Tacoma Spring refurbishing
Discussion in 'Suspension' started by 4WD, Dec 22, 2011.
Thread Status:
Not open for further replies.
  1. Dec 26, 2012 at 11:58 AM
    #1081
    4WD
    4WD [OP] cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    I think most get the theory of progressive susp. the confusion seems to be what makes a spring progressive. (meaning to what degree factor X (thickness)or how much material is reduced to factor Y (thin leafends)
  2. Dec 26, 2012 at 12:47 PM
    #1082
    4WD
    Doug
    2004 DC TRD 4x
    Ok , to answer your other questions, 1st gens use what they call an eliptical spring (confusion already) I just call it "centerpin offset" because they are diff. lengths from the centerpin to the eyeletts of spring, centerpin to front hanger is shorter than centerpin to rear shackle (longer)
    2nd gens are centerpin to eyeletts equal distance from either front spring hanger or rear shackle to centerpin...
    You don't want to mix leafs in regards to thickness or lengths, there must be uniformity or a harsh or at very least a very "odd" ride quality will result
  3. Dec 26, 2012 at 3:42 PM
    #1083
    Blutus
    Blutus Active Member
    Whoa, you mean there's a NEW Mexico??
    1998 Tacoma SR5 V6 4wd
    Interesting. If I understand anything I read through this ENTIRE 57 pages :eek: I'm going to guess that spring will be a firm load-carrying ride (because of the linear short-ish one at the bottom) but smooth and civilized on the streets because of the progressive (and longer) ones above it.
    Am I close? :D
    What donor for the progressive ones?
  4. Dec 26, 2012 at 3:53 PM
    #1084
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    Having a tapered leaf is a good indication that it is progressive, but the real test is to measure displacement vs load. We can calculate the deflection/load at any point on any leaf or combination of leaves, by know the length, width, taper and ARCH, with arch being a critical value. I suspect most of the spring design is done via assembly of sample springs and testing them, since the math isn't straight forward and requires many runs. This is a good place for some computer programing since many runs are needed for each load/deflection.
    See, each leaf has a certain load/deflection, and the leaves have to be combined, based on deflection. I would assign a deflection and then get the load.
    On the other hand, if you have a shop press with both a force read out AND a stroke, and have a way of mounting the spring in very rigid frame, you can do some very good tailoring.
    Or we can go to a local spring shop and they have tables, arching equipment and a metal worker than can shear and punch bulk leaf material.
    Howard
  5. Dec 26, 2012 at 3:57 PM
    #1085
    4WD
    Doug
    2004 DC TRD 4x
    Oh, you're very close , the progressive springs for donors are harder to come by, but to be honest I've had far better results with rebuilding the stock springs with linear springs both in load rating & comfort, I'm running a 6 leaf progressive now & don't like them at all, can't wait to build another linear pack for myself
  6. Dec 27, 2012 at 8:14 AM
    #1086
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    not even on the list WTH??? thats it back to the weazers...
  7. Dec 28, 2012 at 5:20 AM
    #1087
    SoCaltaco65
  8. Dec 28, 2012 at 8:37 AM
    #1088
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    A pair of leafs on the way. Gonna be on the list soon :D
  9. Dec 28, 2012 at 8:44 AM
    #1089
    Gregero
    Gregero TRD: Trail Ready Development
    Greg
    Carson City, NV
    Blue '06 Prerunner TRD Sport
    Debadged Tailgate, TOYOTA logo on Tailgate, Uniden Radio w/ 4' Ant., Removed Sway-Bar, Rear Icon Extended Travel Shocks, 8" King Offroad Shocks, Debadged Doors, 1.25" Rear AllPro Wheel Spacers, 315/70R17 Mickey Thompson Baja MTZs, AllPro Skid Plate, New Car Smell Air Freshener, OMD Ford&Chevy Leaf Pack with Original Main leaf, Engage LT UCAs and LCAs, Engage HD Tie Rod Ends, Kar-Tek Limit Straps, Camber Eliminator Kit, Removed Rear Flares, Blue LED Dome and Map lights, LED License plate lights, Black TRD Sport Rims, 20W PA Speaker, 2 Meter Radio, Demello-like Bed Bar, Harbor Freight Dust Lights, Blacked-out Hood Scoop, Custom Pre-Runner Bumper, JBA Long Tube Headers, MBRP Catback Exhaust, AFE Stage2 CAI, URD MAF Sensor Calibrator
    You've got nice tires, sir.
  10. Dec 28, 2012 at 12:29 PM
    #1090
    4WD
    Doug
    2004 DC TRD 4x
  11. Dec 28, 2012 at 3:08 PM
    #1091
    Blutus
    one of those cams would be mighty handy to see all the jiggling and woggling and jostling going on under my truck, especially since it won't be until Warm that I do the junkyard thing.
    Hmm..
    :spy:
  12. Dec 28, 2012 at 6:14 PM
    #1092
    4WD
    Doug
    2004 DC TRD 4x
    I assume you are entertaining the thought of doing this MOD, well
    you won't be disappointed & I'm here to help along the way if needed...:)
  13. Dec 28, 2012 at 6:36 PM
    #1093
    Blutus
    Thanks, Doug! :D Oh I am absolutely entertaining that thought! I'd be making my maiden voyage to the local junkyards now if it weren't so dang cold. I'm sure I'll be asking more questions once I get thawed out.
  14. Dec 28, 2012 at 7:11 PM
    #1094
    white toy taco
    white toy taco 505 Member
    Albuquerque, NM
    '06 OR and '02 OR (sold)
  15. Dec 29, 2012 at 6:46 AM
    #1095
    SoCaltaco65
  16. Dec 29, 2012 at 8:24 AM
    #1096
    SoCaltaco65
  17. Dec 29, 2012 at 8:38 AM
    #1097
    93civEJ1
    93civEJ1 Well-Known Member
    09 DC TRD OR
    Procomp 6" Stage 1, Bilstein 5100's in front, flowmaster 40 series
    I have a humdinger for you Doug. I have a 09 Tacoma Double Cab on a 6" lift currently. The kit is a procomp...so it came with a add a leaf (which didnt get put on and is still laying in the garage)..I didnt use it because I already had a Toytec AAL for TSB on the rear...so I just used the block that came with the kit for a total of 6" to be even with the front..ok, so here is where I have the puzzle for you...I have my old OME 885 springs I am going to put on the front of the truck, which I read will give about 2 more inches on the front....so I am guessing I will need to do the same to the rear....what would be the best way to go? Would it be good to just go ahead and throw in the procomp AAL as well..that looks identical to the toytec thats already in my TSB pack....or should I ditch lots of this and the blocks and build a 8" pack some how? or should I just say screw it and get a block that is two inches taller??
  18. Dec 29, 2012 at 9:03 AM
    #1098
    4WD
    Doug
    2004 DC TRD 4x
    I'd dump the blocks if possible, you need to find some nicely ARC'd springs off a SUA (spring under axle) probably 4 per side if just using the Toyota main leaf, that probably won't get you to 8" over but with some shackles , possibly . you could probably get by with a block if its no higher than 2", BTW how do you feel about nose bleeds ??
    j/k....:D
  19. Dec 29, 2012 at 9:08 AM
    #1099
    93civEJ1
    09 DC TRD OR
    Any thoughts on what a good spring under axle vehicle is for this? I cant remember right off if we touched anything in the shackle area when doing the procomp kit. btw...nose bleeds dont bother me. :)
  20. Dec 29, 2012 at 9:10 AM
    #1100
    SoCaltaco65
Thread Status:
