Suspension Install; anyone want to help/tips?
Discussion in 'Northern California' started by Kwikvette, May 8, 2019.
  1. May 22, 2019 at 5:25 AM
    #41
    jeg0005
    jeg0005 Well-Known Member
    Jon
    BHM, AL
    2001 Tacoma SR5 double cab
    Full OME 883s, SPC UCAs, 33" STT Pros
    Starting mine today. Are extended bump stops necessary. I don't plan on wheeling hard for a little while. I just dont have them right now and want to get this done. I'll order them an add them later if it won't mess anything up
    Area51Runner likes this.
  2. May 22, 2019 at 5:43 AM
    #42
    Bobby18
    Bobby18 Well-Known Member
    Bobby
    2008 Tacoma Prerunner
    DTF +6 LT, Kings 2.5x10 C/O, 2.5x2 Bump, Adv Fiberglass 1 Piece Conversion
    Probably not a requirement as long as youre not bottoming it out. I would just wait another couple of weeks and do it all at once. You dont want to take u-bolts on and off that often.
  3. May 22, 2019 at 5:58 AM
    #43
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Agreed - I would just wait. How long does it take to receive bumpstops? A couple of days at most then pushing it back to the free day.
    If dead set on installing the bumps later, put it back on the stands, support the axle and try loosening the u-bolts just enough to slip the new bump stops in. This way you aren't completely removing the u-bolts. Last thing you want is to be taking the u-bolts on and off. Never tried this so don't know if it will work.
    One thing, if re-using your factory bumps, you're going to have to drill them out a little bit to make them fit over the center pin (the center pin is longer than the bump stop is deep).
    Just wait. :anonymous:
    EDIT: This thread is huge - lots of info in it, just have to search the thread itself. I referenced it quite a bit when doing my OME install.
    https://www.tacomaworld.com/threads/old-man-emu-setups-on-1st-gen.141055/
    If you get stuck along the way, feel free to shoot me a PM.
  4. May 22, 2019 at 6:01 AM
    #44
    jeg0005
    Jon
    BHM, AL
    I'll just do the front end for now then. OR install it on factory bump stops now and order a U bolt flip kit w/ bump stops to do later
    Area51Runner[QUOTED] likes this.
  5. May 22, 2019 at 7:20 AM
    #45
    Kwikvette
    Kwikvette [OP] Well-Known Member Vendor
    Fresno County
    4 run, 2 don't
    When I first did my suspension, I knocked out the front 1 day and did the rear the week after.
    I've found people running the full OME kit don't bother with extending their bump stops. Not sure if the shocks are limiting droop or not but it's just a trend I had noticed.
    I did some more flexing last night and I intentionally pushed my truck at a steep angle -
    I got close to the bump stop and with limited travel left in my shock, I'm actually going to extend the stops a bit further.
    I don' rock crawl at all, but I'm one of those "better to have it and not need it than need it and not have it"
  6. May 24, 2019 at 4:10 AM
    #46
    jeg0005
    Jon
    BHM, AL
    Where are your jack stands here? The axle and the frame?
