The Torque Spec. Guide
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Benson X, Mar 1, 2014.
  1. May 23, 2018 at 12:46 PM
    #241
    Benson X
    Benson X [OP] My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    No problem! Thanks to @tcBob for letting me/us host it on his site and to the original Engineers/Authors who put it together...if you've looked at some other manufacturer's FSMs or a Haynes/Chiltons - you'll know how fortunate we are to have these awesome exploded diagrams and torque details.
    I still use it almost every time I work on my truck. I have memorized at least some of the torque specs after 7 years, though! :)
  2. May 23, 2018 at 12:59 PM
    #242
    la0d0g
    running for the hills
    For crawling not hauling
    26 ft lbs all day long!
    TacoTRD78 likes this.
  3. May 23, 2018 at 2:50 PM
    #243
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Follow those U-Bolt torque specs! :thumbsup:
    :p
  4. May 23, 2018 at 3:26 PM
    #244
    la0d0g
    Holy balls I'm late to the game and have never seen that! Cringe worthy for sure.
  5. May 23, 2018 at 3:28 PM
    #245
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
  6. May 27, 2018 at 4:15 PM
    #246
    Bravisimo
    Bravisimo So many mods, very little money.
    Joe
    Santa Clarita, CA
    2014 Tacoma PreRunner SR5 DCLB
    Tint, headlights wrapped & rear lights smoked, power outlet mod., grill & rear bumper wrapped, Falken A/T 3W,
    tried to find the torque spec for the bed. I took the bolts out and I hand cranked them down. Is it even on here?
    Also, trying to figure out on the diagrams what the numbers mean. Can someone explain. Im guessing thy are torque specs? If so, I dont now which number to use.
  7. May 27, 2018 at 4:37 PM
    #247
    Bravisimo
    Joe
    Santa Clarita, CA
    Yeah i think ur right @DoorDing on the bed bolts.
    For example, the filler plug has a 49,500, and 36 number. What do these numbers mean?
  8. May 27, 2018 at 4:43 PM
    #248
    mountainmonkey
    mountainmonkey Well-Known Member
    Colorado
    '13 Double Cab TRDOR DCSB
    Never enough
    Those numbers are all torque specs for that filler in different units. The legend is in the box at the lower left of that image. If you’re looking for ft lbs it’s the 2nd number in the parentheses.
    Bravisimo[QUOTED] and DoorDing like this.
  9. May 27, 2018 at 5:16 PM
    #249
    Bravisimo
    Joe
    Santa Clarita, CA
    Thanks @DoorDing ! I have applied anti seize compound already. And thank you for your help. Now i understand how to read the diagram.
    DoorDing likes this.
  10. Jun 27, 2018 at 1:56 PM
    #250
    Ma da tacos
    Ma da tacos Member
    Jay
    2013 Tacoma 4.0L
  11. Jul 6, 2018 at 7:46 PM
    #251
    05tacomabro
    05tacomabro will work for truck parts...
    Alex
    Tucson
    05 dcsb trd OR, 06 xrunner, 73 fj 40
    Icon ex. Travel co's, spc uca's, bamf lca skids, 1" body, all pro heavy duty sliders, expo springs, BAMF shackle hangers, 14" bilstein 7100, rear frame box, custom rear frame crossmember, ifs skid, transmission skid, t-case skid(modified by @jeepandrew for exhaust reroute and more beef), custom k&n intake, flowmaster, diff breather mod, stereo with nav/speakers/subs, coverking tactical ballistic seat covers, Baja utility rack, lots of bed liner, anytime fog mod and steel braided brake lines, energy suspension rad support bushings, abs kill switch, cali raised ditch lights, fsr rtt. Lots of plans, little money....
    @r@tb@st@rd
  12. Jul 17, 2018 at 1:38 PM
    #252
    Slamuel
    Slamuel Well-Known Member
    Sam
    Tacoma
    Can someone verify that the UCA thru-bolt is 85 lb*ft? I’m reading this correctly? Seems kind of high for that..
  13. Jul 17, 2018 at 1:48 PM
    #253
    BudMan
    BudMan knee scooters R us
    Bret
    Alameda, CA, (Bay Area)
    06 TRD Sport DC 4x4
    stuff
    Yes UCA through bolt is 85 ft/lbs :thumbsup:
    Speedo, Slamuel[QUOTED] and TACOVRD like this.
  14. Jul 31, 2018 at 10:42 AM
    #254
    taco_tallua
    taco_tallua MEGA-Known Member
    Anaheim, CA
    2016 MEGA Toyota Tacoma
    I'm here for the memes
    Would these numbers still be accurate for 3rd gens as well?
  15. Aug 31, 2018 at 11:51 AM
    #255
    Dlakerguy13
    Dlakerguy13 Well-Known Member
    So I replaced my rear shocks and used this guide for the proper torque specs. I could get the bottom bolts no problem. The top bolts, I couldn't get the torque wrench to fit due to the angle and location of where the bolts were. So I just used a regular combination wrench. On one side as I was tightening it, I hear a pop at one point. The nut didn't seem super tight at that moment. I am not sure if a washer cracked or what it was. But beyond that, everything in view seems fine and I was able to tighten the nut a bit more until it felt pretty snug. Any thoughts as to what the "pop" could have been?
  16. Aug 31, 2018 at 12:20 PM
    #256
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    One of the thin washers has a lip on the inside circumference that helps center everything on the frame mount. Maybe that was slightly off kilter and 'popped' into place?
    Dlakerguy13[QUOTED] likes this.
  17. Aug 31, 2018 at 12:21 PM
    #257
    Dlakerguy13
    I hope you're right! Thanks!
    xJuice[QUOTED] likes this.
  18. Sep 8, 2018 at 7:17 PM
    #258
    bradgarcia805
    bradgarcia805 Active Member
    Brad
    Southern California
    2014 Toyota Tacoma SR5 4x4 Access cab
    The best post that’s saved me many times! Thank you!
  19. Sep 9, 2018 at 1:31 PM
    #259
    2WD
    2WD Well-Known Member
    Pete
    2013 DCSB TRD Off-Road Pre-Runner Taco
    King 25001-119A, JBA HC and superbumps, EL095 leafs with longer overload leaf removed and 2 degree shim, Bilstein 5160 rears with fox roost shield on passenger side, King 2'' bump stops, B&M 70264 trans cooler, CSF FJ radiator, Leer Trilogy X2T bed cover, Scangauge, 34R AGM battery, weathertech floormats, Gold plug on the differential, fancy engine and diff oils, UNI air injection filter mod, Factory antenna chopped 4'', De-badged, Ram mount on A pillar, Cooper ST Maxx 265/75 R16.
    Great thread, I use it often.
    I had an alignment done 2 weeks ago after installing my front Kings. Ever since the alignment things felt aligned great, but clunky over any bumps. Sure enough, the LCA cam bolts/nuts, all 4, moved about 1/8 to 1/4 turn to hit the proper torque values. I'm guessing they were at 50-60 when they should have been at 100. Haven't driven much today but even going over my driveway curb things feel right again.
    Also double checked my lug nuts after Discount tire put on new tires this week. I always worry about them being over-torqued from some over-zealous 19 year old with an air impact and damaging my wheel studs. One guy in the waiting room said they broke his wheel stud which added even more worries. Checked mine today and they were right on torque value. Pretty happy with my local Discount Tire, seems well run.
  20. Sep 30, 2018 at 4:50 AM
    #260
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    Are the leaf spring u-bolts really only 37 ft lbs ??? That's gotta be a mistake.
