The SKINNY on skinny tires
Discussion in 'Wheels & Tires' started by LadyRed, Jan 19, 2018.
  1. Apr 6, 2019 at 10:27 AM
    #1681
    Gnarman
    Gnarman Well-Known Member
    Southwest
    2016 dbcb trd off road quicksand lb
    ARB Shell, BP51, 255/85/16 ST MAXX, SCS Ray 10 Matte Bronze, Caliraised led 32 inch/side shooter/amber pods, floor mats, start x remote start, auxbeam 8 gang switch panel, diode dynamics hid lows, Australian Shepherd
    Is there a triple snowpeak rated 255/85/16?
  2. Apr 6, 2019 at 11:09 AM
    #1682
    bzzr2
    bzzr2 Well-Known Member
    Not that I am aware of or I would have them!
  3. Apr 6, 2019 at 11:39 AM
    #1683
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    I don’t know any either. Would be great if Cooper made the Discover AT3 4S in a 255 size. It’s a new flavor, so maybe someday. I sent them an email a couple weeks ago asking if they had any plans and just got the “maybe!” response haha
  4. Apr 6, 2019 at 11:41 AM
    #1684
    Gnarman
    Southwest
    Yeah that's the only thing holding me back. Other part is maybe I should just run 285/75/16 falkens and do cmc and trim I'm looking at 265/75/16 and the weight difference is only five lbs per tire more in e load. If I didn't live in Utah I wouldn't care haha!
  5. Apr 6, 2019 at 11:48 AM
    #1685
    bzzr2
    well.... i had initially picked up some at3w's in the 265 size because i wanted the winter rating, i was always somewhat disappointed in them, size-wise and performance was sub par in my opinion. they really don't compare to an actual true winter tire. i wouldn't recommend them to anybody that wants an actual tire that performs like a winter tire. like most things, nothing is great at all things, but kind of ok
  6. Apr 6, 2019 at 11:49 AM
    #1686
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    I hear you. I get away with the ST Maxxs here in Minnesota because I’ve got a set of snow tires for the winter.
    If 17” rims are a possibility, you could the the Cooper 4S tires in 285/70/17
    https://www.tirerack.com/tires/tire...eModel=Discoverer+AT3+4S&partnum=87TR7DA4SOWL
  7. Apr 6, 2019 at 11:50 AM
    #1687
    lojack
    lojack Well-Known Member
    Ahren
    South Shore, Wi
    19 DCSB OR CB
    I'm considering going with Discover AT3 4S in 245/75/16 next winter. I know it's not a tall skinny, but essentially the same diameter as stock and almost an inch narrower.
    CusterFan and doublethebass like this.
  8. Apr 6, 2019 at 11:51 AM
    #1688
    Gnarman
    Southwest
    doublethebass[QUOTED] likes this.
  9. Apr 6, 2019 at 6:25 PM
    #1689
    Kwik
    Kwik Well-Known Member
    Kyle
    Seattle
    2011 Tacoma 4x4 2.7L
    Forgive my ignorance but what is CMC? Thanks!
  10. Apr 6, 2019 at 6:31 PM
    #1690
    TRlPPlN
    TRlPPlN Pavement Cruiser
    Bay Area, CA South SF to be precise
    MGM DCSB 09 DC TRD Sport 4x4 - Family Hauler
    I believe CMC = Cab Mount Chop.
  11. Apr 7, 2019 at 8:27 AM
    #1691
    Kwik
    Kyle
    Seattle
    I can't decide between the 255 80 17 BFGoodrich KM2 weight 57lbs and the
    285 70 17C BFGoodrich KO2 51lbs. I want to go to skinny tires but it seems every option for the 17" wheel comes in E load range. In this case do you guys still think the skinnier tire would be a better choice for power/mpg than the lighter and wider 285 KO2? Thanks!
  12. Apr 7, 2019 at 8:35 AM
    #1692
    bzzr2
    I suggest just getting the ones you want most. The difference in fuel between the two tires you mention will be very insignificant if even existent.
    You also don’t need to get into the cmc with the skinny tires.
    Last thing is there are also options like the 34x10.5r17 ko2 if you’re concerned about a mud tire. Along with a couple other AT tires in the 255 size. Don’t let the 34 size intimidate either, they’re actually 33.5 tall which is the same as the Toyo MT I have on mine that fit great with no mods beyond my basic lift.
  13. Apr 7, 2019 at 6:10 PM
    #1693
    topaza
    topaza Well-Known Member
    2013 Black ACLB 4x4 V6
    34x10.5r17 KO2s. Shown here aired down a little. They measured 33 1/2 before mounting.
  14. Apr 7, 2019 at 6:32 PM
    #1694
    Taco15Bob
    Taco15Bob Member
    Bob
    2015 S5 4 door Prerunner
    None
    Large wide tires ruin steering systems, rake & pinion sets, power steering pumps. Think about it, the force
    required to turn large wide wheels on dry pavement. Mechanics secret is, never turn yours wheels sitting still.
    I'll take skinny tires and leave my money in my wallet.
    mallege and DevilTaco4 like this.
  15. Apr 10, 2019 at 8:24 PM
    #1695
    alexplb
    alexplb Well-Known Member
    I have the exact same size/tire on my 3rd gen and can't help but notice they really do wonder around a lot. I just can't seem to trust they won't come off if I take a turn at higher speeds on or off road... just seem too narrow. What pressure are you running yours at on and off road?
  16. Apr 10, 2019 at 8:39 PM
    #1696
    bzzr2
    Whatever, your tires aren’t gonna come off. Are you on some no name shit branded tires or junk yard crap?
  17. Apr 10, 2019 at 8:52 PM
    #1697
    alexplb
    lol did you read my post? I have the same Toyo tires as the guy that started this post. They are mounted on methods 16x8
  18. Apr 10, 2019 at 9:04 PM
    #1698
    bzzr2
    I have the Toyo’s also, had them on my Jeep also. They’re not gonna come off!
    LadyRed[OP] and alexplb[QUOTED] like this.
  19. Apr 11, 2019 at 10:22 AM
    #1699
    alexplb
    Did you make any sharp turns going 40-50 miles an hour
  20. Apr 11, 2019 at 10:45 AM
    #1700
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    I think you could spin the truck on an airplane runway at 70 mph and do a 1080 at speed and the tires wouldn't come off the bead. You're more likely to roll IMHO. That said when cornering you will notice the tire flexing more than a lower profile, wider tire.
    xxTacocaTxx and alexplb like this.
