Tire Help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SCboater, Apr 30, 2018.
  1. Apr 30, 2018 at 3:25 PM
    SCboater
    SCboater [OP] Well-Known Member
    Jeff
    2017 TRD off road inferno red
    Can anyone tell me the weight of the stock wheel and tire setup on the off road. Thanks in advance.
  2. Apr 30, 2018 at 3:32 PM
    phsycle
    phsycle Well-Known Member
    CA
  3. Apr 30, 2018 at 3:38 PM
    SCboater
    Jeff
    Thank you. I think wheel is 22.4 so 64+ total
  4. Apr 30, 2018 at 5:46 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Tirerack used to list 2 different Wranglers; one at 36 lbs(made in Canada) and one at 42 lbs(made in the USA).
    My OEM Wranglers were Made in Canada...just sayin', those might not be the OEM spec tire.
  5. Apr 30, 2018 at 5:49 PM
    SCboater
    Jeff
    Well that messes up all my math. Wanting to get KO2 and trying to stay close in weight.
  6. Apr 30, 2018 at 5:51 PM
    splitbolt
    NW Arkansas
    Just curious...where were yours made?
  7. Apr 30, 2018 at 5:56 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  8. Apr 30, 2018 at 5:59 PM
    SCboater
    Jeff
    Not sure I'll need to look.
  9. Apr 30, 2018 at 6:14 PM
    SCboater
    Jeff
  10. Apr 30, 2018 at 8:58 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Yes, but if you went Ray 10s in 17 you’d be at 68lbs. And C-load KO2s will ride better, and provide better acceleration, braking and MPGs over their E-load counterparts. Weight on the outer edge of the tire is also more detrimental than weight at the center of the wheel.
    You could also run 17” OEM 4Runner Pro wheels and come in at 70lbs a corner while saving over $100/wheel over Ray 10s.
    Just pointing out options.
  11. May 1, 2018 at 6:14 AM
    phsycle
    CA
    I’d never heard that before. But mine is made in Canada. But all other specs match to the one listed on their site now. 112T service, 640 treadwear, etc.
  12. May 1, 2018 at 8:27 AM
    splitbolt
    NW Arkansas
