it was off the pavement.
  8. Aug 26, 2010 at 12:36 PM
    #48
    danmckennat
    danmckennat Well-Known Member
    chardon, ohio
    2009 tacoma access cab offroad package
    just had the tsb done on my truck and four brand new rims, steering is def alot more toucher, but now when i get up to around 65mph the steering wheel shakes like a mother, guessing they didnt balance tires good enough
  9. Aug 14, 2011 at 1:08 PM
    #49
    06TXED
    06TXED Well-Known Member
    Tony
    Aurora CO
    2023 DCSB MGM TRD OR 4x4
    I tryed to get my zip tie through the gap and it will not go into the gap. Any tips or other methods? ahhhhh just want to get this damn steering column fixed!!!!
  10. Aug 14, 2011 at 9:00 PM
    #50
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    Push the lower portion of the column away from you while you try to fit the zip tie into the portion of the gap closer to you. This will create the space needed. Also carefull, the green grommet goes out of its place easily and is F***ING hard to get back there.
  11. Aug 15, 2011 at 6:29 AM
    #51
    06TXED
    Tony
    Aurora CO
    ^^^^^^thanks I will give that a try
  12. Sep 19, 2011 at 6:02 AM
    #52
    SoCo
    SoCo Hateful Respect
    Colorado
    3rd gen T4R 5spd.
    There's not enough bandwidth for what's happening.
    This thread was a great find. I let go of my 95 Tacoma and picked up a 2005 TRD Off Road. The loose clunk in the steering when over bumps / dirt road was driving me crazy.
    After getting "We don't see / feel anything wrong" from a couple of places, I discovered this forum. I found the TSB for it along with this thread and zip tie fix.
    Put in the zip tie yesterday ... Like having different truck!
    Learning a lot here ... Thanks!
  13. Oct 27, 2011 at 9:03 AM
    #53
    GTABurnout
    GTABurnout Well-Known Member
    Tucson AZ
    2012 Tundra Crewmax Rock Warrior TRD SC
    Icons, TRD Supercharger, TRD Exhaust, TRD Intake
    My 07 with 28K on it has this knock problem. I thought it was something with how the last owner drove it. I am bummed my truck is out of warrenty so no TSB. I guess I will try this simple fix untill I can afford a new steering shaft.
    Thanks
  14. Nov 9, 2011 at 1:21 PM
    #54
    runyun
    runyun Well-Known Member
    Irving/N. Grand Prairie
    02 Silver TRD DC
    Same.
    I put a zip tie in (and looped it) and the rattle became 4x more worse. Need to go remove it.
    Is there a certain area we should squeeze it into? Or anywhere works?
  15. Nov 26, 2011 at 8:04 PM
    #55
    xxaarraa
    xxaarraa Well-Known Member
    Well, I got the TSB done after 6 trips (yes, SIX) to the dealer. Needed 3 trips to get them to acknowledge the problem and order parts. Then they tore my steering rack boot and needed another trip to get that in. Then they lost two (yes TWO) of my wheel center caps and needed another trip.
    Long story short, I still have the problem after the TSB. I wish I had just found this zip tie solution before losing two years of my life expectancy. Will be trying it tomorrow.
  16. Nov 27, 2011 at 8:18 AM
    #56
    xxaarraa
    OK guys,
    I tried to do the zip tie fix this morning and here's an update: Since I got the TSB done, they seem to have already tried to take the slack out by replacing the intermediate shaft. Obviously that didn't solve the problem since I still have the clunk/rattle. Bottom line: there wasn't enough room to wedge a zip tie in there. I then tried collar stays. No go. Then tried a piece of steel wire, no go.
    Finally, I went to my sewing kit and got the thread separator and hammered it in there.
    I haven't driven off road yet to test it, but hoping it solves my most irritating problem with this Tacoma. Also, I guess my mom was right when she said that every man should have a sewing kit.
  17. Nov 27, 2011 at 8:53 AM
    #57
    GTABurnout
    Tucson AZ
    Zip tie fix is working good for me. Did about 40 miles of off road driving last weekend with no issues.
  18. Dec 5, 2011 at 4:47 AM
    #58
    xxaarraa
    Guys, I took it to the dealer, they re-did the entire steering rack TSB but still no dice. Still have the clunk. I am in the unfortunate situation where a TSB is keeping me from applying a home-made zip-tie fix to solve the problem.
    Anyone got any ideas?
  19. Jan 6, 2012 at 8:28 PM
    #59
    jed1894
    jed1894 Active Member
    2011 Tacoma 4x4
    Can someone please tell me why I cannot open the photographs in the orginal post? I can see "photobucket" but nothing will open. Looking for photographs on how to do this if anyone can re-post. Thanks, Jed
  20. Jan 9, 2012 at 5:19 PM
    #60
    kram
    kram Well-Known Member
    Squamish, British Columbia
    09 TRD Offroad Access Cab 6spd MGM
    URD Short Shifter TSB Leaf Pack, Bilstein 5100s front (1.75") and rear. 285/70/17 Duratrac on Rhino Sidewinders. Weathertech Digifit Floormats
    I'm in a similar boat. Had the TSB done and it's worse. Can't apply the zip tie method now either, so I tried the hammering in the metal thing from the sewing kit that was suggested on the previous page, but that had zero effect so I removed it.
    I can recreate the clunk at the wheel by simply pulling up and down on the steering column where the universal joint is. The shaft that is bolted to it doesn't move independantly of the universal joint, but it moves up and down inside the part that it enters closer to the steering wheel. It sounds like wherever the end of that shaft terminates, it's knocking against something which is making the noise and also sending a vibration to the wheel.
    Either the shaft is not supposed to move at all, or it is supposed to move and the hidden end of it is supposed to have more room to avoid knocking or have a bumper to hit against. It seems to me that the shaft is intended to move, as the uv joint sits on a rubber disc that flexes easily.
    Does anyone know what is going on at the hidden end of this shaft? Is there somewhere that we can see an exploded view, or better yet a photo of the guts? I wonder how hard it is to get in there to have look?
