Taco Bros - Technical Thread/Mazn Build Thred
Discussion in 'Off-Topic Discussion' started by dakotasyota, Dec 3, 2014.
  1. Feb 3, 2015 at 4:49 PM
    #2081
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    How can you actively monitor your mpg? :rolleyes:
  2. Feb 3, 2015 at 4:54 PM
    #2082
    Boogyman
    Boogyman Well-Known Member
    Phoenix
    Corpus Christi, TX
    2022 Lunar Rock Trail Edition
    Your killing me lol
  3. Feb 3, 2015 at 5:15 PM
    #2083
    AR15xAR10
    :D i know
  4. Feb 3, 2015 at 5:47 PM
    #2084
    TacoMitch93
    TacoMitch93 Tasty Taco
    Mitch
    Nova Scotia, Canada eh
    09 Tacoma SR5
    I took out the whole hub and bearing and gave them to my dad to take to work to press out and press the hub into the new bearing.
    The only thing I replaced was the bearing itself. It's mounted in a casing though, you need to take 4 bolts out the axle nut and what not and "tap" it out. you gotta be careful not to bed your backing plate though, you can tap it back into shape, or it'll just bend back on its own when you sandwich it between the knuckle and bearing housing. took me around 2 and a half hours to take them out and reinstall them over 2 days (had to wait for my them to come home with dad :D)
  5. Feb 3, 2015 at 6:01 PM
    #2085
    dakotasyota
    dakotasyota [OP] Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    Atta boy! How many monies? I don't want to spend $170 or whatever for a brand new hub.
  6. Feb 3, 2015 at 6:30 PM
    #2086
    TacoMitch93
    Mitch
    09 Tacoma SR5
    I spent 50 bucks at toyota for 2 seals and 1 oring and got the other matched at a hydraulic place for free, and the bearings them selves were 140 each. I could have got cheap bearings for 90 bucks but I want them to last a little while. I need to replace the inner seal on the driver side. It's toast. That'll happen in the spring. If you're going to do your bearings yoy want to get the dust seals because if not it'll eat away at the bearing and it won't last. The guy at toyota told me they normally only replace the outside (it's pressed in between the hub and the bearing) and the inner one you can do if you take the axle out.
  7. Feb 3, 2015 at 8:23 PM
    #2087
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    Dakota i got moog wheel bearings from advance auto parts for 110 a piece. 45 mins to uninstall and 45 min to reinstall per side. so about 3 hours total. Although it may take you less time if you can use that lift. Mitch is a lucky bastard to have quick access to a lift
  8. Feb 3, 2015 at 9:22 PM
    #2088
    TacoMitch93
    Mitch
    09 Tacoma SR5
    :D too bad the 5 gallon compressor I have only puts out like .2 CFM
  9. Feb 3, 2015 at 10:21 PM
    #2089
    TacoMitch93
    Mitch
    09 Tacoma SR5
    Mine were moog aswell. NSK bearings.
    Canadian problems, 30 bucks more for the same part
  10. Feb 3, 2015 at 11:48 PM
    #2090
    dakotasyota
    Dakota
    Ellensburg, WA
  11. Feb 4, 2015 at 8:24 AM
    #2091
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
  12. Feb 4, 2015 at 8:40 AM
    #2092
    AR15xAR10
  13. Feb 4, 2015 at 8:55 AM
    #2093
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    I'm debating on getting one for a spare just incase on a long trip one goes out.
  14. Feb 4, 2015 at 8:58 AM
    #2094
    dakotasyota
    Dakota
    Ellensburg, WA
    I don't think bearings just "go out" they get worse and worse before the seize right?
  15. Feb 4, 2015 at 9:03 AM
    #2095
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Oh do they? I knew they made a noise but i thought really soon after that they seized.
  16. Feb 4, 2015 at 11:17 AM
    #2096
    MTopp
    05 SR5 4x4
    I'm not sure, but I drove on a bad one for a week or two with like 2 short highway trips. It'd only groan and vibrate bad when the steering wheel was turned to the right though. If I were driving a long trip, I'd get an extra.
  17. Feb 4, 2015 at 11:19 AM
    #2097
    MTopp
    05 SR5 4x4
    And I knew it was the driverside because 1) thats where it felt was coming from 2) I jacked up that side, grabbed the tire with both hands in multiple spots and moved it back and forth and felt it move slightly, meaning slop in the bearing.
  18. Feb 4, 2015 at 1:41 PM
    #2098
    TacoMitch93
    Mitch
    09 Tacoma SR5
    One might blow apart on freak chance.... hahaha. If I went on long wheeling trips, far away from roads I'd probably carry one.
  19. Feb 4, 2015 at 2:56 PM
    #2099
    dakotasyota
    Dakota
    Ellensburg, WA
    That seems a bit extreme guys haha
  20. Feb 4, 2015 at 3:03 PM
    #2100
    tacobell007
    Drew
    Western MA
    x2 they'll blow apart and weld themselves onto your hub before they seize. My passenger side pressed off in 2 pieces and a load of ball bearings on the floor... Dakota its cheaper to buy moog bearings and get them pressed than it is to buy pre-assembled. 110 a bearing and $40 a hub for pressing (unless you know someone, for me it was $20, or mitch where it was free...)
