Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Mar 26, 2019 at 6:18 PM
    SpeySquatch
    2016 TRD OR DCSB
    Interesting hearing some of people’s issues with the tip-in of performance tunes. I consider myself somewhat of a heavy foot.
    When I first flashed it seemed aggressive, but after clearing values in techstream it was very smooth and manageable. Maybe clearing values adjusts how the tip-in is interpreted by the ECU?
    :notsure:
  2. Mar 26, 2019 at 6:20 PM
    treimche
    treimche Well-Known Member
    Fargo, ND
    Wish there was a way to know. I couldn't stand the "tip in" of the performance tune so went back to base.
    SpeySquatch[QUOTED] likes this.
  3. Mar 26, 2019 at 6:27 PM
    Mike O
    Mike O Well-Known Member
    2016 TRD OR MGM Access Premium LB
    Mobtown Sliders, SSO Slimline bumper, Baja Amber lightbar & fogs, Sumo bump stops
    Probably the best reason for Mat to NOT do this.
  4. Mar 26, 2019 at 6:36 PM
    dpippel
    dpippel Well-Known Member
    Phoenix, AZ
    Super White 2020 TRD Off Road 4WD DCSB A/T
    Not for me. Clear values every time, but as I've mentioned before the tip-in on both 87 and 91 Performance is just too much for my liking when driving in heavy traffic or off-roading.
  5. Mar 26, 2019 at 6:37 PM
    SpeySquatch
    2016 TRD OR DCSB
    Definitely seems like heavier, lifted, and/or bigger tire trucks work with the tip-in better. Heavy Portland traffic was not that bad at all when I drove it as my daily
    PNWTacoma likes this.
  6. Mar 26, 2019 at 6:39 PM
    dpippel
    Phoenix, AZ
    I'm running 33's with a tri-fold tonneau and 3" King lift.
    SpeySquatch likes this.
  7. Mar 26, 2019 at 6:44 PM
    Crimson Flam3s
    Crimson Flam3s Well-Known Member
    How different do 87 perf and 93/91 perf feel in regular driving ?
    I'm just wondering if the power difference is across all rpms or is it just at the higher end like 5-7krpm or WOT?
    Unless you are WOT, in most acceleration scenarios, the truck seems to accelerate mostly around 3-5k rpm and I know that 87 perf had big gains in that range, so I'm wondering higher octane tunes has a noticeable performance increase in that range.
  8. Mar 26, 2019 at 6:47 PM
    GPH36
    GPH36 Well-Known Member
    2019 Black TRD Pro
    Just flashed 87 Perf. Whoa.
    GPatriot likes this.
  9. Mar 26, 2019 at 6:51 PM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    @OVTune, does this mean we will see the shudder fix at the end of summer or sometime sooner?
    Taco16LB likes this.
  10. Mar 26, 2019 at 7:15 PM
    runmc
    runmc Well-Known Member
    Ron
    DFW Texas
    2021 Army Green Tacoma TRD OR DCSB
    One Mod after another
    I started of with 87 performance. I'm almost at 200 miles and I'm really liking it. I'll probably stay here for awhile.
    PapaRee and Theclclass like this.
  11. Mar 26, 2019 at 7:38 PM
    roy326
    roy326 Well-Known Member
    Roy
    Southern California
    2020 Tundra/V8 4Rnner/GX460. I do miss my tacoma
    How is every one calculating how many misfires and know % of load on the truck at a given gear?
  12. Mar 26, 2019 at 7:49 PM
    El Taco Blanco
    El Taco Blanco Well-Known Member
    2017 White Tacoma SR5 4x4 DCLB
    Stock (for now)
    I’ve read through a large portion of this thread and just purchased the tune. My question is, that here in Georgia most of the mid grade gas around here is 89 octane. Is there a time for that? Or should I just go with the 87 tune?
  13. Mar 26, 2019 at 7:57 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    You'll have to settle for 87, 91, or 93. There is currently not an 89 octane tune and Mat mentioned at one time there would not be one in the future.
  14. Mar 26, 2019 at 8:04 PM
    SpeySquatch
    2016 TRD OR DCSB
    Try the 87 tune first with that gas it should run nicely
  15. Mar 26, 2019 at 8:23 PM
    Shellshock
    Iowa
    You find a number you like and pick that one.
    No need to search for a problem unless you are experiencing one
    iexc, PRO_Taco, lapoltba and 4 others like this.
  16. Mar 26, 2019 at 8:32 PM
    SpeySquatch
    2016 TRD OR DCSB
    This is some of the best info on
    this thread.
    tonered, mZiggy, Neutron and 4 others like this.
  17. Mar 26, 2019 at 9:10 PM
    alwaysHI
    alwaysHI Well-Known Member
    2017 MGM DCSB
    Pro Comp 6", full length 5100's with OME 888 w/ taco lean spacer, 5160s w/ Alcan custom pack, HS extended brake lines, Summit offroad Dakar 17x9, 315/70/17 Falken Wildpeak MT, Nitro 4.88 regear
    Alright, 90 mile trip, plus 10 off road in 4lo on 1.05 87 performance.
    First off, to get to where I am is a pretty ridiculous elevation change. I’m currently camping, roughly 800 lbs of BS, 33’s, 4.88’s and 6” lift with bed racks (if we wanna consider the drag factor). She pulled in 4th gear up steep, long hills around 3200-3300 rpm, and 5th when it tapered. 6th gear on flats. I thought that was very impressive, considering the weight and elevation change from ocean level to roughly 8,000.
    Tip in:
    I’m used to this. Feels like driving a fire engine lol.
    Even in 4lo, very tolerable.
    I understand the tune is still settling in, but going from 87 base to 87 performance, there’s a difference.
    If you’re lifted, heavier tires, and carry weight, performance tune is a must.
    Now, excuse me as I enjoy my cold beer, and relax after working 200+ hrs the past two weeks
    If you’re reading this and still on the fence of buying the OVTune, just do it.
  18. Mar 26, 2019 at 9:12 PM
    roy326
    Roy
    Southern California
    Back to my dumb question. What software are you using to see this information ?
  19. Mar 26, 2019 at 10:01 PM
    Shellshock
    Iowa
    None. I’ve never had a reason to look. :notsure:
    nxcess, mZiggy and inksin like this.
  20. Mar 27, 2019 at 4:48 AM
    Taco16LB
    Taco16LB Well-Known Member
    Deucer01 likes this.
Thread Status:
