take off shudder goes away in 4WD
Discussion in 'Suspension' started by AllMountainToy, Jan 15, 2013.
  1. Jan 15, 2013 at 8:02 PM
    AllMountainToy
    AllMountainToy [OP] Well-Known Member
    Northern California
    2011 Tacoma Double Cab 4X4 TRDOR
    2 3/4 OME Suspension Lift with 885, with trim packer, 1/4" top plate spacer, swaybar relo bracket. Dakar leaf pack with 3rd leaf removed. 285/70/17" BFG AT. XD Wheels with 4.5 BS, Best Top Soft Top, Undercover winch mount with Warn 8k winch (with synthetic line), Pioneer touchscreen double din head unit. 4X innovations welded sliders. roof mounted DVD system.ATO dual battery tray with dual yellow tops. Rugged ridge isolator kit.
    All,
    I love the ride of the OME I installed and if you have been on the forum the last few days have probably seen a few posts by me due to issues I am having.
    Again...I just installed the OME 2.5" lift with .5" toytec spacer and trim packer as well as the Dakars on the rear.
    I have NOT taken it to get aligned yet because I am installing new UCA's this weekend.
    After installing I began to get a shudder at takeoff then would come and go quickly. I immediately assumed it was the rear driveline and ordered the CB drop and was planning on removing the 3rd leaf in the pack to drop the lift a bit.
    HOWEVER...tonight I put it in 4WD and did several stop and starts and there was no shudder!! What gives? I had read a thread some time ago but cannot find it.
    Can it be the alignment? I just had tires rotated during my 25k service. I am hoping it is the alignment.
    Any input would be great.
    Thanks
  2. Jan 15, 2013 at 8:05 PM
    3RZ Taco
    3RZ Taco Well-Known Member
    Austin
    Oregon
    96 3RZ Stock
    K&N air filter, Toolbox, Window Deflectors, Bug Deflector, BFGoodrich A/T's
    Maybe a dif. drop is needed? idk :/
    free bump
  3. Jan 15, 2013 at 8:11 PM
    GreatBasinTaco
    GreatBasinTaco Well-Known Member
    Reno, NV
    2020 Tundra DC
    Lots of stuff
    I wouldn't get too into it until everything is done. Then let the lift settle and get a few thousand miles on it before you go chasing minor vibrations and as mentioned try a diff drop if you didnt put one in.
  4. Jan 15, 2013 at 8:12 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Diff drop doesn't help any.
    Keep in mind in 4x4, torque to the rear axle is reduced by 50%, which means less force on the U-joint bearings and less axle wrap.
    What did you torque the rear leaf U-bolts to? Hope it wasn't 37 ft-lb...
  5. Jan 15, 2013 at 8:25 PM
    AllMountainToy
    Northern California
    I torqued to about 95 ft lbs. I am about 6lbs over the spec. Would that cause a problem?
  6. Jan 15, 2013 at 8:26 PM
    AllMountainToy
    Northern California
    I actually already have a diff drop on that 4WPs put on when they installed the Pro Comp 3 inch lift on the front that I replaced with the OME. Come to think of it...never had the shudder with the Pro Comp lift. BUT I also did not lift the rear only had the TSB.
  7. Jan 15, 2013 at 8:27 PM
    AllMountainToy
    Northern California
    Great suggestion by the way.
  8. Jan 15, 2013 at 8:36 PM
    KenLyns
    Belly of the Beast
    No. The U-bolt spec according to the service manual is in fact 37 ft-lb but appears to be a misprint. 95 ft-lb is fine.
    The diff drop is ineffective on 2nd gen Tacos, due to the diff carrier geometry. A 1" diff drop lowers the CV shaft by only about 1/2". Meanwhile your ground clearance is reduced by 1". And the diff carrier can get caught on obstacles off road, causing this to happen: http://www.tacomaworld.com/forum/2nd-gen-tacomas/118545-remove-differential-drop-your-05-tacoma.html
  9. Jan 15, 2013 at 8:38 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Get the UCA's in and alignment done , let the lift settle in a bit
    Then you need to start checking your driveline angles and correcting as required
  10. Jan 15, 2013 at 8:40 PM
    GreatBasinTaco
    Reno, NV
    2020 Tundra DC
    Lots of stuff
    my mistake. earlier post said diff drop, meant cb drop. don't do a diff drop as stated- worthless.
