Tail light mod (both lights used as brake and signals)?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Chris.taco.2016, Jan 22, 2017.
  1. Dec 12, 2017 at 9:45 AM
    #261
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Just throwing this out there for the battery disconnect. We had some early problems with our Forester that disconnecting the negative terminal didn't fix. The recommendation was to disconnect both terminals completely and touch them together for several seconds. That fixed the problems (the useless-to-me-but-not-the-Wife hatch lift not working and something else that I can't remember).
    Definitely disconnect BOTH before touching them together. ;)
    ToyoDrew likes this.
  2. Dec 12, 2017 at 10:39 AM
    #262
    ratcityrain
    ratcityrain Well-Known Member
    Seattle, WA
    2017 Double Cab Off Road
    OEM Running boards |oemassive headlights | winjet tail lights | led lighting | hid headlight & fogs | oem tri-fold Bed cover | Custom dual JL Audio 10tw3-d4 sub box and custom amp rack | black off road wheels | painted oem grille | jbl door speakers |
    Just to make sure I do this correctly, I am looking at the diagram and on the outside of picture where it says harness, is that at the bulb socket side or the harness coming from truck side meaning the white wire from the T as T, does that go to the bulb socket or harness side?
    lastly, what have you done to seal the T as T module from the elements? I plan to solder all connections, heat shrink, e-tape and loom all wires
    Thanks.
  3. Dec 12, 2017 at 10:53 AM
    #263
    splashflash
    splashflash Vagabonding
    Art
    Timnath, CO
    17 DCSB 4x4 M/T Off-Road
    Black box can be referenced as the sockets. I used clear silicone especially after opening them to make sure the wires were soldered on right after my hiccup.
  4. Dec 12, 2017 at 10:55 AM
    #264
    ToyoDrew
    ToyoDrew Well-Known Member
    Texas
    17 Inferno TRD-OR DCSB 4x4 (SOLD)
    OVTune, Hertz spkrs & JBL MS-8 DSP, Turn-as-Tail mod, LEDs everywhere, MESOJDM Turn Signal, Bakflip Revolver X2, Pop-n-Lock, Yakima roof rack, & many minor mods
    Center of the diagram is the truck and the grey harnesses on the far right and left are harnesses that attach to the tail lights.
    I sealed the T as T with silicone and then wrapped everything with e-tape and loom.
  5. Dec 12, 2017 at 11:02 AM
    #265
    Camel89
    Camel89 Well-Known Member
    Houston, TX
    2016 TRD OR 4x4
    @mesojdm any updates on the plug and play kit?
    I really like the idea of having amber turn signals
    Frito, 02Duck and DPT852 like this.
  6. Dec 12, 2017 at 11:05 AM
    #266
    ratcityrain
    Seattle, WA
    Ultimately this is what I would want as well.
    Frito likes this.
  7. Dec 12, 2017 at 11:10 AM
    #267
    Age315
    Age315 Well-Known Member
    AJ
    Castle Rock, CO
    2016 BBP Yeti Mobile
    TRD Baja Kit with JBA UCA's 1/2 inch spacer on top, Medium Dakars with BAMF hangars and super bumps all around. 285/75/16 Cooper Discoverer AT3 XLT's on graphite TRD faux beadlock wheels. Pro skid powder coated black with Pelfreybilt aluminum mid skid and aluminum gas tank skid.
    So question on the resistors heating up. I figured they would get warm but didn't think they would get that hot. I double side sticky taped the resistor to the T as T then made sure the resistor wasn't touching anything else when I put it back together. Now I'm thinking about mounting it some where and lengthening the wires because I'm worried about how much heat it's going to put out. I noticed it got warm when I was testing it but didn't think it would get that hot. Does anyone know how hot they get?
  8. Dec 12, 2017 at 11:31 AM
    #268
    ratcityrain
    Seattle, WA
    I don't know how hot they get, but in my last truck I mounted it to the sheet metal behind the tail light and never had any issues, but I'm not sure mounting it to the plastic or back of tail light is sufficient enough
    Age315[QUOTED] likes this.
  9. Dec 12, 2017 at 12:57 PM
    #269
    Age315
    AJ
    Castle Rock, CO
    I'll be moving it to the sheet metal I won't have to worry about it. Thanks
    ratcityrain[QUOTED] likes this.
  10. Dec 12, 2017 at 1:20 PM
    #270
    cshrum
    cshrum Well-Known Member
    CO Springs, CO
    17 blue TRD sport DCLB
    I would say VERY:bananadead: hot. It depends on how long the turn signal was on (pushing current through the resistor), but well beyond too hot to touch with your bare hands after just a couple minutes. When mounting the resistor, mount it to a metal surface (not a painted surface...on either side!), using heat sink grease, and mate it to as smooth a surface as possible. The resistor is creating the heat, and needs it needs to be able to be drawn out of it. Double sided tape won't help the resistor disperse the heat that it is being subjected to.
    Mr-Paul and toyomaniac71 like this.
  11. Dec 12, 2017 at 5:52 PM
    #271
    toyomaniac71
    toyomaniac71 Well-Known Member
    Dave
    Colorado
    16 DCSB Sport
    Toytec 2.0 Boss 2" lift; Fuel Boost 18"; Nitto G2 275/65/18; BAMF Grille
    UPDATE. Disconnected battery terminals. Removed all LEDs. Stock bulbs back on.
    Everything works! Thanks for the help guys. Will slowly install LEDS. Probably hold off on TT module install til I get more info.
    Wiring pretty basic...
  12. Dec 12, 2017 at 8:13 PM
    #272
    toyomaniac71
    Dave
    Colorado
    16 DCSB Sport
    My son recently built a computer and remember he used some grease on the CPU fan as it gets warm. Same idea I assume. Seemed like there was more space behind the reverse light wiring so that’s where I was planning to place it
  13. Dec 12, 2017 at 9:03 PM
    #273
    OdiN1701
    OdiN1701 Well-Known Member
    Colorado
    2017 Quicksand TRD OR DC SB
    Sorta. The signals would not work at all with 6ohm resistor and the DD module IF the truck was on. None of his other odd problems though.
    ToyoDrew[QUOTED] likes this.
  14. Dec 17, 2017 at 11:21 AM
    #274
    toyomaniac71
    Dave
    Colorado
    16 DCSB Sport
    Not sure what happened first round with the brake pedal and accelerator pedal electronically engaged. Have not seen that again.
    I can get the module to work without the resistor. As soon as I put the resistor on, I also do not get any turn signal.
  15. Dec 17, 2017 at 11:25 AM
    #275
    toyomaniac71
    Dave
    Colorado
    16 DCSB Sport
    Sorry meant to post photo of module with resistor. DD told me I could ground one end of resistor to metal frame which I did ( and sanded down a little to remove paint to ensure good contact). 6874E993-C42B-4399-BCD8-182BED503211.jpg
    SilverII and cshrum like this.
  16. Dec 17, 2017 at 11:30 AM
    #276
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    In theory that resistor wiring looks correct
  17. Dec 17, 2017 at 12:47 PM
    #277
    toyomaniac71
    Dave
    Colorado
    16 DCSB Sport
    My conversation with Steve at DD has been very frustrating. He keeps telling me “IF” I connected to proper turn signal power ( yellow on driver side) then it should work. He can’t seem to confirm for me that the yellow is the correct wire. I can’t seem to get to next step of troubleshooting with him.
    Anyone know of where I can find official wiring diagram of tail lights so I can get him to stop saying “IF”?
  18. Dec 17, 2017 at 1:16 PM
    #278
    OdiN1701
    Colorado
    Sounds like my problem. I needed to add another resistor in series for MORE resistance. Find my posts above. 6 ohm wasn't enough. Strangely it would work without the resistor if the truck was in acc mode but not with the motor on. But not at all with the 6 ohm. Sounds odd, but I bet it is some sort of circuit protection.
  19. Dec 17, 2017 at 1:18 PM
    #279
    OdiN1701
    Colorado
    https://www.tacomaworld.com/threads/turn-signal-wiring-fixing-hyperflashing.501150/
  20. Dec 17, 2017 at 1:22 PM
    #280
    OdiN1701
    Colorado
    toyomaniac71[QUOTED] likes this.
