Surround View Cameras (or adding multiple cameras)
Discussion in 'Technical Chat' started by Hojae84, Apr 4, 2017.
  1. Apr 4, 2017 at 11:11 AM
    Hojae84
    Hojae84 [OP] Well-Known Member
    Bedford NY
    2008 dcsb 4x4 sr5
    Curtis home pro, front rear cameras, side blind spot cameras and more
    Recently added front,rear,left and right turn cameras to my 08 dcsb - clip below shows how it works
    https://youtu.be/qNS6Ejr_aC4
    Basically, the left and right cams are activated by turn signals, front cam activated by camera switch, reverse cam activated when shifting into reverse.
    This is all going to my aftermarket Pioneer AVHX5800BHS head unit. This headunit has 2 RCA component in channels, but I only used 1 of them as the video switch module does all the work.
    Please note, I am not a car or electrical expert... I know there are better ways to do the wiring (will explain later) so while I prob won't change anything on mine, if anyone knows better ways/places to tap wires then by all means share.
    also i take no responsibility if you mess it up
    Parts:
    'intelligent' 6 video switch module and harness $250
    http://www.brandmotion.com/360-vision/blind-spot/6-way-video-switcher-9002-6118.html
    installation pdf online has detailed how to install etc
    Both Blind spot cameras and drill bit kit $37
    https://www.amazon.com/gp/product/B01AAARUKM/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
    plus a bunch of component cables and of course lots of wires (i used 18awg) and connectors or taps
    Front & Rear cameras($20-$40 each on Amazon or ebay)
    RCA wires, male/female RCA adapters, and a lot of wire (i used 18awg)
    approx $400 all in w supplies.
  2. Apr 4, 2017 at 11:11 AM
    Hojae84
    Bedford NY
    2008 dcsb 4x4 sr5
    How it works:
    Most headunits and backup cams work and connect via:
    1) RCA component video cable from reverse cam for video feed
    2) Trigger RCA video display 12v wire (usually connected to a reverse 12v wire so reverse cam comes on display when you shift into reverse etc)
    The video switch module essentially connects to your headunit's 1) video display trigger wire and 2) RCA component cable in described above.
    If you already have a reverse camera, you will need to disconnect those 2 wires from the headunit and connect them to the reverse trigger wire and RCA IN on the switch module.
    You then connect the trigger wire and rca cable per camera to the appropriate wire in the provided harness.
    This video switch module has labels on trigger and rca wires for front/rear/left/right/aux/trailer cameras. The module automatically converts left and right turn signal pulses into a steady 12v so you don't get a blinking camera displaying on your headunit. The module also allows you to choose a few settings like [turn off cam after 12 seconds (great for turn signals if waiting at a light), some priority logic (e.g. if turn signal is on and you shift to reverse, reverse cam takes priority etc etc plus a few more]
    RacecarGuy, ChadsPride and medic2230 like this.
  3. Apr 4, 2017 at 11:37 AM
    Hojae84
    Bedford NY
    2008 dcsb 4x4 sr5
    wiring requirements per camera involves 4 wires
    cam power + ground
    cam 12v trigger wire to activate display
    cam RCA video signal cable
    it is a challenge to hide this many wires so try keep things tidy
    if you want to activate a camera via switch as i did for front cam, you'll want to use a relay. My front cam switch is connected to a relay that activates both display trigger wire and camera power
    my left n right cams are ignition on
    rear cam only on when in reverse
    the left/right cams i got on Amazon are great and come with a perfectly sized drill bit. worked great on the taco black plastic side mirror housing.
    the Heated mirror thread on TW has all the info on how to fish wires from side mirror to cabin
    other camera hookups are much less annoying to wire and there are how to wire backup cam threads showing step by steps
    for my 4 cams i tapped:
    - reverse wire
    - left n right turn wire (i tapped at the bulb connection at headlight. have a plow so i already have a mess of wires so don't care. if you want clean then im sure u can tap the turn signal switch
    Thats all for now. should be enough for anyone determined enough to do this. any questions feel free to ask ill try be useful.
    No pics cos i have an infant n busybusy... holding him asleep as i type. he keeps waking up wen i put him down wtf
    bahh
  4. Apr 4, 2017 at 11:43 AM
    Hojae84
    Bedford NY
    2008 dcsb 4x4 sr5
    for simpler setups (eg offroad clearance mount cam low or on frame) where you do NOT want turn signal blind spot cameras, but want switch activated view under front n rear of truck
    try this (i have 1 or 2 of these i can sell cheap never used or connected discount vs Amazon) $25 on amazon + cost of any cameras (cheap 20-40)
    https://www.amazon.com/gp/product/B00B155G5M/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
    much much simpler module switch and cheap.
    Note when buying cameras...
    most come as mirror image w gridlines for reverse cams... some allow u to disable gridlines n mirror imaging. make sure you buy the correct type of camera... for front facing you do not want a mirror image cam etc
  5. Apr 4, 2017 at 11:44 AM
    medic2230
    Murph
    Bama! Roll Tide
    2011 Taco 4x4 DCLB 2019 TRD PRO 4runner
    Nice setup man! I like it!
    ChadsPride likes this.
  6. Apr 4, 2017 at 11:48 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    X2 af
    elnip, yazmatic and medic2230 like this.
  7. Apr 4, 2017 at 11:53 AM
    Hojae84
    Bedford NY
    2008 dcsb 4x4 sr5
  8. Apr 4, 2017 at 12:02 PM
    Hojae84
    Bedford NY
    2008 dcsb 4x4 sr5
    thank you sirs
  9. Apr 4, 2017 at 1:10 PM
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    Awesome setup. Any closer pics on the cams in the mirror?
  10. Apr 4, 2017 at 1:35 PM
    Hojae84
    Bedford NY
    2008 dcsb 4x4 sr5
    RacecarGuy likes this.
  11. Apr 4, 2017 at 6:59 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    Wow that's an awesome idea. :thumbsup:
  12. Apr 10, 2017 at 2:57 PM
    elnip
    elnip Well-Known Member
    LC,NM
    '98 Tacoma TRD S/C'd / '16 T4R Trail w/JFR EL Y-pipe 4.56's
    SC'd, fuel mods, Supra TT MAF, TRD headers, WI, Tundra Brake upgrade
    Been researching this for a while, excellent job!:thumbsup::thumbsup:
  13. Apr 30, 2017 at 6:56 PM
    Pilvr83
    Pilvr83 Well-Known Member
    Panhandle, Florida
    2020 Tacoma Limited, Voodoo Blue
    DiamondBack, Spiker hood struts, tailgate step, MESO items
    Where is the reverse 12v wire located?
    Is it under the dash or did you wire to reverse light?
    Reason I ask: installed a camera but have to manually switch it. Want it to come on when in reverse.
  14. Apr 30, 2017 at 7:52 PM
    Hojae84
    Bedford NY
    2008 dcsb 4x4 sr5
  15. May 1, 2017 at 7:41 AM
    Joelev
    Joelev Well-Known Member
    This is killer and a fair amount cheaper than the solutions I was looking at. I have a similar Pioneer head unit. How does this all integrate when you're using CarPlay or Android Auto? I use that as my GPS a lot.
  16. May 1, 2017 at 8:19 AM
    Hojae84
    Bedford NY
    2008 dcsb 4x4 sr5
    I use Android auto on phone and all audio thru Bluetooth. My phone display does not show up on my pioneer unit.
    If you have a pioneer unit that shows carplay or Android auto on the head unit screen, it should act just as if you triggered the reverse backup cam. As in backup cam trigger overrides anything on screen. So it should show a camera when triggered on screen whether backup or left,right turn cameras etc. It returns back to the previous screen when not activating a camera. So if you have gps on head unit then once done w triggering/displaying a camera it should revert back to your GPS screen.
    ChadsPride and Joelev like this.
  17. May 1, 2017 at 12:10 PM
    Pilvr83
    Panhandle, Florida
    Car play works great...well except for the navigation portion; at least for me. I noticed today when using the navigation the display was backwards. The arrow for me was facing down so everything around me was reversed. Probably my settings but I have not figured how to reverse or point North yet.
    Joelev and ChadsPride like this.
  18. May 1, 2017 at 12:12 PM
    Pilvr83
    Panhandle, Florida
  19. May 8, 2017 at 9:14 PM
    AcerD
    AcerD Well-Known Member
    Austin
    Bend OR
    2013 Tacoma Shortbed
    This is an awesome idea! Subed
  20. May 10, 2017 at 5:02 PM
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    Nicely done! I have a 4 channel Quad that I plan to wire to my Pioneer headunit but I hadn't thought about triggering them. Was going to use the remote that came with the quad to switch between 4 up , 2 up and 1 up displays.
