Taco turbo
Discussion in '1st Gen. Tacomas (1995-2004)' started by Memodonis, Jul 2, 2017.
  1. Jul 2, 2017 at 2:56 PM
    Memodonis
    Memodonis [OP] Member
    Adelmo
    Tacoma 03
    Hi guys, I'm New in this community and I have couple questions before start my project: Alright, I have a tacoma 03 2.4L 5 speed with 203,000 in the engine and I want put turbocharger on it but I don't know if first I need to rebuild it and I don't know exactly what kind of kit I need to buy for, thanks for look my post and for your help.
  2. Jul 2, 2017 at 3:06 PM
    Neutral
    Neutral Well-Known Member
    Fella
    Alabama
    14 SR5, 25 SR5
    14 4.5" RCD, Pelfreybilt armour, Fox coilovers/shocks, Alcan leaf springs, 4.56 gears, 35's 25 Stock
  3. Jul 2, 2017 at 3:14 PM
    Memodonis
    Adelmo
    Tacoma 03
    Thanks Neutral, do u know some shop they can put turbochargers in Birmingham area or somewhere of Alabama.
  4. Jul 2, 2017 at 5:40 PM
    Neutral
    Fella
    Alabama
    14 SR5, 25 SR5
  5. Jul 2, 2017 at 6:04 PM
    Memodonis
    Adelmo
    Tacoma 03
    :thumbsup::thumbsup::thumbsup:
    Neutral likes this.
  6. Jul 3, 2017 at 3:36 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Having a Shop do this type of work unless your lucky enough to find one that has done this type of install.
    Is really going to be expensive
    What is your end game here.
    Till your done a 3.4 swap will be much cheaper with lots more support
  7. Jul 3, 2017 at 4:37 AM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Check out LC Engineering.
    I personally would stalk the classifieds for a manifold and buy the rest new.
    yota243 and Memodonis[OP] like this.
  8. Jul 3, 2017 at 6:21 AM
    Indy
    Indy Master of all I survey.
    A whole lot of investment for very little return.
    99SuperTaco4x4 likes this.
  9. Jul 3, 2017 at 6:56 AM
    Memodonis
    Adelmo
    Tacoma 03
    How much do u think I'll go investment for this project because I have in mind spend like 2,500 or 3
  10. Jul 3, 2017 at 7:03 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Personally for that budget I'd just get the supercharger that LCE offers, it comes with fueling and ignition management as well.
  11. Jul 3, 2017 at 9:00 AM
    jgill21
    jgill21 Not Technically Stock Anymore
    Jake
    Nashville
    98 2.7 TRD PreRunner
  12. Jul 3, 2017 at 9:52 AM
    Memodonis
    Adelmo
    Tacoma 03
  13. Jul 3, 2017 at 12:36 PM
    Memodonis
    Adelmo
    Tacoma 03
    But before I need to rebuild the engine with turbo kit or something like that right guys. Somebody can tell me what kind of kit I need to buy and where (ebay or Amazon) or some store selling online
  14. Jul 3, 2017 at 1:05 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  15. Jul 3, 2017 at 1:07 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Way less support, if going turbo.
  16. Jul 3, 2017 at 1:11 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Do a compression test. Check cylinder health. Change your old cracked vacuum hoses for new. Change the fuel fitler.
    After a compression test, you will know if you should upgrade the head gasket and add some ARP studs in, or keep it like it is until you want/need to.
    Best bet, is like others said. www.lceperformance.com Your engine is their specialty.
    Brice and boostedka like this.
  17. Jul 3, 2017 at 1:21 PM
    ArcherTaco
    ArcherTaco Well-Known Member
    Riley
    Greeley/Windsor, CO
    '13 DCLB TRD Sport
    Toy-Tec Kit, Tool box fit to bed, Dipped badges, cab lights, running boards, Flowmaster exhaust
    ^ This guy know what's up. Just be careful. Follow Tor very long and you'll be on your third engine before you know it :rofl:
    Brice and BassAckwards like this.
  18. Jul 3, 2017 at 1:22 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Shhh......:laugh: :spy:
    holyfield19 likes this.
  19. Jul 3, 2017 at 4:48 PM
    Memodonis
    Adelmo
    Tacoma 03
    Ok guys thanks I'll go with carefully :rofl:
    I have another engine with bad head and somebody tell me I can use it to rebuild with a turbo kit (cylinders, rings, valves, everything new) but I'll go test the compression of the cylinders (thanks for the idea Torspd)
  20. Jul 3, 2017 at 7:47 PM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    I turbo'd my motor at 175k a year ago and I've had no issues. Like torspd said, a compression test will really let you know if you need to do any motor work before boosting it. If you're going for a low boost setup (6psi or less), you shouldn't have much more maintenance than before.
    Memodonis[OP] likes this.
