Tips and Tricks on the 3rd Gen Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AAChaoshand, Jan 22, 2016.
  1. Oct 30, 2020 at 6:33 AM
    #3221
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    We recently bought a 2020 Armada that has remote start. After starting the vehicle remotely, if you get in and put it in Drive the engine kills.
    But after starting remotely, if you get in and step on the brake and press the Start button the vehicle will remain running when you put it in Drive.
    9mmMike likes this.
  2. Oct 30, 2020 at 9:00 AM
    #3222
    barnes828
    barnes828 Well-Known Member
    Nathan
    Vancouver, Wa
    21’ DCLB OR WHITE
    Just adding to the CCW conversation, but I prefer to just keep my gun on me at all times. I carry appendix in an T1C Axis Elite and for me and the situations I can see happening this is best. My draw stays the same, if I need to exit the vehicle I can do so quickly, and it’s always concealed just to name a few reasons.
    kbow12A, BadDad69! and Boghog1 like this.
  3. Oct 30, 2020 at 12:36 PM
    #3223
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Yeah, but I recall something similar from my last truck too. Basically it's either on the inside or the outside of the frame and either way, there's potential to be hit. (Not referring to running it through the frame, just on the "inside" from the location you've shown.)
    Rcyotaaa5 likes this.
  4. Oct 30, 2020 at 12:37 PM
    #3224
    RedWings44
    Michigan
    Yeah, I'm not sure why it can't just function like the keyed version. You get in and step on the brakes without a key detected and it kills the engine. That way I can still let the truck warm up while I'm loading items inside it.
  5. Oct 30, 2020 at 12:52 PM
    #3225
    Burmapeak
    Burmapeak Well-Known Member
    Oregon
    2017 Tacoma TRD PRO Cement
    You can start it, than lock the door with the key that is hidden inside your key fob.
    bigsmirt likes this.
  6. Oct 30, 2020 at 2:23 PM
    #3226
    RedWings44
    Michigan
    That's good for one door. 3 left. Although I haven't tried with the door buttons. I'll try it now and report back.
    Edit: tried it, but the truck keeps unlocking itself again any time you hit lock.
  7. Oct 30, 2020 at 3:24 PM
    #3227
    Burmapeak
    Oregon
    Interesting, mine locks all doors with the key. Maybe because I changed my settings for when I push unlock on my key fob, one push unlocks all doors instead of just the drivers door. Factory has it set that you need to push unlock twice to unlock all doors.
  8. Oct 30, 2020 at 3:37 PM
    #3228
    RedWings44
    Michigan
    Based on what you said, I decided to give it a try. I almost never use the key fob to unlock the truck since the handle is just easier. (I have that set to unlock all doors). One push of the unlock button allows me to unlock just the driver's door. I can then start the truck and manually lock it and none of the other doors unlock. I have to manually unlock the door though as the key fob still won't unlock the truck.
  9. Oct 31, 2020 at 7:26 AM
    #3229
    Gumpmann84
    Gumpmann84 Member
    Forrest
    Idaho
    Cement 2020, TRD OR, Long bed
    Roadmaster Active Suspension, Sumo Springs, ARE Camper w/ Yakima gutter pylons & bars and a Prinsu Cab Roof Rack.
    Dang. That is weird. I don’t have that at all.
    As soon as I unlock my Taco it shuts off. I can’t even get in the door.
    Still bizarre to me. I should be able to get into the truck and hit the start button to ensure the key is present. I could see the truck shutting off as soon as someone puts it in gear if no key fob is present. But simply opening the door or unlocking is odd. Undo wear on the starter. I wonder if there is a setting I can change somewhere...
  10. Oct 31, 2020 at 9:18 AM
    #3230
    RedWings44
    Michigan
    There is no setting you can change. It is done from the factory. Even installing an aftermarket remote start won't solve the issue.
    jamesfishn09 likes this.
  11. Nov 12, 2020 at 1:42 PM
    #3231
    Punkface
    Punkface Well-Known Member
    Colorado
    2020 Tacoma TRD Off-Road DCSB 4x4
    Tip #33 to change screen images does not work with the 2020's if anyone was wondering.
    Edit for clarity: meant the image that shows on your screen during start up and when the display is set to "OFF"
  12. Nov 12, 2020 at 1:45 PM
    #3232
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
  13. Nov 16, 2020 at 12:25 PM
    #3233
    Hammer40
    Hammer40 Well-Known Member
    SW Washington
    '96 Tacoma (sold). '05 DCSB TRDOR(sold) '17 DCLB TRDOR (Traded)
    tonneau cover.
    The remote start issue with the PTS ignition was just pure laziness and a BS excuse from Toyota for the reasoning. My '19 CRV works exactly the way all others do it. To this day the fact that my $50K Taco can't do what a $20k cheaper vehicle does do just pisses me off.
  14. Nov 16, 2020 at 1:44 PM
    #3234
    dand
    dand Blood and tears
    Dan
    Newport News VA
    2021 DCSB TRD Sport Army Green
    $50K for a Tacoma?
    Tell me more..
  15. Dec 27, 2020 at 6:12 AM
    #3235
    SeanDP
    SeanDP Member
    2020 Tacoma Off Road
    Yeah #10 isn’t true for me. I now have 18,101 on my 2020 OR and it’s doing the same thing as it has from the start. Jerks or “stutters” at speeds between 40-50MPH on flat roads when not in ECT mode.
    Fishcop2903 and BlueRidgeFly like this.
  16. Dec 27, 2020 at 8:24 AM
    #3236
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    Get the TSB update, it will greatly improve how the truck shifts gears to the way its supposed to. Click on the link below.
    Finally a fix from Toyota for Stumble condition (TSB 0062-18)
    JustinTRD20 likes this.
  17. Dec 27, 2020 at 11:00 AM
    #3237
    dilbert
    dilbert AI Member
    PNW
    The TSB you want for a 2020 automatic is TSB-0092-20 to update your ECU to 04B81. You can even do it yourself or find someone near you willing to update it for you.
    https://www.tacomaworld.com/threads/ecu-tsb-update.562550/
    JustinTRD20, C41n, Devious6 and 2 others like this.
  18. Jan 9, 2021 at 8:14 PM
    #3238
    iMissMyFj
    iMissMyFj Member
    2019 Ram 1500
    Mine does not have the premium/advanced package, and the remote start didn't work until I activated the Remote Services in the Toyota app... it appears that I will need to maintain a subscription if I want to keep the functionality. The triple click on the remote, and starting from the app both work.
  19. Jan 19, 2021 at 11:35 PM
    #3239
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    2 months into 3rd gen and chill, and I'm still learning how to use all this tech
    AdkGal1, leueddie, BRUIN8124 and 2 others like this.
  20. Jan 24, 2021 at 7:24 PM
    #3240
    4wdmurph
    4wdmurph Active Member
    LA
    2016 Tacoma TRD Off Road
    Anything you like about the tech?
