Tire Size with Leveling
Discussion in '3rd Gen. Tacomas (2016-2023)' started by LDog, Jan 14, 2022.
  1. Jan 14, 2022 at 3:49 PM
    LDog
    LDog [OP] Member
    2019 white TRD XP
    None yet
    Gonna add 2” to the front and 1.5” to the rear of my 2019 TRD. What is the largest tire I can put on with 16” wheels?
    Tocamo likes this.
  2. Jan 14, 2022 at 3:58 PM
    Nw_nomad
    Nw_nomad Well-Known Member
    2019 Tacoma Trd offroad 6MT
    If you trim the fenders and stack enough spacers you are only limited by your imagination.
    Sroberts likes this.
  3. Jan 14, 2022 at 3:59 PM
    Nw_nomad
    255/85r16
    SnuggleTruck, Tocamo and 71tattooguy like this.
  4. Jan 14, 2022 at 4:27 PM
    LDog
    LDog [OP] Member
    2019 white TRD XP
    None yet
    A friend told me he read a response where someone raised a 3rd gen 2” up front and 1.5 in the rear and fit 285 75 16. Minor modification inside the fender well.
  5. Jan 14, 2022 at 4:33 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
  6. Jan 14, 2022 at 4:36 PM
    LDog
    LDog [OP] Member
    2019 white TRD XP
    None yet
    Yea…bit much for what I want to do.
  7. Jan 14, 2022 at 4:41 PM
    gudujarlson
    Minnesota
    Don’t stop dreaming.
    Montana_Actual and Nw_nomad like this.
  8. Jan 14, 2022 at 4:48 PM
    LDog
    LDog [OP] Member
    2019 white TRD XP
    None yet
    Thanks
  9. Jan 14, 2022 at 4:51 PM
    gudujarlson
    Minnesota
    Tocamo likes this.
  10. Jan 14, 2022 at 4:59 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    FWIW You could do 255/85/16 or 265/75/16 Tire on a 16x8 wheel 0 offset or whatever else works. You’ll be dialed off-roading and every day driving. Flex out no rub and keep weight down as well :rasta:
    McPickle, Hansamzac, Tocamo and 5 others like this.
  11. Jan 14, 2022 at 5:09 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    I have about the same lift height as you. I run 265/75R16 KO2s on 16x8 -12 wheels with no rubbing. You may be able to fit a 275. A 285 would be sketchy
    LDog[OP] likes this.
  12. Jan 14, 2022 at 5:13 PM
    Nw_nomad
    265/75r16 with 2" lift in front. Nothing in the rear.
  13. Jan 14, 2022 at 6:25 PM
    Mystery252
    Mystery252 Well-Known Member
    Largest height or width?
  14. Jan 15, 2022 at 12:09 AM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    welcome aboard
    Do you want to hammer pinch welds and cut some plastic?:yes:
    :sawzall:
    Montana_Actual likes this.
  15. Jan 15, 2022 at 1:49 AM
    Montana_Actual
    Montana_Actual ;)
    Ew. No.
    He said tires... Not pizza cutters. ;)
    Sroberts and Nw_nomad[QUOTED] like this.
  16. Jan 15, 2022 at 2:42 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    265s for the win. No issues, no loss of power, no decrease in mpg, no trimming, able to run factory mud guards, no re-gear, no trimming, no cutting the fenders, no recalibration, no cab chop mounts needing cutting, no hammering the pinch welds, no excessive wear on suspension and brakes. Its just a win win for a perfectly fit tire or do all that for an inch more. Hell I just talked myself out of 285s again! As much as I want the 285s and they look great I'm sticking with 265s and its a great size for a 2/1 lift.
    IrishRed, LDog[OP] and 71tattooguy like this.
  17. Jan 15, 2022 at 4:29 AM
    LDog
    LDog [OP] Member
    2019 white TRD XP
    None yet
    Sold
    just want a bit more clearance and still be able to pull a small camper.
    265 75?
    71tattooguy likes this.
  18. Jan 15, 2022 at 5:08 AM
    Tocamo
    Tocamo .
    Ottawa
    2017 Bug-out vehicle
    265/75/16 is the most common, without issues. And they look great!
    255/85/16 is the biggest that will fit without cutting.
  19. Jan 16, 2022 at 4:57 AM
    LDog
    LDog [OP] Member
    2019 white TRD XP
    None yet
    It came stock with 265 70 r16s. I think I can increase a bit after the 2” lift.
  20. Jan 16, 2022 at 5:17 AM
    SnuggleTruck
    SnuggleTruck Well-Known Member
    Alex
    Fort Myers
    2020 DCLB TRD OR
    TRD Pro skid plate TRD 2" lift shocks Icon AAL (gave me 1" lift with OL leaf out) ECGS bushing OME carrier bearing drop kit Truxedo roll up Tonneau cover MESO - led interior light kit, blackout kit and gashole Toyota door sill protectors and bed mat
    Lift doesn’t let you run a bigger tire. Wheel placement does (particularly when you are talking about a bigger and WIDER tire). This is why you can run a 255/85/16 and not rub when flexing while you likely will with a 285/75/16. If you don’t want to change your UCAs or do a CMC, run 255 or 265s. You can do the 265/75/16 and get an extra .5” of axle clearance vs stock or do the 255s and get a bit over an inch of added clearance.
    Orrrrr… full send and get out the hammer and knife for 285s and wider .
    Thunder Fist likes this.
