tie downs up front
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jimiola, Aug 3, 2008.
  1. Aug 3, 2008 at 9:54 PM
    jimiola
    jimiola [OP] Member
    07 prerunner
    anyone ever install tie downs like the factory ones in the rear of the bed to the two bed bolts up front near the cab?
    are those bolts screwed to the frame or is there a nut under there? I need to haul a motorcycle and I don't trust those plastic side tie downs. :help: Thanks
  2. Aug 3, 2008 at 10:24 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    The bolt comes out like the other ones no nut on the bottom the only dont fall you will have to cut the washer off, i have extra d-rings in my truck.
  3. Aug 4, 2008 at 6:16 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    The ones in the front go into the frame. The only thing that I don't like is that the rings won't spin around if you install them there.
    I'd install some other d-rings with a large backer plate.
    You're right to not trust those rings. I think they're only rated for 125#.
  4. Aug 4, 2008 at 7:29 AM
    4x4x4trd
    4x4x4trd My other ride weighs 200 tons
    North Texas
    08 White Access Cab TRD OR, Debadged
    AFE oil free drop in, Secondary removed, tint, front D-rings, Toyota bed mat, Undercover tonneau, TRD seat covers and floor mats, Pioneer speakers, Westin Platinum bars, Fumoto oil valve, short antena, Nifty Xtreme's, TSB leaf springs, Bilstein 5100's set at .85" in the front
    I installed the factory ones on the vertical sides as the instructions show as I didn't want to cut my bed mat to make them work. I wouldn't trust the bed rail system to hold a bike just with straps to the tie downs either. There are some products that are like wheel chocks that mount to the rail system that seem to work. Do a search on here and you ought to find them.
    Here's the link from this sight.
    http://www.tacomaworld.com/forum/technical-chat/4838-cheap-free-mods.html
    I ordered the factory ones when the dealer sent me a coupon book for 20% off. Here's some factory ones.
    http://toyotapartspeople.com/Search...70021&year=08&productdesc=D-Rings+-+Tie+Downs
  5. Aug 4, 2008 at 9:17 AM
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    FYI, rated for 200#
