Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Jun 19, 2020 at 8:31 AM
    Shellshock
    Iowa
    the registry key is tied to the system ID of your computer, so he needs that ID to generate the key.
    If you send in your dongle, you get VF tuner for free ($79 upgrade) plus FM w/ p5flash
  2. Jun 19, 2020 at 8:34 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Because a dongle goon pissed OVT off and he simply changed his terms. Search back and give that person a piece of your mind.
  3. Jun 19, 2020 at 8:36 AM
    Lt_Dan
    Lt_Dan Well-Known Member
    Daniel
    Cincinnati OH
    2017 TRD OR 4x4 DCSB A/T Super White
    I don't mind that if I can get the tune right now and the VF tuner later when he receives the dongle, I don't think that'll happen though haha
  4. Jun 19, 2020 at 9:11 AM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    This had been forecast for some time; ie probably as far back as 2+ months ago it was made known that 2.0 wouldn't release on dongle. I just dove in and sent mine in so that I could get everything prepared and ready for when 2.0 released. It worked out well for me.
    I get it.... when I downloaded the tune pack for my ECU, there was ~30 tunes in there. Multiply that by the number of ECU's, and then double that again for dongle, and it's a ton of detail work to keep straight. I think the number is that now less than 100 dongle users (or at least that was the number ~2 months ago) exist. That's probably a pretty small percentage of the whole tuned community.
    Lt_Dan, tonered and PhogDog like this.
  5. Jun 19, 2020 at 10:05 AM
    Gjr003
    Gjr003 Well-Known Member
    Ya the process is generate a ticket, mail your dongle, matt replies with reg info when he gets your dongle. He has to email someone to generate the registration so add a couple days there. The instructions are a probably 50 pages back at least.
    jholc21 likes this.
  6. Jun 19, 2020 at 11:42 AM
    txags92
    txags92 Well-Known Member
    2016 DCLB TRD OR 4x4 BBP
    Sounds to me like they are all describing not having gear lock...which you have pointed out several times is not part of this 2.0 version. Going from a gear lock tune back to one without gear lock and then driving in s mode would produce exactly the shifting behavior changes they are describing. Wanting to keep gear lock is the only reason I haven't downloaded the new version to fix my cold start hiccup. Other than the cold start hiccup, the most recent 2.0F with gear lock is perfect for me.
    BortisYeltzen and blitzkrieg3002 like this.
  7. Jun 19, 2020 at 12:58 PM
    paleh0rse
    paleh0rse Well-Known Member
    Raleigh, NC
    2019 Cement Tacoma TRD Off-road DCLB
  8. Jun 19, 2020 at 1:05 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :hattip:
    On the dongle issue, run away: :bikewhoops:
    Don't go playing edit games here.
    wahoobie and johntoyota like this.
  9. Jun 19, 2020 at 1:18 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    340-ish miles so far
  10. Jun 19, 2020 at 1:50 PM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    04A61, 2.0 reg 89oct 35 THX. I’m stock tires and gears but thought I would get slightly higher shift points by running the larger tire size tune. So far it appears to me that all the shifting is bang on and the 4-5 shift under light throttle dosent happen until 2700 (should be 1700)rpm. With the previous tune it appeared to occur at around 2500 (should be 1500) so that extra 200 is good. Seems to have eliminated any bogging on the upshifts under light throttle. Great feeling. If you’re wondering how I know what gear I’m in, it’s monitored on my Scangauge.
    Has anyone who is monitoring trans temps notice that it appears to be running cooler with 2.0F base? I have about 450 mi using D only and the pan temp is never exceeding 185* and the atf cooler has not come on. Based on previous situations, I would expect it to heat up at the TC enough to open the cooler tstat but that hasen’t happened yet. I’ll be towing next weekend so I’ll likely see some different readings that include the atf cooler. Also to check out how ECT works.
    Just an thought that perhaps @OVTune has tweaked this tune so things run a bit cooler than previous? Is that possible?
    I have no complaints as everything appears to be working as one would expect a new truck to work. Kudos to Mat for a great product. Worth the wait.
    It will tide me over until the gearlock version is released.
    Cheers
    Edit: Corrected (bold) at what rpm the 4-5 upshift happens.
    GPatriot, dubs66 and tonered like this.
  11. Jun 19, 2020 at 2:23 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    I did notice it as well.
  12. Jun 19, 2020 at 2:31 PM
    johntoyota
    johntoyota "I'm higher than you'll ever be." -Treetop
    Down yonder in TN
    16 truck
    I have noticed the trans temps running cooler. And the MPG running higher.
  13. Jun 19, 2020 at 2:36 PM
    svermilyea
    svermilyea Well-Known Member
    Scott
    East Tennessee
    2018 Taco Sport (Cement)
    3in leveling lift (Coilovers and AAL) 285/65R18 tires 18" Fuel wheel/tire package Pro Grill, Morimoto XB LED Headlights, DD SS3 Pro Fogs Body Armor Front and Rear Bumpers Pioneer WC6600 head unit w/ OEM Audio + Reference 500 System with dedicated sub amp Meso signal lights, gas hole, led interior lights, ECT relocate, Chrome delete kits Meso Overhead Molle Rack, Seat Risers, Katzkin Leather seats (self installed...it was a fucking bitch) VFTuned .....KDMax Pro!
    I am about 700 miles in on 04A61 Premium 33 Thx . Around town mgp went from 15.5 to 18.5. Highway mpg went from 18.5 to 21.2. Very happy!
  14. Jun 19, 2020 at 2:45 PM
    runmc
    runmc Well-Known Member
    Ron
    DFW Texas
    2021 Army Green Tacoma TRD OR DCSB
    One Mod after another
    Running same tune here. Let me know when you get AGM battery 14.6 volts figured out with VFT :cheers:
    MacMedic, GPatriot and johntoyota like this.
  15. Jun 19, 2020 at 2:46 PM
    johntoyota
    Down yonder in TN
    16 truck
    I plan to ask for experienced help when someone gets the voltage thing figured out. I don’t have it in me keep up with another OV thread that I’m already so far behind on.
    runmc[QUOTED] likes this.
  16. Jun 19, 2020 at 2:46 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
  17. Jun 19, 2020 at 2:47 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    But, the vF has managed to stay out of the dumpster so far.
  18. Jun 19, 2020 at 2:49 PM
    johntoyota
    Down yonder in TN
    16 truck
    Even without the fires, I’m sure there is a lot guessing, speculation and just plain wrong shit in there.
  19. Jun 19, 2020 at 2:52 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    IDK about that last one? Definitely the first two, but hey, it's TW.
  20. Jun 19, 2020 at 2:54 PM
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    There is A lot of guessing and speculation in your post, check out the thread and find out the truth :thumbsup:
    johntoyota[QUOTED] likes this.
Thread Status:
