Synthetic Oil and Dipstick
Discussion in 'Technical Chat' started by rentbw, May 19, 2010.
  1. May 19, 2010 at 9:56 PM
    rentbw
    rentbw [OP] Well-Known Member
    Brent
    Colorado/Illinois
    Black 09 Tacoma Sport
    Bull bar, Nerf Bars, Headlights, Cold Air Intake, Flowmaster Duel Exhaust.
    I changed to Royal Purple on my 09 tacoma, v6 I put in about 5.5 to 6 quarts and its not really showing up on the dipstick too good it is way to thin and runs up the whole stick, with my normal oil it was clear as day to read. Is this normal with Synthetic oils? is there a trick to making it easier? thanks I know there are posts on dipstick problems but none really with synthetic dipstick problems
  2. May 20, 2010 at 4:23 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The dipsticks on the 2nd gens absolutely SUCK and its normal.
    Some folks have sanded or roughed up the ends to help. I roughed mine up pretty good and it didn't help at all. For the most part - I put the recommended amount in, check the dipstick and guess where the mark is - and seeing the oil is there......and that's about it.
    I wish there was an aftermarket dipstick out there - I somewhat searched a couple years back without any results. I didn't spend that much time searching though....
  3. May 20, 2010 at 7:50 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Ha ha you have a little too much oil in there.
    5.2 quarts puts you at the top line and over if you did not drained all correctly so 5.5 - 6 is way above the full mark :)
  4. May 20, 2010 at 8:05 AM
    Janster
    Jandy
    Lancaster, PA
  5. May 20, 2010 at 8:12 AM
    rob1
    rob1 Well-Known Member
    Robert
    South Texas
    Indigo Blue DblCab 4X4 Long Bed TRD Sport SR5
    Tail gate mod, locking gas cap, locking spare tire, rear spring tsb,Weathertech Digital fit's
    I use Royal Purple also but to answer your concern is simple I think that's if you have not done this. Fill with 5 quarts then turn on engine so that some oil go's into the oil filter, turn off engine go inside have a cookie :cookiemonster:, (let the oil drain back down)then come out add some oil little by little till you can get an accurate reading on the dip stick Jimmy!! (sorry had to) :D
  6. May 20, 2010 at 8:59 AM
    BlueT
    NorthEast
  7. May 20, 2010 at 9:02 AM
    BlueT
    NorthEast
    Oh and as the dipstick goes. I think problem is related to the fact that dipstick makes S while goign to oil. So what I do is I remove dipstick for good 5-10 minutes for oil to come down from that pipe and then put dipstick i and out to get level. Hope that helps
  8. May 20, 2010 at 9:20 AM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    I have no problems with reading my dipstick, maybe it's because I use Toyota oil. [​IMG]
  9. May 20, 2010 at 11:58 AM
    Janster
    Jandy
    Lancaster, PA
  10. May 20, 2010 at 12:10 PM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    The best way to do it is to check it when the truck has been parked for a few hours like before you go to work and then first time you pull the dip stick is the amount of oil you have. rather than pulling the dip stick check it then put it in and checking again.
  11. May 23, 2010 at 6:13 AM
    intense
    intense Well-Known Member
    Georgia
    TRD OFF ROAD '07
    ASE Dry, Carbon filter removed, Grillcraft, 5100's. Low Pro Ameriweld box black powder. Tint / Vent Visors. Textured Black skid plate. Husky Liners. Design Seat Covers
    Let sit overnight and check before starting, true reading.
  12. May 23, 2010 at 6:59 AM
    Janster
    Jandy
    Lancaster, PA
    I've tried all that.....and my dipstick still sucks. I can get a half-assed reading from it but it always seems to read low. I put 5.5quarts in and that's all I need to know. The dipstick reading is just a backup (so to speak). As long as its on the stick somewhere within those lines...I'm happy.
