Tire Pressure Light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tensecondchevelle, Dec 31, 2014.
  1. Dec 31, 2014 at 11:49 AM
    tensecondchevelle
    tensecondchevelle [OP] Well-Known Member
    Eric
    Mesa Arizona
    2006 Tacoma Double Cab
    My tire pressure light went on and has been on for a few days now.
    I double checked my tire pressure in my four tires and everything is within range, I can only assume it's my spare tire at this point. I really don't have the desire right now to drop the spare down so I can check the air/fill it up (the stem is facing the bed of the truck, not the ground).
    Am I ok to just reset the light and if it goes back on just ignore it?
  2. Dec 31, 2014 at 11:52 AM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    You can reset it, but I wouldn't ignore that spare too long. You may end up with a flat tire some day only to find out you have two flat tires.
  3. Dec 31, 2014 at 11:56 AM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    If the batteries in one of your TPMS sensors are dead then the light will turn on due to the missing signal from that sensor. Good luck pinning down which tire is to blame if this is the case.
    The batteries only last so many years until you have to replace them or the sensors.
  4. Dec 31, 2014 at 12:00 PM
    Manwithoutaplan
    ID
    well if you don't tpms sensor then you don't have worry about that :D>
  5. Dec 31, 2014 at 12:01 PM
    tensecondchevelle
    Eric
    Mesa Arizona
    I don't have any plans on getting a flat tire anytime soon. :)
  6. Dec 31, 2014 at 12:05 PM
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    I don't think I've ever planned to get a flat either, but shit happens. :rolleyes:
  7. Dec 31, 2014 at 12:11 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
  8. Dec 31, 2014 at 12:13 PM
    tensecondchevelle
    Eric
    Mesa Arizona
    I can appreciate that answer.... In all honesty I've been wanting to drop down the tire anyways for "practice" as I've heard it's not all that easy to do, specially when you're broke down on the side of the road.
    I suppose I have to just stop thinking about it and doing it.. ha.
  9. Dec 31, 2014 at 12:30 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    YEAH.... if you got an '06 and not had that tire off yet.... you better do it ASAP.... the wheel will be rusted and I doubt you could put it on the truck even if it did have air in it...... Turn it over so you can check from the bottom....
    The removal method is CRAP and I'd not want to do that at night.... so MY spare is in the box where it don't get salt, rain, etc all over it (under the Tonneau) and I can check it easy...
    Good luck with that.... First time dropping that will be a lot of fun, I guarantee...
  10. Dec 31, 2014 at 12:31 PM
    Shelf Life
    Rob
    Central Oregon
    Get er done. I think they are mounted outside up so you dont trash the outer side of your tire /rim.
  11. Dec 31, 2014 at 12:32 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    My 2013 has been reset by the dealer just 2 weeks ago, and the TPMS is always on. Tire pressures are fine, usually is off for 2-3 days after reset and then it's on all the time after that. Spare is flipped, pressures are all the same. Not sure if this is "normal" or what, but it's annoying.
  12. Dec 31, 2014 at 12:37 PM
    over60
    Muskoka, Ontario
    One small 3/4" x 3/4" piece of black electrical tape placed in the right position over your TPMS light works for me... Probably the cheapest DIY you could do....
    (Who needs that freakin' TPMS anyway)... it's there for the girls.... Real men don't need that crap.
  13. Dec 31, 2014 at 12:39 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Pipe bomb
  14. Dec 31, 2014 at 12:41 PM
    over60
    Muskoka, Ontario
    HUH..???????
  15. Dec 31, 2014 at 12:42 PM
    OZ-T
    Peter North
    British Columbia
    Do the pipe bomb / TPMS pressure vessel mod
  16. Dec 31, 2014 at 12:44 PM
    Clearwater Bill
    Billy
    Largo Florida
  17. Dec 31, 2014 at 12:45 PM
    over60
    Muskoka, Ontario
    Yeah,.... OK that trick... still too much work for me... All my working TPMS sensors are in the garage this time of year anyway...Wouldn't work then.
    Tape works great.... and if I ever have the dash apart, that light will be removed
  18. Dec 31, 2014 at 12:45 PM
    Clearwater Bill
    Billy
    Largo Florida
    I'd make myself very annoying to them until it was fixed, assuming it's still a warranty issue for you (I have a year left on my '13)
  19. Dec 31, 2014 at 12:49 PM
    OZ-T
    Peter North
    British Columbia
  20. Dec 31, 2014 at 12:49 PM
    over60
    Muskoka, Ontario
