Suspension Noise (with video)
Discussion in 'Suspension' started by J_Hacker, Mar 9, 2017.
  1. Mar 9, 2017 at 9:39 AM
    J_Hacker
    J_Hacker [OP] Well-Known Member
    Somewhere in Virginia
    '19 White Tundra Crewmax
    Bilstein 6112, CB +2 Shackles, Soft Topper, Method 316, 295’s
    I have been having some suspension noise on my drivers side. I finally strapped a go-pro in and video'd the noise. Noise starts mostly around 3:00. Icon extended travel coilover, icon tubular uca. It can be heard mainly when loading the drivers side
    any and all help would be appreciated
    https://youtu.be/VABzolJcG0g
    *Update post #35*
    KingKoda likes this.
  2. Mar 10, 2017 at 10:23 PM
    Drew12
    Drew12 Well-Known Member
    Andrew
    Sisters, Oregon
    2005 4x4 TRD OR Access Cab
    Bilstein 5100's/Toytec 620 coils, rear AAL, Camburg UCA's, Pro Comp 7069, AFE stage 2 CAI, Blacked Depo Headlights
    Dude... Pretty sure I have the same problem. Is it like a ticking noise going over subtle bumps and stuff? I have looked everywhere to find mine.. I am thinking it may be LCA related.. It almost sounds like a cracked weld on my truck.
  3. Mar 11, 2017 at 4:11 AM
    J_Hacker
    Yes there is a ticking noted
  4. Mar 11, 2017 at 6:33 AM
    Drew12
    Andrew
    Sisters, Oregon
    Have you found a remedy for it yet? Its driving me crazy and I cant find where its coming from after hours of looking.. I have a feeling its LCA related though. Either that, or something is loose in the engine bay and its being a PITA to find.
  5. Mar 11, 2017 at 9:21 AM
    J_Hacker
    not yet. planning to go through all moving parts in the front end tomorrow and torquing everything
  6. Mar 11, 2017 at 12:14 PM
    Drew12
    Andrew
    Sisters, Oregon
    Awesome. Looking forward to hearing how it goes.
  7. Mar 11, 2017 at 12:17 PM
    Thesandaddict
    Thesandaddict The dude
    Harley
    West Covina, CA
    2010 tundra bro-dozer
    Check the Allen bolt on the sway bar end links. Probably loose.
  8. Mar 11, 2017 at 12:19 PM
    Thesandaddict
    Harley
    West Covina, CA
    After watching video, im even more certain the bolts need to get tightened. Literally just did this to mine. Chased the issue for 2 weeks. It was the passangers side end link on mine
    J_Hacker[OP] likes this.
  9. Mar 11, 2017 at 12:21 PM
    Drew12
    Andrew
    Sisters, Oregon
    Good call. Forgot when I torqued mine that there is an allen key in that bolt. That being said though, my noise started haoppening before I installed my lift. And believe me, that nut was snugged down good when I tried to take it off. Not sure where mine is coming from still.
  10. Mar 11, 2017 at 12:23 PM
    Thesandaddict
    Harley
    West Covina, CA
    Double check it. I didnt take my sway bar off or even touch it to do my shocks and sure as shit 8 months later it worked its way loose. Crabked that effer down and my annoying click went away.
  11. Mar 11, 2017 at 12:27 PM
    Drew12
    Andrew
    Sisters, Oregon
    Shiet. Ill give her a go this weekend. Thanks man
    Thesandaddict[QUOTED] likes this.
  12. Mar 12, 2017 at 9:00 AM
    Bsheriff11
    Bsheriff11 Remember Your ABC's. Always. Be. Casual.
    Brandon
    Virginia livin', South Carolina raised
    2000 Limited T4R
    Click My Sig Homie
    Yea make sure the end link is sitting flush and tight! It can make that tinking sound if its not flush and bolt moves a little
  13. Mar 14, 2017 at 11:14 AM
    J_Hacker
    Went through everything on Sunday. Retourqed everything. Pulled CV and check ECGs bushing. Everything was good everything is at spec and tight. Butttt the noise is there, and louder. Not sure what the hell it could be
  14. Mar 14, 2017 at 1:00 PM
    KingKoda
    KingKoda Never Satisfied
    Palmetto
    '12 TRD.S DCSB 4x4
    Boosted TRD/URD All Terrain Sleeper w/ Sockmonkey Decals Worth +666HP
    i had seen your post awhile back (https://www.tacomaworld.com/threads/icon-coilover-issue.470228/page-2) and was hoping you might update that one.
    Have you changed out the lower shock mount bearing (http://performancelifts.com/icon-com-10-replacement-bearing-255110.html) that was suggested in the previous post?
    I have a similar noise in my front end when going over subtle rumples, bumps etc at a neighborhood speed (Icon Extended travel coil overs up front as well). I just live with it after going over all things to make tight several times the past couple years. I don't think it has to do with sway bar, haven't run that in ages either. I've got about 60K miles on my icons now fwiw, other than this rumple bump noise and little bit squeaky rear shocks when dirty, all is good.
  15. Mar 14, 2017 at 1:33 PM
    J_Hacker
    I have not done that yet. Completely forgot about it. Thank you for the info thou I will look into it further.
  16. Mar 14, 2017 at 1:38 PM
    DrFunker
    DrFunker Well-Known Member
    Check the torque on the alignment cam nuts.
    Had a noise similar to this and that was the issue.
    Thanks to @GHOST SHIP for that excellent diagnosis. :hattip:
    GHOST SHIP likes this.
  17. Mar 14, 2017 at 1:42 PM
    KingKoda
    Palmetto
    '12 TRD.S DCSB 4x4
    DrFunker[QUOTED] likes this.
  18. Mar 14, 2017 at 1:44 PM
    J_Hacker
    I checked them too. Torqued to 100ft lb.
    KingKoda and DrFunker[QUOTED] like this.
  19. Mar 14, 2017 at 1:44 PM
    DrFunker
  20. Mar 14, 2017 at 1:44 PM
    DrFunker
    damn.....:(
