THEFT PREVENTION CATALYTIC CONVERTER
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WhiteHotTaco, Jun 27, 2018.
  1. Oct 21, 2021 at 1:56 PM
    #301
    TacoTuesday1
    SD CA
    not my truck but it is an RCI skid system
    if you mean that thing showing on the left; I'm not sure if other companies add wings to cover that
    I've heard some people add their own wings by welding them on.
    IDK if everything is compatible with each other. Like using a more front area skid from one company, and a different company farther rear; if the parts will interfere with each other bolting up properly
    Someone here mentioned aluminum.
    I heard the standard a skid should be is 1/4 steel
  2. Oct 21, 2021 at 2:23 PM
    #302
    Bishop4WD
    Bishop4WD Well-Known Member
    San Diego until I escape Communist California
    2019 MGM Off Road
    Yeah that "thing showing on the left" is one of the catalytic converters so it looks fairly accessible.
  3. Oct 22, 2021 at 7:03 PM
    #303
    jjrek9
    jjrek9 Well-Known Member
    will deff. be on the look out for this. Maybe make a thread for your products specifically
  4. Oct 25, 2021 at 12:20 PM
    #304
    FrayDoh
    FrayDoh Alfredo (The Sauce)
    Fredo
    Houston, TX
    2021 Voodoo TRD Offroad
    Icon Stage 4 - 2.5" lift Hood Struts - Redline Quick-lift Elite Interior Lighting - Diode Dynamics LEDs Diode Dynamics SS3 Fogs & Ditch Lights Diode Dynamics SS30 stealth amber bar Bed Cover - PACE EDWARDS ULTRAGROOVE METAL
    Agreed, I'll be keeping watch.
  5. Oct 25, 2021 at 2:01 PM
    #305
    TheSortaHawaiian
    TheSortaHawaiian Well-Known Member
    21 Lunar Rock TRD Pro
    @Talon2006 have you seen anyone install your cat plate so it sits on top on the TRD skid plate vs sandwiched?
  6. Oct 26, 2021 at 5:48 AM
    #306
    Talon2006
    Talon2006 Well-Known Member Vendor
    I guess I could make a specific thread. I actually reached out to the mods about becoming a official vendor on TW and 4Runners but was rejected.
    I have not seen anyone do this yet. Not sure how well it would work.
  7. Oct 26, 2021 at 6:08 AM
    #307
    Broadrunner
    Broadrunner Well-Known Member
    Hi @Talon2006. I currently have your cat protector installed with the TRD Pro skid plate. The cat protector is installed with it sandwich between the spacer and the TRD Pro skid plate. After the skid plate have been installed and all bolts are tightened, I get rattling now underneath the truck and I can hear it from the cab. It not really loud but it’s loud enough for me to hear it. I can’t seem to figure where the rattle is coming from. Have you heard of anyone else having the same issue?
  8. Oct 26, 2021 at 6:44 AM
    #308
    Talon2006
    I have not heard of anyone else having this issue. I assume you did a quick double check to make sure everything is tight?
  9. Oct 26, 2021 at 6:56 AM
    #309
    Broadrunner
    I did double check to make sure all bolts are tight and I double checked to see if anything is hitting anything that could possibly make a rattle noise
  10. Oct 26, 2021 at 6:56 AM
    #310
    19cement4xor
    19cement4xor Well-Known Member
    Eric
    Clear Lake TX
    19 Cement Trd off road 4x4
    TRD Pro suspension, Method Nv, 265/70-17 bfg ko2, meso TRD center caps
    check the side wings to see if they are contacting the trans brace if so adjust so they don’t.
  11. Oct 26, 2021 at 7:15 AM
    #311
    19cement4xor
    Eric
    Clear Lake TX
    Is it possible that something fell and is sitting on top of the cat plate or the TRD skid? When I did the ones on my wife’s TRD pro 4Runner I had a rattle and it was a rock in the skid.
  12. Oct 26, 2021 at 7:22 AM
    #312
    Broadrunner
    That is possible. After work today I will inspect to see if there is a rock sitting on top of both plates
  13. Nov 2, 2021 at 6:26 AM
    #313
    19cement4xor
    Eric
    Clear Lake TX
    Did you find a cause?
  14. Nov 2, 2021 at 6:28 AM
    #314
    Talon2006
    X2, I’m super curious what it is.
  15. Nov 2, 2021 at 7:31 PM
    #315
    jjrek9
    I see a vendor badge on your name now, congrats.
  16. Nov 5, 2021 at 4:43 AM
    #316
    19cement4xor
    Eric
    Clear Lake TX
  17. Apr 17, 2022 at 5:26 PM
    #317
    asualumni
    asualumni New Member
    Luis
    '22 Tacoma SR 4WD
    @Talon2006
    Can your product be used on a 2022 Tacoma 4x4 with an ARB Rear Driveshaft spacer installed?
  18. Apr 19, 2022 at 3:49 PM
    #318
    asualumni
    Luis
    '22 Tacoma SR 4WD
  19. Apr 19, 2022 at 3:59 PM
    #319
    venezian
    venezian Well-Known Member
    Los Angeles
    2022 7545E
    Well shit, here I was trying to figure out what plate would work with your shield...
    Group buy? :D
  20. Apr 19, 2022 at 3:59 PM
    #320
    usna92
    usna92 Well-Known Member
    Jim
    PNW
    2022 MGM TRD Off Road DCSB
    Glare blockers, Dash Cam, TRD Lift, Skid Plate, Bed Step, TRD Grill (with Lift) CatSecurity Cat Shield, Snail Armor Tailgate Plate
    I went with CatSecurity on mine because our dealership is an installer in WA for them. We had attempted cat theft on our Highlander Hybrid (all they managed to do with the chop saw was $5K in damage to the bottom of the car, but left the cats) parked right next to our house. We live in suburbia, so it was $300 insurance and no loss of time so they go look for easier marks. The HiHy stays in our garage now when not in use because no one makes a protector for a 10 y/o highlander.
