Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Aug 17, 2018 at 6:30 AM
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    Two 08 Highlanders, 11 Outback, 13 Outback
    In order of install: Tint all around Weathertech floormats Center console insert and tray 17x7.5 +15mm alloy FJ rims, painted black Morimoto 2stroke led low beams Toyota bed mat AVS in-channel vent visors Removed black stickers from doors Removed air dam Debadged JDM ASTAR reverse leds Door sill protectors Reflective black tailgate inserts Rear cam anytime Fabric console cover Extra coverage engine guards Rigid SAE fogs Kicker/Subaru in-dash speakers JBL GT7-96 front door speakers JBL GT7-6 rear door speakers Hushmat deadener and wave breakers in doors Noico deadener behind rear seats Timbren Tortun4L rear bumpstops Added Line-X'd OEM flares OEM mudflaps Skid from TRD OR Avid Off Road front bumper guard Fatmat hoodliner 2nd gen 5100's with 2885s Sway bar relocate Cut off exhaust behind spare Wet Okoles on front seats Wheelers Superbumps Wheelers 2” single AAL ATH corner tie-downs ATH bed stiffeners Line-X’d rear bumper end caps TRD Sport/OR tail lights OEM bed step TRD Pro grille Fortin remote start Leer 180 Sleeping platform in bed 265/70/17 Terra Grappler G2 BPF front recovery point OV Tune 1.04 87 Westin 30” hidden bumper light bar Rago hidden bumper brackets
    I thought I had no mpg gain from 1.04 87 over stock, but really I had compensated for mpg increase by having too much fun driving. Got a ticket, calmed down a bit, and seeing probably around 2 mpg higher.
    double_duez, KkelX4, Dor and 3 others like this.
  2. Aug 17, 2018 at 6:36 AM
    MasonicTaco
    MasonicTaco Member
    2017 TRD Sport Inferno
    If I have 04B12 right now in my MT how would I go about getting 04B13?
  3. Aug 17, 2018 at 6:43 AM
    Pickupman2007
    Pickupman2007 Well-Known Member
    Kenneth
    Murfreesboro, TN
    2022 Rivian R1T
    2020 Tacoma: Morimoto xB LED Headlights & fogs, MESO Total Tail S1, Fortin Evo One Remote Start, OEM Audio Plus System 500Q,, Redarc trailer brake controller, Carplay2Air wireless adapter, Custom shift knob, Electric tailgate lock, Chrome tailgate inserts, Limited fog light bezels, 2018 TRDOR Grill, Chrome door handle covers
    MasonicTaco[QUOTED] likes this.
  4. Aug 17, 2018 at 6:50 AM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Sounds like when Mat/ @OVTune releases 1.05, it will include all of the changes that cane with 04B13 anyway. Just the ID will be different from what it would be from Toyota. I'm assuming this means if you elect to wait for Mat's update, your ECU version will still be 04B12?
    @MOC221_ @Shellshock any wisdom to share? I've actually been considering just doing two flashes basically, once 1.05 releases. One to bring me up to 04B13 and then immediately afterwards to update with 1.05, if the alternative is running 04B12 1.05...i dont think my dealer would, but I'd prefer them to not just update me without telling me ahead of time. This way, they'd think there's no reason to do the update during servicing
    MOC221_ likes this.
  5. Aug 17, 2018 at 7:03 AM
    acemastr
    acemastr Well-Known Member
    Aaron
    Tampa, FL
    2016 Tacoma Limited 2WD AT
    OVTune
    Why do you care what the version number says? He can make it "ILikeTrees" if he wants, it's still the same thing
    dagsamp and MOC221_ like this.
  6. Aug 17, 2018 at 7:16 AM
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    1.0-iliketrees-5!!
  7. Aug 17, 2018 at 7:17 AM
    Pickupman2007
    Kenneth
    Murfreesboro, TN
    2022 Rivian R1T
    I believe @mZiggy reasoning is if he were at the dealer for something and they saw 04B12 and the available 04B13 they might update his truck, overwriting the OVTune. But if he had 04B13 before OVTune it would just look like 04B13 and no update would show up, eliminating the possibility of overwriting.
    taco 16, Anchovy and mZiggy like this.
  8. Aug 17, 2018 at 7:17 AM
    acemastr
    Aaron
    Tampa, FL
    OVTune
    A dealer automatically update your truck out of goodwill? hah! :p
    Anchovy, catastrofe and DakoTaco like this.
  9. Aug 17, 2018 at 7:37 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Ok, but what is the tune based on? The underlying code?
  10. Aug 17, 2018 at 7:39 AM
    MOC221_
    Frank
    This is basically what I'm doing, although I've already done the first step lol.
    Shellshock and mZiggy[QUOTED] like this.
  11. Aug 17, 2018 at 7:39 AM
    acemastr
    Aaron
    Tampa, FL
    OVTune
    The tables within the file, the revision or name is irrelevant apart from keeping track of what you're on. His new turbo ID is OVBoost01 for instance.
    MOC221_[QUOTED] likes this.
  12. Aug 17, 2018 at 7:48 AM
    Taco16LB
    Taco16LB Well-Known Member
    When taking a truck into Toyota for warranty work , they cannot tell if it has an ovtune if it has the same as stock ECU calibration #. If the truck has Twin turbos on it , well , they will most likely be noticed so the ecu calibration # being changed is not a problem so long as they see they need to leave it alone . If you do not have turbos , you want Toyota to think it is a stock tune and the # from OVTune says it is . If you have turbos you do not want Toyota to reflash it , and the warranty for the engine is done anyway , so the name for a turbo tune should not be the same as a stock tune .
    Edited
  13. Aug 17, 2018 at 7:48 AM
    MOC221_
    Frank
    I don't know if I agree with this statement. Mat's enhancements to a particular OEM calibration change many things (throttle, ignition, VVT, shift points etc). He has stated a few times now that there is a boatload of other code that he does not alter. For example, how something such as "requested torque" is actually calculated (the math). So, if Toyota improves "the math" in a later calibration, it absolutely does matter what a new OVtune is based on. That's what I'm trying to say.
    ie 04B13 > 04B12
    dingel5, inksin, su.b.rat and 3 others like this.
  14. Aug 17, 2018 at 7:50 AM
    mZiggy
    mZiggy Honey badger
    Marc
    Yeah that's what i was getting at. I've been taking my 4R and now my Tacoma to this dealer for about 5 years now and they're no strangers to aftermarket stuff and I don't have the impression they'd overwrite without first asking, but i was just kinda hypothesizing. It's not really an issue if they overwrote the tune, i could just rewrite when I got home. Just would be an annoyance is all
    MOC221_ likes this.
  15. Aug 17, 2018 at 7:51 AM
    mZiggy
    mZiggy Honey badger
    Marc
    If the truck had turbos on it and they overwrote with a different map (I'm assuming that's what you meant? It's what i read it as) then that is absolutely a problem lol
  16. Aug 17, 2018 at 7:55 AM
    acemastr
    Aaron
    Tampa, FL
    OVTune
    If it has twin turbos you bet your ass they'll be test driving it lol
  17. Aug 17, 2018 at 7:57 AM
    dagsamp
    dagsamp Unknown Member
    Marla
    16' TRDOR DCSB OV Tune
    OV Tune
    I feel like they would be smart enough not to fuck with a truck that has turbos on it.
    Shellshock likes this.
  18. Aug 17, 2018 at 8:05 AM
    Taco16LB
    Thanks for the catch . I edited it .
    mZiggy[QUOTED] likes this.
  19. Aug 17, 2018 at 8:17 AM
    Shellshock
    Iowa
    I just assume anything the dealer can mess up, they will. You can go in and beg for an update and not get it. Then go in for an oil change and surprise they updated you. I’d just update it yourself then not have to worry.
    I don’t plan on making any more trips to the dealer unless something catastrophic happens or I’m buying a new truck
  20. Aug 17, 2018 at 8:27 AM
    su.b.rat
    su.b.rat broken truck
    not irrelevant. i don't even need to know more to be able to say this.
    exactly. it's more than the maps. if there are conditional statement and dependencies in the code that shit cannot be totally and effectively reverse engineered, which probably describes why this release is on another level of smoothness and consistency than the previous OV releases. Toyota has provided far more than updated mapping in 04B13 from previous.
    inksin likes this.
Thread Status:
