Tachometer Not Accurate
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jonas111, Dec 15, 2015.
  1. Dec 15, 2015 at 9:18 PM
    Jonas111
    Jonas111 [OP] Well-Known Member
    Kelowna, BC, Canada
    I have a 2005 Tacoma Quad cab with a 4.0 and Manual transmission.
    I noticed today the tachometer isn't very accurate. When at idle it shows 0rpm. When I start to go and I haven't got it much above 4,000rpm Max.
    Has anyone had this issue and what did they find was the issue?
    Thanks in advance
  2. Dec 16, 2015 at 3:48 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Not sure, but the following threads seem to mention needle misalignment, bad ECU connection, or defective crank position sensor:
    https://www.tacomaworld.com/threads/1998-2-7l-tachometer-reading-wrong.350137
    https://www.tacomaworld.com/threads/tachometer-not-at-0-rpm-help.172840
    https://www.tacomaworld.com/threads/2005-tachometer-failure.299186
    https://www.tacomaworld.com/threads/3-4-tachometer-false-reading.349710
  3. Dec 16, 2015 at 4:03 AM
    NMW 4x4
    NMW 4x4 Wheels With Moose.
    Walt
    T8 R11 WELS, Maine
    '14 DCLB SR5 4x4
    I had that exact issue in my '07. I took the plastic cover off of the gauge cluster and with the engine running at idle, manually moved the needle back to ~750 RPM. That put it back into alignment for the entire RPM band. A little hack, but it worked. I had to do it three times throughout the life of the truck.
  4. Dec 16, 2015 at 6:00 AM
    Jonas111
    Kelowna, BC, Canada
    I did a search and didn't come up with any of these. I really need to learn how to do a search better. Thanks for this.
