Tacoma Habitat AT
Discussion in 'Tonneau Covers, Caps and Shells' started by battdoc, Jan 22, 2017.
  1. Dec 10, 2017 at 9:08 PM
    #201
    breakfasttaco93
    breakfasttaco93 Well-Known Member
    Dan
    2017 Tacoma 4x4 TRD Off-Road
    What does 1L / 2L mean? Was talking about mounting to the 'top' of the habitat for lightwhen it's open.
  2. Dec 10, 2017 at 9:10 PM
    #202
    kalieaire
    kalieaire i didn't know they stacked sh*t that high.
    Santa Clara County
    '12 TRD Off-Road 4x4 AC V6 6MT
    Adventure Trailers Atlas, Demello Sliders, BAMF Skids, PelfreyBilt Bumpers, SCS Ray 10
    first floor vs 2nd floor. like the top outside? or inside?
  3. Dec 10, 2017 at 9:11 PM
    #203
    kalieaire
    Santa Clara County
  4. Dec 10, 2017 at 9:14 PM
    #204
    breakfasttaco93
    Dan
    Ahh gotcha. Like the top outside, on the underside of the bed when open.
    I went with the LEDs in the bed of the truck from AT, and have a luminaid supernova I throw in the netting above the bed for light on the second floor, so good on interior lighting for now.
  5. Dec 10, 2017 at 9:20 PM
    #205
    kalieaire
    Santa Clara County
    On the top, outside, would be above the tent. If that's the case, then I have LED xmas lights that I can throw on top to be festive for photos of the exterior, and I guess I could put some random lights up there like a luminoodle to signal my location.
    The underside of the bed, I use rock lights from Amazon, 6-pack for $40
  6. Dec 10, 2017 at 9:22 PM
    #206
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    I cook by boiling water based food (soup, food in foil pouches, hot drinks, etc.) in a tent only, especially if snow camping.
    excorcist likes this.
  7. Dec 10, 2017 at 9:27 PM
    #207
    breakfasttaco93
    Dan
    Cool, thats what i'm thinking of doing as well. So they're permanently mounted on the underside of the bed? How did you do the wiring? Any pics?
  8. Dec 10, 2017 at 9:53 PM
    #208
    kalieaire
    Santa Clara County
    Nothing on hand right now since I haven't actually wired them yet. lmao
    Rock lights will be setup for cab control because I count them as navigation/trail lighting and tied to the vehicle battery. I wouldn't normally use them in a camp setting since that's what lanterns and other exterior lighting is for, and I don't really need to crawl around under my truck if I'm camping in a single spot. When I finally setup the aux battery properly, I'll have accessory lighting like this available to turn on with an RF relay in case I ever need to work on stuff on the trail like replace a prop shaft or the mounting bolts for my leaf springs.
  9. Dec 10, 2017 at 10:22 PM
    #209
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    @kalieaire we were talking about mounting rock lights under topper that provides the "built in awning" so the lights would be pointing straight up when habitat was not deployed, then when it flips over they would be pointing @ ground behind truck.... I think your talking about mounting them under the bed of the truck.
  10. Dec 10, 2017 at 11:32 PM
    #210
    kalieaire
    Santa Clara County
    Oh that's easy. Just run airline track on either side and seal with silicone.
    Then just use any standard airline track quick release or studs and string up some standard Goal Zero LALs.
    excorcist[QUOTED] likes this.
  11. Dec 10, 2017 at 11:37 PM
    #211
    kalieaire
    Santa Clara County
    Oh, another "Fancy" choice would be to glue some stainless steel plate to the bottom of the habitat to maintain a low profile and also provide separation (to prevent galvanic effect). Then just use those OXYLED Strip lights from Amazon. The only downside w/ this model is you'll need a 12v to 24v voltage boost converter and wiring it up, but if you have a little bit of wiring experience, it's exceedingly easy.
  12. Dec 11, 2017 at 5:06 AM
    #212
    tacofort
    tacofort Well-Known Member
    Joe
    Cincinnati, OH
    2017 Toyota Tacoma TRD PRO, Automatic, Cement
    Adventure Trailers Tacoma Habitat Pelfreybilt Rock Sliders Line-X Pelfreybilt Pro mid, Gas, Exhaust Reroute Skids Hondo Unholey Dash mount Total Chaos Bed Stiffeners Redline Tuning Hood Lift Struts Weathertech Floor Liners
    Just ordered to do the same. The tembo tusk truck has them and they are slick.
  13. Dec 11, 2017 at 12:00 PM
    #213
    breakfasttaco93
    Dan
    Yeah just checked it out, trying to figure out how the wiring works. Probably a switch inside the habitat, which I don't have.
    I have L-track on the 'roof' of my Habitat, and have some D-ring studs on there I use to tie bags down, so may just hang some luminAID packlights for outside lighting, and mount the dome lights under the truck.
  14. Dec 11, 2017 at 2:44 PM
    #214
    kalieaire
    Santa Clara County
    The challenge with wiring up the roof is the movement. As we all know, wires don't like being continually bent/twisted etc. This makes it difficult for permanent solutions.
    The Baja Designs lights have their own individual light switches which makes them easy to turn off and on. But then you'd have to either poke a hole in the base to run wires internally and then down the wiring pillar, hopefully to an internal switch to prevent the lights from turning on when the setup is closed.
  15. Jan 12, 2018 at 10:21 AM
    #215
    breakfasttaco93
    Dan
    Anyone have any tips/ideas/recommendations for building out internal storage in the Habitat? I think I will eventually cave ($$$$) and go the Goose Gear route, but want to get some cheaper storage options going in the meantime.
    Thanks!
  16. Jan 12, 2018 at 10:52 AM
    #216
    Moogle
    Moogle Dyslexic Stanist
    Glen
    Alameda, CA
    07 Silver TRD Sport DCSB 4x4 6-speed
    Blood of virgins
    I've been looking at goose gear stuff trying to figure out the details on how they are constructed, to try to build something similar myself. The frame is just T-slot aluminum but I don't have a good idea on the rest.
    excorcist and tacofort like this.
  17. Jan 12, 2018 at 11:01 AM
    #217
    tacofort
    Joe
    Cincinnati, OH
    I want a combo slide with the stove from AT, also i'd like to get a molle panel for the side walls to put pouches on. For bulk storage, totes of whichever manufacturer you prefer work well for gear, I use plano. Drawers would be slick, but I am at an impasse on built in system convenience versus the ease of moving totes about. Check out this build, super slick ideas and great to follow.
    The goose gear system is slick, but the last thing I would spend money on personally, need to finish suspension, dual battery, fridge, stove, etc.
    Good luck on your build sir. Be sure to send pics.
    As far as tips or tricks, measure everything. Every inch of your gear. I've built a couple chuck box camp kitchen type things over the years and there is really 2 approaches. Build it to hold anything, or build it to hold exactly your stuff that you like today. This dramatically changes the build. do you want future flexibility or are you set on the gear and stuff you have today? If your coleman stove is the one you intend to use for eternity, build a spot on a shelf or drawer for it, otherwise plan for what you might buy down the road and find the happy medium. I tend to believe, you'll have a better system if you build it for what you need, not what someone else wanted.
    HomerTaco likes this.
  18. Jan 12, 2018 at 12:31 PM
    #218
    kalieaire
    Santa Clara County
    They use L brackets for a lot of the mounts. In some instances on the T slot you can drill and tap into the aluminum framing directly. In the X style with a slot on each of the 4 sides, you can use a nut inside and screw in the L Bracket that way so you have a modicum of adjustability. For the bed plate, just standard line-X'd baltic birch mounted to the frame. If you just bought a bunch of bulk frame, and and made your own bed plate, you can start framing up stuff and just cut off what you need with an angle grinder. You can use SketchUp for free to make your first design and then adjust everything as needed.
  19. Jan 12, 2018 at 12:31 PM
    #219
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Excellent advice. :thumbsup:
  20. Jan 12, 2018 at 12:36 PM
    #220
    kalieaire
    Santa Clara County
    In lieu of cabinetry, I've been using front runner bins. They're not water proof, they're not the deepest, longest, or even super amazing, but they have performed relatively well strapped down. I usually have 2 stacks of cub packs stacked 4 high side by side closest to the cab strapped down with a single ratcheting cargo strap and they've never moved.
    tacofort[QUOTED] likes this.
