Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Aug 18, 2020 at 8:48 AM
    tacocart762
    tacocart762 Well-Known Member
    desert55gr
    Santa Clarita Valley
    2017 Tacoma TRD Offroad Dbl Cab Long Box
    1.5in Bilstein 6112 Front,1in Alcan Leaf Rear with Bill 5100's. Battle Armor side step,bull bar, and rear step.
    That is good. Isn't it a common theme that the truck will not hold a gear going up a hill? Maybe I am just reading these posts incorrectly.
  2. Aug 18, 2020 at 8:55 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Depends on the hill. Dont expect to hold 5th on 3k -4k passes while keeping up with a speed limit. Even drive by "bale wire" cars cannot maintain that.
    tacocart762[QUOTED] likes this.
  3. Aug 18, 2020 at 9:08 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    I don't wanna cluster f this thread even more, but can somebody explain to me in a private message the breakdown of how vF tuner will work for flashing other trucks. I have the current kit (not USB) and license already now but wanna buy vF Tuner and flash my friend's truck for him.
    All I know right now is I will need to buy vF Tuner for $79, after that, I don't understand what I need to buy to start flashing my truck and friends with that software.
    Thanks
  4. Aug 18, 2020 at 9:12 AM
    xLOGREx
    xLOGREx Well-Known Member
    Logan
    SL,UT
    2017 White SR5
    Little of this, little of that.
    If I'm getting this tune, would getting a TSB before make any difference or would the tune override any benefit a TSB would offer?
    tacocart762 likes this.
  5. Aug 18, 2020 at 9:17 AM
    Shellshock
    Iowa
    All of this is answered in the vF thread
    https://www.tacomaworld.com/threads/vf-tuner-for-the-3-5l-tacoma.662948/
    If you have further questions, feel free to PM me.
    Technique[QUOTED] likes this.
  6. Aug 18, 2020 at 9:58 AM
    InternationalHarvester
    InternationalHarvester VF Pro Licensed, KDMAX Authorized Vendor
    Sierra Nevada
    2017 TRD DC LB OR 4x4
    KDMAX Tooooned
    Yeah, update first, then tune. Isn’t a requirement, but will provide better final results.
  7. Aug 18, 2020 at 10:00 AM
    xLOGREx
    Logan
    SL,UT
    2017 White SR5
    Okay thank you. I'm trying to look up what TSB(s) I should try to get for my truck but I'm having some difficulty. You have essentially the same truck as me except I have a SR5. Would you happen to know what one I would need or how to find it?
  8. Aug 18, 2020 at 10:01 AM
    Shellshock
    Iowa
    You can do it yourself. All the instructions and files you need are in this thread
    https://www.tacomaworld.com/threads/ecu-tsb-update.562550/
    Skydvrr, tonered and xLOGREx[QUOTED] like this.
  9. Aug 18, 2020 at 10:33 AM
    tacocart762
    desert55gr
    Get the update from the dealership or you can do it at home yourself.
    xLOGREx[QUOTED] likes this.
  10. Aug 18, 2020 at 10:33 AM
    tacocart762
    desert55gr
    x2
  11. Aug 18, 2020 at 10:48 AM
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    PM'd
  12. Aug 18, 2020 at 11:17 AM
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    i only drive in s4...always. it's the only way it shifts properly.
  13. Aug 18, 2020 at 12:20 PM
    Tharris242
    Tharris242 Technically
    Houston, TX
    2017 TRDOR DCSB 4X4 A/T FP TO BL
    Solid Fold 2.0, Air Dam
    Hopefully, that's all it is and I can eventually fix it with vF tuner. This lack of shifting (thus acceleration) with so much pedal input is illogical. I'd own a manual if the wife wasn't so uncoordinated.
    GPatriot and VB25 like this.
  14. Aug 18, 2020 at 1:58 PM
    inksin
    inksin Well-Known Member
    Hawaii
    2016 Off Road access cab
    Doesn't matter what TSB you get for your truck cause as long as it's for your model year, every TSB will update you to 04B04.
    Follow Shellshocked's link and it'll tell you what to download and how to do it then thank Tonered for making a great tutorial
  15. Aug 18, 2020 at 2:00 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :hattip:
  16. Aug 18, 2020 at 2:02 PM
    xLOGREx
    Logan
    SL,UT
    2017 White SR5
    Well thank you both!! I wasn’t sure how the TSBs worked but what you’re saying and the link helped a ton. For simplicity’s sake I made an apt with my local Toyota dealer to have them do the TSB for me.
    inksin[QUOTED] and tonered like this.
  17. Aug 18, 2020 at 2:04 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Just sayin', but it wouldn't hurt to be prepared for disappointment. That is the main reason the ECU Update thread is still alive.
    xxTacocaTxx, inksin and Shellshock like this.
  18. Aug 18, 2020 at 2:08 PM
    xLOGREx
    Logan
    SL,UT
    2017 White SR5
    Disappointment about what?
    If it’s that it doesn’t make the truck drive as good as it should, I’m getting my OVtune soon to take care of the rest. I was just told to get the TSB first because it’s better to do so.
    tonered[QUOTED] likes this.
  19. Aug 18, 2020 at 2:08 PM
    inksin
    Hawaii
    personally I wouldn't bother with the dealership. Often times they make you jump through hoops to get the service that you are owed and even then, sometimes they still won't do it for you. There are numerous threads about it here. If you do it yourself not only do you get the updated ECU version but you gain a valuable tool to be able to understand your truck and are able to diagnose and modify factory settings (like seatbelt and door chimes and blinker functions and other shizz that Toyota will charge you to do). The more you understand your vehicle the less dependent you are on the dealership and others
  20. Aug 18, 2020 at 2:09 PM
    Shellshock
    Iowa
    No. Disappointment because the dealer gives you the run around and refuses to do it. Thats what happens to a lot of people here. Hence why we’ve done it ourselves
Thread Status:
