Throttle position sensor 89452-35030
Discussion in '1st Gen. Tacomas (1995-2004)' started by thumpertx, Sep 4, 2018.
  1. Sep 4, 2018 at 5:42 PM
    thumpertx
    thumpertx [OP] Well-Known Member
    2003 silver TRD4X4, 2017 quicksand TRD 4X4
    Has anyone been able to find a throttle position sensor for a 03 Taco? The dealer says they can not get the part #89452-35030 and I think it also fits 01 and 02 models. [6cyl]
  2. Sep 4, 2018 at 6:07 PM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
  3. Sep 4, 2018 at 6:33 PM
    thumpertx
    dirty_lickings likes this.
  4. Sep 4, 2018 at 7:00 PM
    hubcapsc
    hubcapsc Un-Known Stranger
    Upstate South Carolina
    2002 6cyl 4x4 manual
  5. Sep 4, 2018 at 7:51 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
  6. Sep 4, 2018 at 8:32 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    So just for reference, I ordered P/N 89452-35020 for my 2002 back in May from Camelback Toyota. Price at the time was 52.33. It's still sitting in my parts box (lol) waiting to be installed. OP, I'd check-in with @gunny1005 and see what he recommends... might be able to track down what you need.
  7. Sep 4, 2018 at 10:51 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    xxxxx-35020 is a three pin TPS & xxxxx-35030 is a four pin, p/n's aren't compatible between these two throttle bodies (non/ects-i=35020 & etcs-i=35030). A three pin can be bought relativity easy, the four pin; at my last checking involves replacing the complete throttle body because knowone supplies that individual part.
    jammer likes this.
  8. Sep 5, 2018 at 9:49 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Nope been elusive part to find. I even tried to get Denso to make them available and Beck Arnley to make them. Tried buying overseas, all a dead end. 2003-2004 have the electronic throttle bodies and the TPS sensor 89452-35030 is not sold separately from the throttle body. A used one or new from Toyota. Toyota has come down in price a lot. They used to be over $1000 now they're around $600.
    Wyoming09 and jammer like this.
  9. Sep 7, 2018 at 4:49 PM
    thumpertx
    Dealer ran my vin through the system and says my truck has PNXXXXX-35020 sensor but it does not, it has xxxxx-35030. They called yoda distribution and were told that some 03 tacos had 35030 sensors but most had 35020. If you get the replacement throttle body it comes with 35030 sensor [if you order that verson] so that means Toyota has the part, they just will not sell it without the expensive throttle body [$800 my dealer said]
  10. Sep 7, 2018 at 5:04 PM
    License2Ill
    Ian
    It's actually, in reality, the other way around. Very, very few 03's had the 35020. And very, very few 02's had the 35030.
    Don't know if this is true, but it seems accurate because Toyota doesn't stock the 35030 TPS, because according to Toyota the 35030 TPS needs to be calibrated along with the APPS at the factory, on the throttle body.
    Of course that doesn't justify the fact, that a new 35030 TPS can be installed on a existing TB and "clocked" to adjustment given the diagnosis listed in the FSM.
  11. Sep 9, 2018 at 6:00 AM
    thumpertx
    I have not heard that the 35030 sensor needs to be calibrated anywhere else. Do you have anything from Toyota that states this? If that is true then it seems that individuals who got their replacement part from a junk yard would have had issues. It would also seem odd that Toyota would make this one sensor model that needs calibration.
  12. Sep 9, 2018 at 11:51 AM
    License2Ill
    Ian
    No. That's why I stated "not sure if true or not". But I've read it a few times throughout the years on multiple forums... I no longer have those sources conveniently available to quote, sorry.
    Maybe it's all hearsay. But it makes sense if Toyota doesn't stock that part. Because it's obviously a completely separable part from the TB. Maybe it's to avoid liability. Toyota has a bad track record regarding their computer controlled throttle.
    Since Toyota is known to repeatedly use a single part on a large variety of models & years. I'd be interesting to see what other drive-by-wire 4 pin TPS' that are out there and maybe they even have a different part number...
  13. Sep 9, 2018 at 1:52 PM
    Pauhana
    Pauhana Well-Known Member
    Mark
    Irvine, CA
    04 SC PreRunner
    RECARO Trend Seats TRD SC URD Fuel Upgrades
    I have an 04. Mine started acting up. I ended up getting a used TB from the parts dismantler. No other options I could find. Dealer wanted $1000+. I even checked overseas with all of the China manufacturers whom said they had it but didn't. I got a 30 day warranty and it worked. Just my experience.
  14. Sep 9, 2018 at 6:05 PM
    cleonard
    cleonard Active Member
    Santa Clarita, CA
    2003 extra cab 3.4L 4x4
    Darn I have one of these 4 wire TPS that appear to be unobtanium. I've had bad luck with these failing on me in the past.
    There are other contemporary Toyota TPS that have 4 wires. The first I found is the 89452-30150 is 4 wire and looks like it could be a physical fit. The mounting holes are slots so it will need calibration most likely. I'll look into others.
    Really it just needs to fit mechanically and be electrically equivalent. Time to break out the ohm meter...
    It's a dual sensor due to the fly by wire throttle. I image it is a safety thing so the throttle servo does not end up applying too much throttle. Probably a good idea due to the Lexus runaway problems from the past. I'd guess you could take a regular three wire and just connect the two sensor wires together. Should that fail it might be a little exciting.
    89452-30150 fits
    Lexus
    ES300 2002-2003
    GS300 1998-2004
    GS400 1998-2000
    GS430 2001-2004
    IS300 2001-2005
    LS400 1998-2000
    LS430 2001-2003
    LX470 1998-2002
    SC300 1998-2000
    SC400 1998-1998
    SC430 2002-2005
    Toyota
    Camry 2002-2003
    Land Cruiser 1998-2002
    MR2 Spyder 2001-2005
    Prius 2001-2003
    Sequoia 2001-2004
    Supra 1998-1998
    Tundra 2000-2002
    License2Ill likes this.
  15. Sep 9, 2018 at 10:14 PM
    License2Ill
    Ian
    Have you given this a read?:
    https://www.tacomaworld.com/threads/2003-04-tacoma-tps.334363/
    @mechanicjon is our 1st Gen 4 pin TPS sleuthing paragon.
    mechanicjon and Area51Runner like this.
  16. Sep 9, 2018 at 11:24 PM
    cleonard
    Santa Clarita, CA
    I have and several other on other forums. The picture from the first page of that threas shows the inside face and the 30150 is not a match. However, another 4 pin TPS with number 89452-22080 appears to be the same mechanically. Is it an electrical match? I'm thinking not after looking at the wiring diagrams of vehicles that use it.
    There are some others like from the Lexus 3.5L used in 04 and 05 that look to be electrically compatible, but the mechanical interface is different like the 30150.
    License2Ill[QUOTED] likes this.
  17. Sep 9, 2018 at 11:48 PM
    License2Ill
    Ian
    Sorry, I'm not up do date on all the TPS differentials.
    What do you mean by "mechanical interface"? I'm guessing that's a reference to how the mechanical part of the throttle body linkage intercepts/ engages the linkage/coupling in the TPS sensor?
    Just curious. What basically is different between the two (ie the 35030 & 30150)?
  18. Sep 9, 2018 at 11:56 PM
    cleonard
    Santa Clarita, CA
    Exactly, I'm not sure. The plastic pieces where the throttle body turns the sensor are different. Enough different that they probably will not work.
    It's pretty important that this is right. Wrong could end up with uncommanded full throttle.
  19. Sep 10, 2018 at 4:55 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Clockwise or counter clockwise turn
  20. Sep 10, 2018 at 8:45 AM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    CS_AR likes this.
