Thump?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mmelaney, Dec 29, 2010.
  1. Dec 29, 2010 at 6:38 AM
    Mmelaney
    Mmelaney [OP] Well-Known Member
    Waynesboro, GA
    2016 TRD Sport DCLB
    So.... The other day I'm driving down the road and I come to a stop light. Of course I stop.... When I started back moving I accelerated as normal (not rapid accel). At about 10 mph, maybe 15 feet from the start I hear a "thump" like something shifting in the bed of my truck. Problem is there's nothing in the bed. I dismiss it as just a bump in the road and go on.
    Now it seems I'm hypersensitive to every noise and I keep hearing it. A couple times I can even feel a bump like a keg rolling around in the trunk of a car (familiar feeling from my past).
    Anyone know what this might be? Should I be concerned? It's a brand new 2011 DC TRD Sport.
  2. Dec 29, 2010 at 6:41 AM
    danteisme
    danteisme Well-Known Member
    Vandergrift, PA
    06 DCSB Sport, 96 Integra GSR
    maybe axle wrap? but i dont think it would be THAT noticeable.
  3. Dec 29, 2010 at 6:49 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Sometimes when I have something in storage compartments under or behind the seats they make a really loud thump, particularly when I put my hitch ball mount in there.
    hitch ball mount: I'm sure this is the wrong technical term
  4. Dec 29, 2010 at 6:58 AM
    Mmelaney
    Waynesboro, GA
    2016 TRD Sport DCLB
    I checked that. Everything is secure. (fire ext. Is all I got back there and it's strapped tight. )
  5. Dec 29, 2010 at 7:06 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Do a search on old threads. You'll find a ton of people complaining about this over in the past. There were two causes: Axle wrap and fuel in the fuel tank (this was the more common cause when the tank wasn't full).
  6. Dec 29, 2010 at 7:09 AM
    Mmelaney
    Waynesboro, GA
    2016 TRD Sport DCLB
    Ahhhhh..... I have had a half tank for a few days now. That makes sense.
    Because I'm not a gearhead can someone define axel wrap?
  7. Dec 29, 2010 at 7:12 AM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    Well apparently I was way off.
  8. Dec 29, 2010 at 7:14 AM
    05Moose
    Jim
  9. Dec 29, 2010 at 7:29 AM
    Mmelaney
    Waynesboro, GA
    2016 TRD Sport DCLB
    Actually you weren't way off. I actually had a similar noise when I first put all my stuff in the truck. That's why the fire ext. Is secured now. When I heard the noise the first time that was the first thing I checked.
    I did some reading on axle (axel) wrap in the forums. That definitely sounds like the ticket. I wouldn't have expected something like that on a 3 week old vehicle with 1700 miles on it though.
    My third and final question: If it's just annoying, is it eventually going to cause a problem?
    By the way, thank you. You guys have been great.
  10. Dec 29, 2010 at 7:57 AM
    05Moose
    Jim
    In the case of the Tacoma and axle wrap, it just seems to be the way it is with the softer springs (it pretty much goes away if you have the rear spring TSB done). But I'm betting it's your fuel tank. Either way, nothing to be worried about short term or long term. The "Thump" question used to come up a lot on the various forums. Not so much anymore as the 2nd Gen has been around for so many years now. We don't get into the long discussions on axle wrap, fuel tank thumps, and drivetrain slack (the delay when you leave that red light).
  11. Dec 29, 2010 at 8:15 AM
    Mmelaney
    Waynesboro, GA
    2016 TRD Sport DCLB
    Thanks Moose. I'm a Tacoma newb so this is virgin territory for me. I do appreciate the info.
