Thud thunk lunge lurch, stopping started, axle wrap SOLVED.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lj973gm, Jul 22, 2012.
  1. Oct 25, 2012 at 1:59 PM
    #41
    Toy Yoda
    Toy Yoda gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
    can you elaborate on your experience with the pro comp bar? I'm curious as to why more people don't use traction bars, they seem like one of the best solutions just by looking at the basic concept of how they work
  2. Oct 25, 2012 at 4:02 PM
    #42
    ThreeMan
    ThreeMan Opinions Vary...
    Oswego, NY
    08 4x4 V6 TRD DCLB
    King Remote Resi Suspension - Total Chaos UCAs - Full Katzkin Leather - Leer Camper Shell - Custom Projector Halo Headlights - HID Fogs - Eagle Eye LED tail lights - Rigid Industries LED Light Bar Mounted in Bumper - Wade In-channel Vent Visors - K&N Filter - 20% on the fronts - Dakar Progressive Leafs - Fuel Beast Wheels wrapped in Hankook Dynapro ATMs - 4 Tie Down Mod - Pop N Lock - Billet Grille - Weathertech Mats - LED Map and Dome Lights - Optima Yellow Top - Redline Elite Hood Struts - Tunes: Eclipse 7100 HU - Eclipse IPC-106 Interface - Audison LRX 5.1K - Hertz Mille MLK2 Components - JL 13TW5 - JL cables and wires - Fully Deadened with SDS products - Metra dash kit - Custom Sub Box and Amp Rack - Still Under Construction.
    Where and how much for the axel? Did you install yourself? Pics?
  3. Oct 25, 2012 at 4:17 PM
    #43
    TRDBeast
    TRDBeast Boogie Man Kryptonite
    Wayne
    Coconut Creek, FL
    08 Tacoma Crew Cab TRD
    Brute Force front armor with 30" rigid and dual 4" quad rigid fogs OME suspension 3" lift with Dakar leaf pack and ToyTec body lift for total 4.25 LR UCA's 9000 sport Nitro Charger shocks 885X Coils AFE Pro Dry CAI 18" Rockstars Alpine DDIN systemw/Nav, Bluetooth and DVD 2 12's Infinity Kappa's in doors and Alpine 6.5 X 9 in front and back and 2 Alpine Zeus amps rear 2 Rockford Fosgate amps front NFab running boards Dyno tuned FXRs w/ 3" Projectors and Halos retrofit w/ Apollo shrouds and 5000k HID 55W Debadged Wet Okole skins HomerTaco Satoshi grill Elusive Elements light support with 2 Hella 500ff's behind grill Powder coated tool box TRD gear shift Andres Devil Horns TREX eyelids Body Armor rear bumper 15% Tint "ZOMBIE" light switches Custom gun concealer in dash One-piece aluminum drive shaft LED interior light swap
    The pro comp bar looked cheesey and too light. also it didnt line up properly and I was told by the shop guys that because I have Dakars in the rear it wouldnt fit without modification. they ended up trying to mod it themselves and it was a disaster- still didnt fit. I would highly suggest to anyone wanting a traction bar to buy a budbuilt. not only do they have the best ratings on the forum, but bud himself knows his stuff, will talk to you personally and is super nice and helpful!
    now the explanation I got from him was a traction bar will immediately fix the axle wrap but not fully prevent it from happening- only mask it.
    a 1 piece shaft seems to be the only "perfect" cure
  4. Oct 25, 2012 at 6:52 PM
    #44
    lj973gm
    lj973gm [OP] Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    So did you measure your angles throughout the drivetrain or just toss the shims in at different degrees?
    Did you ever grease the yoke yourself?
    A one piece shaft is not curing any axle wrap it would be a part to mask it. A traction bar is the product to actually stop axle wrap.
    As for the new driveshaft what joint setup does it have? Common u-joint, cardon/ double?
    Glad to hear you solved your problem in the end. Need to elaborate a bit more.
  5. Oct 25, 2012 at 8:59 PM
    #45
    TRDBeast
    Wayne
    Coconut Creek, FL
    well im not tech savy but heres what the shop tried first:
    they tried shims beginning at 2 degress and ended at 4 degrees. there they said the angle was perfect. the acceleration shutter was somewhat better but still there.
    greased the slip yolk and the thud was gone but thats what happened last time- it came back.
    i spoke with bud at budbuilt about the traction bar and he suggested shimming the carrier lower as well as grease the slip yolk. he also said the one piece shaft would be the cure all.
    the drive shaft they made for me is aluminum 1 piece std u joint. I had heard about the double cardon and spoke with the folks at tom woods first. they said double cardon usually suggested on shorter shafts like a jeep but aluminum on tacomas especially being mine is a 2wd.
    so far the shudder is completely eliminated and I havent noticed a slip yolk problem since... fingers crossed
  6. Feb 6, 2013 at 5:10 AM
    #46
    Erik
    Erik That smells like pure gasoline
    Erik
    Nashua, NH
    10'TRD off-road
    Shrockworks bumper+ IFS skid, 4xInnovations rock sliders, Toytec Bilstein/Eibach 5100 @ 2.5", 3" All-pro leaf pack w/Bilstein 5100, PIAA 510SMR, PIAA 1500, Python LC3 2-way Auto-start, Fog lights on w/Parking lights, ATRAC Hack, Diff breather mod
    I tried to do this yesterday before I found this thread. I didn't know to take off the clamps. I just unbolted the four bolts on the rear diff and expected the shaft to drop down and come off. I tried to kick it loose with no result. I removed the 2 bolts on the carrier bearing to get some more play, but still didn't budge. I tried tapping the bracket with a hammer, but decided to do more research before I take a hammer to anything.
    I thought the rear piece was supposed to slide forward and drop down is this not correct? Mine wasn't sliding forward.
    When I removed the carrier bearing bolts I noticed the slip yolk flexing as I lowered the shaft.
    If I remove the clamps on the rubber and remove the carrier bearing bolts, will the slip yolk come out when I lower it without dropping the rear end of the shaft?
    I was hoping to find some pics that were specific to 05+ tacomas.
  7. Mar 12, 2013 at 8:28 PM
    #47
    9civichatch3
    9civichatch3 Well-Known Member
    Bama
    08 PreRunner FoDo
    K&N Drop-In, 10% Window Tint, 265/70/16 General Grabber AT2, iPhone Interface, TRD Bilsteins, ToyTec 3/4" Top Plate Spacer Kit, ToyTec 1" Blocks
    I am having a thud at start as well. I have a 2wd Pre-Runner and do no think I have a slip yoke. Am I overlooking it ??
  8. Mar 19, 2013 at 2:03 PM
    #48
    TRDBeast
    Wayne
    Coconut Creek, FL
    yes
    u still have a slip yolk...
  9. Mar 19, 2013 at 2:16 PM
    #49
    Large
    Large Red
    Running a 1 piece and still have a shudder.
  10. Mar 19, 2013 at 2:29 PM
    #50
    Large
    Large Red
    More of a thud but yes.
  11. Mar 22, 2013 at 2:47 PM
    #51
    TRDBeast
    Wayne
    Coconut Creek, FL
    the shudder is known as " the shudder of death" lol
    its a known problem when going 3+ INCHES. its the angle of pinion/driveshaft/ carrier drop........ a 4x4 easy fix is a traction bar. a 2x2 driveshaft is the only solution i have heard of
  12. Jun 9, 2013 at 12:26 PM
    #52
    lj973gm
    Ohio
    06 DCSB 4wd
    So the lunging and surge when coming to a stop and starting to accelerate started to rear its face again last week.
    So it lasted almost a years worth of driving. I am not exactly sure but I would say between 10-15K of miles before having to regrease the splines again.
    I pulled it apart today and the grease that was in there was breaking down and thinner than when originally applied.
    Regreased and took it for a spin with no signs lunging and surging from stops. Shudder on my truck is on and off depending on how fast or slow I take off but you have to try and notice it. Only about 10mph is where it can be felt if it happens.
    Crom likes this.
  13. Jun 18, 2013 at 4:19 PM
    #53
    ryanweinstein
    ryanweinstein Well-Known Member
    Moorpark
    07 prerunner long bed double cab
    Sway-A-Way 2.0 Coilovers, Fox 2.0 piggy back Resi rear shocks, Glassworks front fenders and rear bedsides, custom front bumper and skid plate, N-Fab in bed tire carrier, Nitto Terra Grappler 285/85/17, 3" wheel spacers on the front, AFE stage II sealed CAI, Kenwood 6.5' touch screen DVD player, Alpine type R 10" sub, Sony 1000w amp, custom sub box ported.
    I have been having a little kick when i come to a complete stop as well. I have taken it to a transmission shop because I noticed it was leaking fluid from where the front yoke enters the transmission. They said that the bushing inside where the front yoke goes in is natorious for going bad. I'm going to try and replace it and grease the front slip yoke as well as the entire shaft as well. Has anyone found any posts about walking through greasing the drive shafts with pictures?
  14. Oct 21, 2013 at 7:17 PM
    #54
    dalesrn
    dalesrn Tacoma TSS
    Dale
    Southeast Louisiana
    2008 Tacoma PreRunner DC with TSS Package
    Borla exhaust system, Sirius Satellite Radio, Chrome package, Trailer Hitch, Clazzio Leather seat covers, TSS badging, Anytime on fog lights mod, Daytime driving lights mod, Dual backseat DVD players w/monitors, 3rd Brake Light "TSS" mod, Bed pocket lights mod, Seat belt chime mod, Bed storage compartment auxillary outlet mod, Shorty antenna, Armor Lid Tonneau Cover, Line of Fire tailgate light
    I think I have the same problem, but could this be possible with a 2WD? If so, could someone post pics of the joints I need to disassemble and grease?
  15. Nov 13, 2013 at 10:00 AM
    #55
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Good to know. Thanks for reporting back the service interval for your truck... :thumbsup:
    http://www.tacomaworld.com/forum/te...ntire-drive-shaft-u-joints-5-zerks-total.html
  16. Nov 17, 2013 at 10:15 AM
    #56
    dbbyleo
    dbbyleo Member
    I've been having this clunk noise issue since the summer. And I think it's been there much longer, just not as loud so I didn't hear. But since the summer, I can both hear it and feel it.
    I'm learning here that (correct me if I'm wrong), the noise if from the slip yoke binding. And that binding is or can likely the result of axel wrap. There will always be some degree of axel wrap, whether you have aftermarket leafs or not, so a better or more complete remedy is to make sure the slip yoke is greased well. Re-greasing of the slip yoke may/will be required again when the binding re-occurs. Despite what measures you take, including greasing the slip yoke will result in a more lasting remedy.
    Is that about right?
    Before all this, I read the u-bolts could be the culprit because the manufacturer may not have torque the bolts enough (only 37#). From what I've read, it appears this u-bolt thing simply adds to the axel wrap problem with leads to slip yoke binding. So tightening the u-bolts may or may not help... or may remedy it, but only for a short while.
    Did I get that right, too?
    Anyway... I finally got under there this weekend. It was easy enough to tighten the bolts and I tightened to 73# (as I've read in this forum as well as others). Right away, this made the clunk go away. I'm not so optimistic it will stay that way based on what I've read here, though, so I'll still make plans for doing the slip yoke. I'll post back to update on my progress... ie how it takes for the clunk to return after just tightening the ubolts.
    Anyway, thanks so much for the valuable info in this thread. I'm starting to "wrap" my head around this issue :)
    Here's another thing... I recently installed air suspension on the rear axel (Air Lift). I started pulling a pop-up (this summer) and wanted to correct the ride. I knew the rear springs were weak and was contributing to the slip yoke binding. But I thought having pressure in the air bags constantly (even without the pop-up) would be more or less equivalent on having AAL. But that still didn't fix the "clunk". Just curious on your thoughts on that.
  17. Nov 17, 2013 at 10:41 AM
    #57
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Mine cured with an allpro leaf pack. The stock springs with aal were driving me crazy.
  18. Nov 17, 2013 at 12:03 PM
    #58
    lj973gm
    Ohio
    06 DCSB 4wd
    No issues yet since I greased it last time I reported back.
    Just a part of maintenance on a truck with a slip yoke. Every truck I have owned has had this issue after the miles started racking up. Tahoe, sierra, silverado, tacoma and a J-10.
    Proper grease and a little work seems to do the trick.
    Same issue if you are 2wd or 4wd both have a slip yoke.
    If you have a shudder it is also likely a driveline angle concern. The greasing of the slip yoke is mainly for the thunk, lurch and lunge effect.
    It is a whole big picture of leaf springs wearing out, driveline angles/driveshaft style and slip yoke wear.
    Crom likes this.
  19. Nov 17, 2013 at 12:48 PM
    #59
    dbbyleo
    dbbyleo Member
    Tighten bolts didnt help at all. I don't know it seemed like it went away when I test drove it. I was punching the gas from stop and couldn't get it to clunk. Then I gave the Taco a wash. After the wash... there it was again. Who knows, but at least now I know my u bolts are tightened, at least above 37#.
    I will be planning on the slip yoke next weekend.
  20. Dec 14, 2013 at 10:59 PM
    #60
    jathomas437
    jathomas437 Well-Known Member
    Angleton, TX
    1999 Tacoma SR5 Xtracab V6 4x4
    Subscribed. Mine has the thud and I plan to grease the slip yoke. Thanks for all the info.
