Taco Bump Steer? Where to Start?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ColeRedRubi, Mar 14, 2016.
  1. Mar 14, 2016 at 5:16 PM
    ColeRedRubi
    ColeRedRubi [OP] Well-Known Member
    I just crawled under it and checked again. Looks like one of the bushings on a lower control arm has a LOT more play than the rest. Like 3/16". I'm guessing that is a big problem so I'm going to replace that and then take it to get it realigned with higher caster. What do you think I should tell them to shoot for with the caster number?
  2. Mar 14, 2016 at 5:28 PM
    ColeRedRubi
    Anybody know of a good writeup on replacing LCA bushings?
  3. Mar 14, 2016 at 5:29 PM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    I'm pretty sure I read a thread that said that the lca bushings are a pain in the ass. Did you actually see the lca move? You can wiggle it around?
  4. Mar 14, 2016 at 5:31 PM
    deeezy
    Dana
    Hawaii
    Make sure what you think is "play" is not how the stock bushings actually look like.
  5. Mar 14, 2016 at 5:35 PM
    ColeRedRubi
    Yeah I can see it move quite a bit, its night and day compared to the other side. It is moving a really noticeable amount.
  6. Mar 14, 2016 at 5:37 PM
    deeezy
    Dana
    Hawaii
    Well then, that sucks. It shouldn't move at all.
  7. Mar 14, 2016 at 5:38 PM
    ColeRedRubi
    Yeah, just got a quote for $900 to replace all 4 C/A Bushings :annoyed:
  8. Mar 14, 2016 at 5:42 PM
    deeezy
    Dana
    Hawaii
  9. Mar 14, 2016 at 5:58 PM
    Armkb
    Armkb Well-Known Member
    Hudson Valley, New York
    09 TRD Sport DCLB
    Bilstein 5100, OME 885X, LR UCA, ARB/EL095R, ES LCA Rack & Sway Bar Bushings, Yellow Wire Mod, ABS Switch, TPMS Mod, Scanguage, Toyota Bed Mat, WeatherTech Floor Liners, Extang Trifecta Cover, Fumoto Drain Valve
    My vote is for more caster and replacement of steering rack bushings. Rack bushings can be a pita to install but doable. Replaced rack, sway bar and my LCA's with Energy Suspension bushings. Not to crazy bout the LCA bushings as they can be somewhat harsh at times. My E rated General Grabbers dont help.
    I would say my steering has definitely improved from stock form. Very precise and got rid of my bump steer.
    vtown likes this.
  10. Mar 14, 2016 at 11:48 PM
    Carson403
    Carson403 Active Member
    Carson
    Santa Barbara, CA
    2020 Cement TRD OR M/T
    Magnuson SC
    I'm thinking about replacing my bushings with the Energy Bushings. Have they started to squeak? A shop in town said the Poly bushings tend to be really loud.
    Did you have to reuse the inner sleeve to install them?
  11. Mar 15, 2016 at 3:37 AM
    Armkb
    09 TRD Sport DCLB
    The rack bushings wont experience any squeaks mainly by there design. I replaced all of my bushings over a year ago and am squeak free.
    The hardest part of the rack was getting the OEM bushings removed. I usex a pneumatic pickle fork which help tremendously. No inner sleeve for the rack bushings only the LCA's.
    My only problem after replacement of bushings is my traction control goes nuts once in a while when making a wide right turn. Have resorted to using my ABS delete more often. Have tried the Yaw sensor recalibration but problem still persist. Funny thing is it didnt do it after the lift and LCA bushings. It started later when I replaced the sway bar and rack bushings. Go figure.
  12. Mar 15, 2016 at 3:46 AM
    Armkb
    09 TRD Sport DCLB
    Forgot to mention. I have 2 sets of wheels and tires. General Grabber AT2's 235-85/16 on stock steelies and Nitto Terra Grapplers 265-70/17 on stock Sport wheels. The Grabbers track straight and true while the Nittos tend to wander more. Only drawback to the Grabbers is the E rating. Very stiff side walls for such a light truck. Not very happy with the performance of the Nittos. Wont buy them again.
  13. Mar 15, 2016 at 8:55 AM
    ColeRedRubi
    Thanks for all of the support guys. I'm going to have to wait until this weekend to install the bushing. I got a Moog bushing set off of Amazon. Hopefully that cures the problem. Now that I realize where the play is it makes sense based off of what I am feeling in the steering.
    Once I get the new bushings in and C/A back on any suggestions for setting the alignment to make it to the alignment shop? I'm just going to take it straight to the shop and take all back roads driving under 40 mph to get there. Should I be safe doing that? I'm new to independent front suspension so sorry for any newb questions.
  14. Mar 15, 2016 at 9:01 AM
    deeezy
    Dana
    Hawaii
    I would try to get your caster in the high 2's and camber and toe close to zero.
    vtown likes this.
  15. Mar 15, 2016 at 9:02 AM
    #35
    ColeRedRubi
    Thanks!
  16. Mar 17, 2016 at 4:44 PM
    #36
    ColeRedRubi
    I just dropped the truck off at a family friends place who is a mechanic so we will see what he has to say. After that I'm going to an alignment shop to get my caster set differently. I'll let everybody know if this fixes my problem.
  17. Mar 18, 2016 at 4:04 PM
    #37
    ColeRedRubi
    Had the mechanic look at it, I guess there aren't any worn bushings and the ball joints/ Tie rod ends, inner tie rods, sway bar end links, rack bushings are all good. I did the zip tie fix and that actually helped quite a bit. I'm hoping that when I go get it aligned with higher caster my issue goes away. Its starting to look like I might just be picky haha. Still I'm glad I know now that everything is good in my front end.
    deeezy likes this.
  18. Sep 17, 2023 at 6:29 AM
    #38
    BlueTaco9486
    BlueTaco9486 Well-Known Member
    Bunk
    2013 Blue Taco
    Factory Off Road Package
    What numbers are desirable? I’m having this issue.
  19. Sep 17, 2023 at 6:31 AM
    #39
    BlueTaco9486
    Bunk
    2013 Blue Taco
    Did the higher caster work?
  20. Sep 17, 2023 at 8:54 AM
    #40
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I don't agree with this. If you don't have a bunch of extra weight in the rear, a 285 does not need more than 32 PSI to hold the ass end of your little truck up. This has nothing to do with your bump steer.
    I'd bet money that if you did a chalk test, you'd see that the outer lugs on those back tires are barely even touching the ground. This is just my opinion.
