Still in limp mode after 6 months
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GrampsTacoma23, Nov 1, 2022.
  1. Nov 4, 2022 at 3:29 AM
    #101
    GrampsTacoma23
    GrampsTacoma23 [OP] Just hit 100k Club
    Jeff
    N GA
    2010 Silver Tacoma Base 2.7
    DJM Lowering kit, All LED lights on entire truck and inside, wheels
    I mean havent with a test light again but idk what else would be wrong everything has power and ground im getting-40 air intake temp and my airpump wont cuton and im getting the code say secondary air injection driver
  2. Nov 4, 2022 at 4:49 AM
    #102
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    A meter doesn't load the circuit thats why I asked, a test light will tell you if the circuits can carry a load or not a meter will not.
    Same thing with the ground, you can use a test light connected to battery positive to check the ground.
    See the videos below for 2 examples of a meter showing proper voltage but it won't even carry enough current to light a test light.
    https://youtu.be/LGts5gWsLOc
    https://youtu.be/xazvmJ8_p5Q
  3. May 19, 2023 at 9:39 PM
    #103
    GrampsTacoma23
    Jeff
    N GA
    Alright so im back with this and wanting to retrace my steps to ensure ive missed nothing. Ive followed all the wiring from the front to back and have no issues with grounds loose or dirty connections. I moved to testing power and continuity at all points where needed for the codes im getting and it all looks good. I started fidgeting with the plugs for the sais module from dewitt industries or whatever it is and i noticed if i unplug the one thats behind the map sensor and plug it back in while the truck is running it shuts off but its still in limp mode. Ive checked all of my fuses including ones not correlated bc why not i was there and everything was good there. I notice when i hooked it up to my buddies scanner my maf reads nothing and my AIT reads -40 still confuses me as to why its in limp mode if everything is good or well atleast appears to be. Is it possible a sensor like cam or crank something like that would cause limp mode and to give me these readings?
  4. May 19, 2023 at 9:57 PM
    #104
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Have you done any checking with a test light yet?
    A cam or crank sensor problem isn't gona cause the MAF and IAT sensors to not read properly.
    The truck is always going to be in limp mode with no MAF signal.
  5. May 19, 2023 at 10:00 PM
    #105
    GrampsTacoma23
    Jeff
    N GA
    No i havent i need to buy one to test again and yeah i imagined it wasnt just wanted to throw it put there just incase it was that dumb lol
  6. May 19, 2023 at 10:18 PM
    #106
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Doesn't hurt to ask.
    We know what the MAF Sensor needs to operate so we need to check things there for starters.
    Pin 1 (Blue/White): Battery voltage with key on
    Pin 2 (Red/White): MAF Sensor Control/Ground from PCM
    Pin 3 (Red/Yellow): MAF Sensor Signal to PCM
    Pin 4 (Red/Blue): IAT Sensor Signal (5v with MAF unplugged)
    Pin 5 (Brown): MAF/IAT Sensor Ground
  7. May 19, 2023 at 10:20 PM
    #107
    GrampsTacoma23
    Jeff
    N GA
    Its funny bc i was litterally just looking for those lol, btw if my maf isnt receiving power could i test it by running 12v to the positive part and a good ground wire with it plugged in to see? Sounds rigged and i wouldnt actually drive ut like that but id just be curious if it didnt have power
  8. May 19, 2023 at 10:23 PM
    #108
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I guess you could, just be 100% sure what wire your on because if you jump power to the wrong one you may let the magic smoke out.
  9. May 19, 2023 at 10:48 PM
    #109
    GrampsTacoma23
    Jeff
    N GA
    We have progress, i ran a 12v and ground from battery cut the brown wire and the blue/white wire right before the connector and hooked it up and its out of limp mode so now i know its an issue with either power or ground to the maf sensor, going to unhook the power and recconect back in line with the oe wire if it stays then i know its a simple ground issue or vice versa being a power issue will keep updated
    Dm93 likes this.
  10. May 19, 2023 at 10:51 PM
    #110
    GrampsTacoma23
    Jeff
    N GA
    Ok so berified as a power issue so now the next step is to see why i dont have 12v key on power to my maf
  11. May 19, 2023 at 10:58 PM
    #111
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    We were chasing that earlier in this thread (Pages 3 & 4) but I don't think we ever got to a conclusion of where exactly power was being lost at.
  12. May 19, 2023 at 11:03 PM
    #112
    GrampsTacoma23
    Jeff
    N GA
    Yeah we kinda where just chasing our tails with the fuse box ig also so hapoy its out of limp mode just did a burnout for the first time in a year at 2am , if we cant find out why power is being lost would it be sketchy to run a permanent wire from a keyed 12v source to the connection?
  13. May 19, 2023 at 11:11 PM
    #113
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I guess you could but IIRC much more than the MAF was missing power so I would really reccomend finding and fixing the actual problem.
  14. May 19, 2023 at 11:14 PM
    #114
    GrampsTacoma23
    Jeff
    N GA
    True, domt want it to just become an issue later again, any schematics that show where the wire is routed or any fuses ect that send power to this 12v dource really dont wanna have to unwrap the harness loom
  15. May 20, 2023 at 7:14 AM
    #115
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I think we had pretty much determined it was something under the fuse box at or near the junction box where 2A and 2B are but you never went any further.
