Switch Pros 9100 install and BS thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PNWTacoma, Feb 16, 2018.
  1. May 11, 2020 at 7:34 PM
    #881
    Shellshock
    Iowa
    Take off the nut in the top left. Then the other pieces will pull out so you can open up the piece the wires come through. It’s hinged with a snap on one side. I think there was a little piece of tape to remove too.
    dhillr[QUOTED] likes this.
  2. May 11, 2020 at 7:36 PM
    #882
    Big_Salad
    Big_Salad Well-Known Member
    Mark
    Bay Area
    2019 Cement TRD OR DCLB
    Now that I have a switchpro, I've totally neglected any knowledge of wiring up an actual dash switch.
    I'm moving my ham radio from the switchpro to the blue sea fuse block, and turning it on/off with a dash switch. I'm used to just needing power and ground so running into some knowledge issues.
    Isn't a two way switch essentially just opening and closing a circuit? Why on earth are there 4 wires coming out of the back of the dash switch? If one of you more skilled than I can take a peek at this thread I posted in technical chat, I'd appreciate it.
    https://www.tacomaworld.com/threads/simple-dash-switch-wiring-question.665983/
  3. May 11, 2020 at 8:15 PM
    #883
    Shellshock
    Iowa
    Typically there’s an illumination light which is the 4th wire. So you have pos ground switched and illuminated
    you don’t have to wire up the last one. Most people just leave it or tie it to the switched wire.
  4. May 11, 2020 at 8:21 PM
    #884
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Why didn't I listen to you earlier :oops:
    AY_ARONTRD[QUOTED] likes this.
  5. May 11, 2020 at 8:25 PM
    #885
    AY_ARONTRD
    AY_ARONTRD Well-Known Member
    Aaron
    Murrieta ,CA
    2019 DCLB Cement OR 4x4
    Because at the time who knew what would happen :D
  6. May 11, 2020 at 8:25 PM
    #886
    Skydvrr
    Nick
    YMH
    Black '17 OR
    You still finding time for new ones? I know work has been crazy for a lot of us.
  7. May 11, 2020 at 8:29 PM
    #887
    AY_ARONTRD
    Aaron
    Murrieta ,CA
    Yea work has been super busy for me. But I’ve just been working my 40hrs. Turning down OT to stay on top of these Switch-Pros builds/installs
  8. May 11, 2020 at 8:35 PM
    #888
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Nice, I'll hit you up! I've been slammed. 60-70hrs. I worked 1:30am to 4:30pm today. It's been super crazy
  9. May 11, 2020 at 8:40 PM
    #889
    AY_ARONTRD
    Aaron
    Murrieta ,CA
    That’s a lot of hours. I would be passed out right about now.
  10. May 11, 2020 at 8:40 PM
    #890
    Skydvrr
    Nick
    YMH
    Black '17 OR
    The body has a way of acclimating. Fomo is real haha.
    Jeff Dartfrog likes this.
  11. May 11, 2020 at 9:06 PM
    #891
    YotalikesTacos
    YotalikesTacos Big Sexy Trail Limo
    Travis
    2017 Big Sexy Trail Limo TRD Offroad 4X4
    Great job.
    What size braiding did you use on the wires?
  12. May 21, 2020 at 8:30 PM
    #892
    Jabib
    Jabib Well-Known Member
    Garry
    Westminster
    2020 DCSB OR 4WD 6MT
    I searched the thread and found only post #867 - 870.
    Installing in a 3rd Gen TRD OR 6MT.
    Ordered Power Trays mount with the optional clutch reservoir bracket.
    Has anyone used this specific set up? Have pics? I think they sent me the wrong stuff or the stuff is not actually compatible with my configuration... Seems the SP mounted vertically would be in the same place as my clutch reservoir.
    First Photo - Mocked up.
    Second Photo - Obviously the tray will be further forward once the clutch res moves.
  13. May 21, 2020 at 8:37 PM
    #893
    Shellshock
    Iowa
    I think most either have a circle cut out for the clutch reservoir or a bracket to relocate it to somewhere else.
    Skydvrr likes this.
  14. May 21, 2020 at 8:45 PM
    #894
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    As a side note. I see you have hood struts. I have Redlines’s and I cannot use the cover on the negative bus bar as the strut hits it. It still just barely hits the far stud, without the cover, but I’m not worried about it since it’s a ground and not power.
    Jabib[QUOTED] likes this.
  15. May 21, 2020 at 8:58 PM
    #895
    Jabib
    Garry
    Westminster
    Thanks for the heads up!
    Totally bummed I installed the struts... Makes it way harder to get to some areas.
  16. May 21, 2020 at 8:59 PM
    #896
    Jabib
    Garry
    Westminster
    This doesn't address any of my questions.
    I specifically mentioned that the kit I bought included a relocation bracket.
  17. May 21, 2020 at 9:09 PM
    #897
    Skydvrr
    Nick
    YMH
    Black '17 OR
    It literally addresses the first question
    jcfitz7 and Shellshock like this.
  18. May 21, 2020 at 9:10 PM
    #898
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  19. May 21, 2020 at 9:31 PM
    #899
    Jabib
    Garry
    Westminster
    The very first question was "has anyone used this specific set up?"...
    I also specifically said I have the relocation bracket.
    I really don't want to argue with anyone or add filler to a solid thread. Just looking for a response from someone that can confirm that I was sent the wrong shit for my install.
    I saw the DIY bracket with the hole drilled out for the clutch res in posts #867 - 870. It's nice clean work but is it the exact same set up I am asking about? No. Not even close.
  20. May 21, 2020 at 9:39 PM
    #900
    Shellshock
    Iowa
    I thought the issue you had was the reservoir, you didn’t mention anything about struts and I didn’t see it.
    it depends where the mounting holes on the power tray are. Otherwise you may need some spacers to clear the strut.
    I’ve got the SDHQ mount and had to file out a notch for it to fit around my struts.
