Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Dec 16, 2019 at 7:08 AM
    VoodooPro
    VoodooPro Well-Known Member
    2019 Voodoo blue TRD Pro
    OV 93 tune, TRD pro intake, LED headlights, LED interior lights, tuffskinz interior overlays "RCF", tailgate inlay, Illuminated kickplates, blue interior compartment inlays. Painted voodoo blue interior trim, nitto ridge grapplers, bara 1 inch spacers, redline pro hood struts, trd oil and radiator caps.
    Weird even after the 19800 2.0 flash my truck still does the same damn thing. If I go WOT through the gears, its ether 3rd or 4th, cant tell..... it revs to redline, stalls and suddenly acts like I'm not pressing the peddle at all, the tach drops to about 4k and suddenly it accelerates again and shifts like nothing happened. Consistently does this every time, every version of the tune I've used since 1.05. Whether I do it from a dig, or a kick down on the highway it will shift fine for a gear or two, then fuck up, then shift fine again. Its outright dangerous on the highway or trying to pass. Cant be relied on at all, have no idea what's wrong. I've posted this before explaining the issue better I just dont care to repeat it. It ONLY does this at WOT. If I drive "normally" it will shift perfectly every time without fail. It will even do this issue if I have it in "manual" mode and shift myself, I will let it get up in the rpm range, press forward and it will shift..... until it comes to the bullshit gear, and I will press fwd and nothing will happen just keeps climbing in RPM, bouces off redline, stalls dangerously, then finally decides to shift.
    paleh0rse and RyanDCLB like this.
  2. Dec 16, 2019 at 7:10 AM
    TheUpstateTACO
    TheUpstateTACO Well-Known Member
    2018 Silver DCSB TRD OR 4x4
    Yakima Overhaul HD bed rack, Faux Pro Grill
    Good call, unfortunately I'll have to update from 04A60 to 04A61 before I can go to 2.0. I'll check out 1.05.1 until then, have to head to the dealer for my 25k service in the next few weeks anyway, I'll have them update to 04A61 when I go.
  3. Dec 16, 2019 at 7:36 AM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    Ditto. I'm on the 2.0 - 87 base tune w/ 4:88's.
  4. Dec 16, 2019 at 7:43 AM
    rdpoe
    rdpoe #2WDFTW
    Central Kentucky
    2019 TRD OR DCLB (Sold), Honda Civic TRD PRO
    Submitted to Mat via zendesk?
    Shellshock likes this.
  5. Dec 16, 2019 at 8:01 AM
    VoodooPro
    Yeah I talked to him via email a while back and was told to try a different tune. This is the 3rd different update I've tried.
  6. Dec 16, 2019 at 8:07 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    maybe its not the tune?
  7. Dec 16, 2019 at 8:13 AM
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    Did you let him know that it is still happening with other tunes you've tried? Maybe log it and send him the logs.
  8. Dec 16, 2019 at 8:18 AM
    ihatemytruck
    Dave
    Southern California
    Make sure you print a copy of the tsb, and tell them you experience the same symptoms. The stumble at elevation is a good one, because some dealerships aren't at elevation, so they can't give you too much push back. It's also pretty easy to install the free version of techstream and do the update yourself.
  9. Dec 16, 2019 at 8:28 AM
    paleh0rse
    paleh0rse Well-Known Member
    Raleigh, NC
    2019 Cement Tacoma TRD Off-road DCLB
    You're not alone. My 2019 TRDOR (04B30) has exhibited the exact same behavior with WOT on more than one occasion. I don't often drive with WOT, so it hasn't been a total showstopper for me, but it's certainly a little scary when it happens unintentionally.
    Maybe I'll try to log the experience for Mat... if I can figure out the logging process.
  10. Dec 16, 2019 at 8:31 AM
    paleh0rse
    Raleigh, NC
    Just realized we're all running the tune on 2019 trucks. Probably not a coincidence.
  11. Dec 16, 2019 at 8:33 AM
    VoodooPro
    I have the little orange square thing that plugs into the obd2 port and then into my laptop, not 100% sure how to log with that flasher.
  12. Dec 16, 2019 at 8:35 AM
    Shellshock
    Iowa
    With the logger that’s in flash manager
  13. Dec 16, 2019 at 8:37 AM
    VoodooPro
    I'm familiar with logging using a cobb access port, so hopefully it's similar. Just initiate, do a bunch of 36 to 60 pulls and then stop it? I'm sure it's not hard, but just coving bases. The instructions on how to flash dont say how to log.
  14. Dec 16, 2019 at 8:43 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Rafael is working on a step by step logging guide for our logger.
    The shift at WOT issue is only present on 2019s on some trucks, with the same shift tables that work fine on others.
    It *could* be from other modifications but I think some trucks just require to shift sooner before the limit.
  15. Dec 16, 2019 at 8:52 AM
    VoodooPro
    Cool. So can I have a super special secret squirrel version of 2.0? I dont have any mods unless you count the TRD intake and exhaust. PM me and I will give email if need be. I'm currently running the 19800 91oct performance gearlock 2.0 tune. I use 93 with it too btw.
    paleh0rse likes this.
  16. Dec 16, 2019 at 8:56 AM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    I've gone ahead and bought a used OVTune dongle kit, what do I have to do the get a license so I can tune my truck? I assume I'm sol until Jan 5th or after?
  17. Dec 16, 2019 at 8:58 AM
    go2cnavy
    go2cnavy Well-Known Member
    ‘17 OR DCLB. VF Tuned, 5.29s, Dobinson’s MRR
    OVTuned w/ 5.29s 2” lift on Dobinson’s MRR paired with ICON RXT leaf packs. SCS RAY 10s Toyo Open Country AT III 285/70R17
    Mine did this a few times. Ended up being a bad high pressure fuel pump. T-SB-0016-18
    edit: mine had nothing to do with the shift, but rather fuel starvation at WOT and max rpm.
    El Chivo Norteño likes this.
  18. Dec 16, 2019 at 9:03 AM
    RyanDCLB
    4/19 DCLBOR
    My truck was manufactured in April 2019. TSB says for years 16-17 Tacoma per the attachment here.
  19. Dec 16, 2019 at 9:08 AM
    paleh0rse
    Raleigh, NC
    I'm willing to test a custom version of 2.0 beta for 04B30 if/when you try to fix this issue. I can probably do some logging for you, as well.
    I'd really appreciate a fix, so please just let me know.
  20. Dec 16, 2019 at 9:13 AM
    RyanDCLB
    4/19 DCLBOR
    I'm on 04B31, and can help with logging or testing too... Zendesk #7296
Thread Status:
