synthetic vs. regular oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pancho24, Jul 2, 2012.
  1. Jul 2, 2012 at 2:52 PM
    Pancho24
    Pancho24 [OP] New Member
    Temecula
    02 reg. cab
    wondering what the guys with the v6 engines use and why. Feel any difference or better performance?
  2. Jul 2, 2012 at 2:56 PM
    Holyfather
    Holyfather Well-Known Member
    Arizona
    2011 TX Pro TRD
    Front Bilstein 5100s @ 1.75"
  3. Jul 2, 2012 at 3:01 PM
    goufcustom
    goufcustom 7.62x63mm
    MD
    2006 4x4 TRD Off Road DC SR5
    Bed Topper, Diff Breather, aFe Cold Air Intake, Satoshi Grill, Moved Horns, Oil Catch Can, Tailgate Lock, Husky Mud Flaps, H4 65/70W Bulbs, Lower Grill Mesh, TRD Skid Plate, LEDs in the bed, LEDs behind the grill for accent lighting, Parking lights as turn signals, LED turn signals and reverse lights, 5100s up front, eibachs up front, SS extended brake lines all around, 1.5" AAL in the rear, Relentless Fab U-Bolt Flip Kit, ICON Progressive AAL, TRD Wheel Center Caps, HomeLink, Heated Driver Seat, Hella 500 FF Driving Lights, BAMF Diff Skid, BAMF LCA Skids, BAMF Rock Sliders w/ KickOut.
    Interested...
  4. Jul 2, 2012 at 3:02 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    '13 MGM AC 4x4 TRD OR
    Husky front mud flaps, OEM bed mat, 3D floor mats, Wet Okole seat covers, fog lights anytime mod, rear diff breather extension, aluminum Relentless tailgate reinforcement, NWexpo corner gussets, 265/75-16 Hankook Dynapro ATM
    In typing in 'synthetic vs. regular oil' in search, there are at least 13 threads on the first page...try reading those, they have plenty of info...
  5. Jul 2, 2012 at 3:05 PM
    friction
    friction Well-Known Member
    Charleston, SC
    '08 4X4 RC SR5
  6. Jul 2, 2012 at 4:52 PM
    graywolf2011
    graywolf2011 Well-Known Member
    Orlando Florida
    11 Tacoma 4X4
    undercover hard toneau, stainless steel nfab step bars
  7. Jul 2, 2012 at 5:04 PM
    Enzo
    Enzo Well-Known Member
    Opie
    Bedford, Va
    2012 FJ Cruiser
    2012 FJ Cruiser Maggiolina Medium Grand Tour w/winter hood National Luna dual battery split charging system ABR Sidewinder Aux battery tray ARB 50qt Fridge w/Transit Bag Bajarack flat rack w/ladder Crawlarado flat black hood blackout TRD exhaust Trasharoo Outback FJ roof console
    :D
  8. Jul 2, 2012 at 5:14 PM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    '11 TM DCSB & '13 BRM regular cab
    Leather seats, WeatherTech's, Access LiteRider tonneau cover, extra D-rings in bed & tailgate. Pelley lightbar with Hella 700FF's. Temp./compass O/H console.
    I like using synthetic oil in my 4.0L V6. I extended my personal oil change intervals to 5,000 miles. I originally changed out the "regular" oil at 1,000 miles, so my mpg figures aren't relavent. You pay more for synthetic, but you go farther between changes.
    Whatever you decide to run in your truck, just keep clean oil in the engine and you'll be A-OK.
  9. Jul 3, 2012 at 11:23 AM
    GuyWithCamera
    GuyWithCamera Well-Known Member
    Alan
    Tracy,CA
    Nissan 370Z
    Woah... Really? You change your oil really often. I would be doing oil changes twice a month if I did it every 1000 miles :eek: .
    I use Royal Purple with either a Royal Purple oil filter or at the moment right meow it has TRD filter... I change it every 7000 Miles. :cool:
  10. Jul 3, 2012 at 11:27 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Extremely dusty conditions warrant more oil changes. Not 1k oil changes, but faster all the same. I have no clue why one would change oil at 1k, but I can say if you NEED to change at 1k something is seriously lacking with the trucks set up.
  11. Jul 3, 2012 at 4:05 PM
    billygoat
    billygoat Well-Known Member
    American Southwest
    05 TRD Offroad 4x4
    OME lift, Duratracs, BAMF sliders, Brute Force hybrid bumper, XRC8 Comp winch, raised sleeping platform, shell, breather relocation
    The purpose of synthetic oil is not to improve power or torque. Synthetic oils lubricate better, and that is what they are designed to do. They provide better shear resistance and superior lubrication over a wider range of temperatures. AKA if you drive in the snow, extremely hot weather, or tow, you should run synthetics for that reason alone. A normal stock engine does not require synthetic, but will last longer if you run synthetic. Yes, you might pick up a single HP or two, but really you should run synthetics because your engine will last longer and it will be cheaper when you extend the change intervals.
  12. Feb 11, 2013 at 2:56 PM
    2006TRDSPORT
    2006TRDSPORT 2006TRDSPORT
    Felton, Delaware
    2004 4Runner SR5 4WD
    I just changed mine from conventional to synthetic at 91K, not because I think that conventional didn't do it's job, but because I think synthetic will do even better and with higher mileage it's worth the extra few dollars.
  13. Feb 11, 2013 at 3:03 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I used regular oil until the truck was out of the 60k mile warranty period then switched to Mobil 1. I extended my oil change interval to 7,500 miles (will still change at 5k miles if I'm towing or hauling frequently) but did not notice any changes in the truck at all.
  14. Feb 11, 2013 at 3:06 PM
    scottw1
    scottw1 Well-Known Member
    Scott
    Norfolk, VA
    2010 SR5 Tacoma 4x4
    Lighted 4wd dial, Sirus XM radio
    Please, read some of the other 100s of posts about syn or conv. This topic is covered on every forum I've ever looked at in more than great detail.
  15. Feb 11, 2013 at 3:11 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  16. Feb 11, 2013 at 3:14 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    I use synthetic BECAUSE I am LAZY-do not need to change as often.
    Costs are about the same if you figure in the mileage.
