Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Aug 4, 2020 at 6:15 AM
    Saeros
    Saeros #dealermole
    Canada, Eh!
    2022 Venza Limited
    I had two that were lose.
  2. Aug 4, 2020 at 6:16 AM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
  3. Aug 4, 2020 at 6:32 AM
    Shellshock
    Iowa
    I had one that was looser than the others but not to the extent others have seen getting blow by.
  4. Aug 4, 2020 at 6:40 AM
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    Looks like I'll be checking my plugs now
  5. Aug 4, 2020 at 7:08 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Mine weren't loose at all. Changed at ~50k if I remember right
    BlkTaco47 likes this.
  6. Aug 4, 2020 at 8:06 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    ownubad and DES2009[QUOTED] like this.
  7. Aug 4, 2020 at 8:24 AM
    xLOGREx
    xLOGREx Well-Known Member
    Logan
    SL,UT
    2017 White SR5
    Little of this, little of that.
    Which tune from the Tacoma pack offers the best MPG? Also what is a succinct difference between the options?
  8. Aug 4, 2020 at 9:34 AM
    SpeySquatch
    2016 TRD OR DCSB
    Not only possibly loose, but when you change them make sure you get the EXACT factory plug gap (which I believe to be .032” if I remember correctly).
    I tried some plugs that looked identical to the factory plug (3 prong NGK Iridium), but they were .040” gap and the truck ran odd and got -3/4 mpgs over the week I tried it. Switched to correct plug (sorry cannot recall part #) and the oddities were gone.
    20tacoma17 likes this.
  9. Aug 4, 2020 at 9:50 AM
    bunz559
    bunz559 Well-Known Member
    Fresno, CA
    2018 Tacoma TRD Off-Road
    Waiting for someone to chime in and post, "I didn't buy a truck for MPG. If you're worried, should've gotten a Prius." :popcorn:
    :rofl:
    Skydvrr and rlx02 like this.
  10. Aug 4, 2020 at 9:56 AM
    xLOGREx
    Logan
    SL,UT
    2017 White SR5
    You do make a good point but I still want to do the best I can. Although I think I do better than most right now with an avg of 23 mpg.
    bunz559[QUOTED] likes this.
  11. Aug 4, 2020 at 9:59 AM
    bunz559
    Fresno, CA
    That is crazy good from my experience. Highest I've seen was 18ish. But average daily I see 14-15. Most highway trips I get a hair above 17. It is what it is. LOL
  12. Aug 4, 2020 at 10:13 AM
    Idahotaco88
    Idahotaco88 Well-Known Member
    Steven
    2017 black AC OR
    Kings 2.5 with adjusters, icon rxt stage 2. SCS stealth blue on 35s
    Thanks for the good info. I just checked mine and they were not loose. I wonder why some are loose like that.
    SpeySquatch[QUOTED] likes this.
  13. Aug 4, 2020 at 10:31 AM
    Shellshock
    Iowa
    Probably the same reason some are low on trans fluid
  14. Aug 4, 2020 at 1:16 PM
    TEXAS BS
    TEXAS BS Formerly known as MMXVII
    JB
    Texas
    2017 ACLB TRD OR 4X4
    So, what is the correct torque on the plugs?
  15. Aug 4, 2020 at 1:19 PM
    xLOGREx
    Logan
    SL,UT
    2017 White SR5
    13 ft lbs for Gen 3 Tacos.
    I believe 15 ft lbs for Gen 2.
    SpeySquatch and TEXAS BS[QUOTED] like this.
  16. Aug 4, 2020 at 1:38 PM
    01Snake
    01Snake Fast Car Junkie
    SATX
    2020 White TRD Sport DCSB 4X4
    Anyone have this on their 2020? I've only had my rig for about 500 miles but I honestly don't think the way it drives is too bad at all. (It's a truck after all) Occasionally there is a slight lag when mashing the gas but it seems to shift fine. I'm sure I need some more seat time to get more accustomed to it but so far, so good. With that said, if people with 2020's are finding that the vehicle drives a lot better after the OVTune, I'd strongly consider doing this mod. :D
  17. Aug 4, 2020 at 1:58 PM
    dabbinuguay
    dabbinuguay Well-Known Member
    PDX, Oregon
    2017 Tacoma TRD OR DCSB
    With the range of MPG's and truck behaviors reported here, does anyone have thoughts on whether there is some sort of drivetrain friction, or load, that varies between our trucks?
    Example: Does the rear differential assembly (not gear choice) have opportunities to introduce MPG loss if it's not assembled exactly right? If not rear diff, maybe transmission, or transfer case?
  18. Aug 4, 2020 at 3:47 PM
    dunlap837
    dunlap837 Well-Known Member
    2018QSDCLBSR5
    Enhanced Skinny Pedal
    I suspect its all load - heavy tires, armor, hills, or even just a lead foot.
    From what I understand nearly all of the efficiency improvements from second gen to third gen are in the low rpm, low load regime. Get above that magic engine load number, and you’re not gonna see any improvement.
    But like many internet theorists I have no data to back my hypothesis up.
    SpeySquatch likes this.
  19. Aug 4, 2020 at 5:33 PM
    Frito
    Frito Well-Known Member
    If I was only getting 14 MPG, I'd Definitely be driving a Tundra !
  20. Aug 4, 2020 at 6:20 PM
    Invid
    Invid Well-Known Member
    New Braunfels, Texas
    2016 Tacoma Limited
    Yeah, I've never got that low of mileage even when being aggressive around town.
Thread Status:
