The Epic Wy/Co meet picture thread!!
Discussion in 'Trip Reports' started by Blackdawg, Aug 4, 2013.
  1. Dec 16, 2013 at 8:44 PM
    #1161
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I have a slider in elements in the exposure tab (forget what its named) that pulls in the histogram from the right. In other words, it reduces highlights. I like to use it but if I go to far with that adjustment, objects surrounded by certain blue skies (depends on the angle of the light) will get a type of glowing edge. It is a white edge that comes out of the abject and seperates it from the blue sky. A very subtle "halo" effect.
    From the 1st time thru:
    From the 2nd time thru:
    Chromatic aberration (purple fringe) is from the lens, not from post processing. Altho post proc might make it more noticeable.
  2. Dec 16, 2013 at 9:41 PM
    #1162
    Digiratus
    Roaming the PNW
    The RedHead
    If it is a purple edge, then maybe the lens but if the edge is what I'm thinking about, it is not the lens, it is post proc.
    It is interesting how our 1st shots are quite similar and our 2nd shots are very different.
    I'd really like to see this (IMG_0760) pic on my setup. If you think about it, bring a copy of the raw (.cr2) file when you come over next month. It would be cool to play with when you are there so you can get a sense of comparo with your setup.
  3. Dec 18, 2013 at 8:23 PM
    #1163
    rileySB
    rileySB RileySB
    Gen
    Santa Barbara, CA
    13 DCSB OR 4x4
    5100/887, Dakars, 285s, Built Right UCAs, Icon rears
    Hey guys, any idea when the 2014 trip will be? I have to put in my vacation request soon for it!
  4. Dec 18, 2013 at 8:25 PM
    #1164
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    this is not an annual trip.
    and no. as far as i know we have no idea when or where we are going
  5. Dec 18, 2013 at 8:34 PM
    #1165
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yea man..not an annual thing :eek: sorry..
    that said though..i will probably make a feeler thread to see if anyone wants to come up and actually can in late july for some of these trails as they are so close to me.
    But won't be a big 2 week trip like this again.
  6. Dec 18, 2013 at 8:36 PM
    #1166
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    I'll definitely be hitting the Goose Lake trail again this coming summer. This time spending 2 or 3 days up near the lake or in that general area. Who's game?
  7. Dec 18, 2013 at 8:38 PM
    #1167
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    that is a very very long drive to spend some time by a lake...
  8. Dec 18, 2013 at 8:39 PM
    #1168
    Blackdawg
    Monte
    Wyoming/St. Louis
    Keep me posted man. You know i live right there so i'd be down most likely. Ill be going back there a few times this year probably.
  9. Dec 18, 2013 at 8:41 PM
    #1169
    Infra
    Az
    :thumbsup:
    I'll be up in Montana and Wyoming anyways again for about 7 or 8 weeks
    :D
    Will definitely keep you posted
  10. Dec 18, 2013 at 8:41 PM
    #1170
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    I'm down Jason! Be nice to spend more than one night in a spot and enjoy that area.
  11. Dec 18, 2013 at 8:43 PM
    #1171
    Blackdawg
    Monte
    Wyoming/St. Louis
    Haha...apparently this is an annual trip now...haha
  12. Dec 18, 2013 at 8:46 PM
    #1172
    SconnieHailer
    Marc
    Annual every weekend in the summer type thing! ha
  13. Dec 18, 2013 at 8:47 PM
    #1173
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well..for you and I :D haha
  14. Dec 18, 2013 at 8:48 PM
    #1174
    Infra
    Az
    Well I was very impressed with the Goose Lake area, very amazing and beautiful scenery! If this becomes an annual trip, then all the better!
  15. Dec 18, 2013 at 8:49 PM
    #1175
    Blackdawg
    Monte
    Wyoming/St. Louis
    You live in Laramie..haha
    wrong corner of the state :p
    or you gonna be in sheridan??
  16. Dec 18, 2013 at 8:50 PM
    #1176
    SconnieHailer
    Marc
    Yea the pictures you guys got of that area looked really inviting!
    Gage I guess you can come every weekend too, lol.
  17. Dec 18, 2013 at 8:53 PM
    #1177
    Blackdawg
    Monte
    Wyoming/St. Louis
    oh..well then you might not even be in Wy? haha wtf..haha
  18. Dec 18, 2013 at 8:57 PM
    #1178
    Blackdawg
    Monte
    Wyoming/St. Louis
    well cool. Im hoping to land a job with Weed and Pest so lots of Wy meets to be had :p
  19. Dec 18, 2013 at 9:13 PM
    #1179
    rileySB
    rileySB RileySB
    Gen
    Santa Barbara, CA
    13 DCSB OR 4x4
    Well bummer! I was getting my rig outfitted for some good dirt roading, sad I wasn't ready this past summer. I'm planning to head that way end of July for some dirt roads and to visit a friend in Bozeman. Maybe I'll just have to hit y'all up for some beta. Your pics in this thread leave me inspired and truthfully drooling. Will there possibly be a MT trip planned? Maybe not a three legged epic trip?
    For instance when is the best time to go visit southern Montana and northern Wyoming (Tetons)?
  20. Dec 18, 2013 at 9:18 PM
    #1180
    Blackdawg
    Monte
    Wyoming/St. Louis
    No idea about a MT trip either. Lisa does those..rather anally..but she makes meets. Usually has a few every summer.
    If you just let me know id be happy to try and meet you and do some of these trails.
    Wouldn't call them dirt roads..haha Goose Lake is rocky..and has one area that is a bit tricky but not horrible and has no by pass.
    Lander trails are NOT dirt roads..very rock..Shoshone is basically only rocks for a majority..haha
    But yea we could do something if your out this way, take you to the Big Horns too maybe.
    Just let us know. We have a Wy BS thread we all hand out in regularly and would be happy to try and work out the timing somehow.
    Wy BS thread: http://www.tacomaworld.com/forum/north-west/146555-wyoming-b-s-thread.html
    id also recommend check this out if your head to Bozeman : http://www.tacomaworld.com/forum/north-west/225261-magruder-lolo-motorway-bs-thread.html
    Those are dirt roads..but man..very fun and beautiful area. You could take on of the two from ID to MT or MT to ID..which ever. That was a fun trip too.
