To buy or not to buy wheel spacers and why
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dontstealmyride, Feb 10, 2016.
Would you buy wheel spacers?
  1. Yes
    206 vote(s)
    58.5%
  2. No
    61 vote(s)
    17.3%
  3. Hell no
    85 vote(s)
    24.1%
  1. Jan 24, 2019 at 4:19 AM
    #101
    twheat40
    twheat40 POOP Custodian
    Tyler
    2017 4Runner SR5 Premium
    Wheel spacers do not affect the suspension. The "spacer" that affects the suspension is a spacer lift, which is put in above the coils on a coil-over. I ran wheel spacers when I had 255's on my 4runner and never had any issues. I had to remove them when I switched to 295's to reduce rubbing. Debris kicked onto the body gets worse, but that is obvious because part of your tire sits outside the body once you put a spacer in.
  2. Jan 24, 2019 at 4:45 AM
    #102
    RetiredSCPO
    RetiredSCPO Well-Known Member
    Will
    Seven Cities
    2017 Tacom TRD Off Road Double Cab-Silver
    Stock
    Usually it is to keep factory backspaced wheels with non-factory sized tires, for example on my jeep tj rubicon and factory rubicon wheels I went to a 35 12.50 tire(Much wider) so to minimize rubbing on control arms etc the backspacing needed to change. I used Spidertrax spacers on 2 different jeeps for this purpose to run factory wheels and wheeled them hard as well as daily drove. Follow the instructions, torque properly, and periodically pull the wheels and check the lugs/re-torque if needed. Don't go ebay cheapo spacer route. You get what you pay for.
  3. Jan 24, 2019 at 4:51 AM
    #103
    gurneyeagle
    gurneyeagle Well-Known Member
    Saint Augustine, FL/Houston, TX
    2008 Tacoma SR5, 2018 Audi TT RS, 2018 Tacoma TRD Off Road (Cement), 2019 MDX
    Just an FYI, that probably doesn't effect 1% of the folks on this forum but deserves being mentioned - Direct Tire will NOT touch a car that has wheel spacers. Learned that the hard way with my 370Z when I had a blowout. Limped over to Discount Tire, told they would/could not touch the tire so I had to remove it myself in the rain while wearing a suit.
    It's a corporate liability policy for them. Not sure what other national tire stores' policies are, but just wanted folks to know.
    BTW - Never had a problem, other than that noted above, with my spacers. They were hub-centric with extended replacement studs. I would not use spacers that bolt on using the original studs.
  4. Jan 24, 2019 at 5:04 AM
    #104
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    You must have missed my post (hard to believe, only 6 pages ;)), but my DT actually installed mine and has done numerous rotations, balances, and a new set of tires installed with the spacers on. Whenever I go in I also ask them to ensure that they re-torque the spacers. No comments or problems at all.
  5. Jan 24, 2019 at 5:12 AM
    #105
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    Moving the contact patch of the tire further away from the wheel bearings increases the moment around the wheel bearings.... increasing the load at the bearing.... kinda like a longer crow bar makes pulling a nail, opening a crate, lifting something heavy, etc... easier.
    Personally, I feel that the extra bolted joint doesn't help things. I definitely prefer no spacers. I also don't want the tires sticking out more than needed. Less is better.
  6. Jan 24, 2019 at 5:13 AM
    #106
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    With any spacer 1" or thinner, you cannot use extended studs. The OEM studs project beyond the spacer. On 3/4" spacers, the OEM studs may even need to have 1/8" ground off the end if wheels do not have a relief cut on back side of where they contact the spacer.
    I ran Bora 1" spacers for nearly 100K miles with stock studs. NEVER had one loosen. NEVER had a tire shop balk at doing work on truck. NEVER had a problem. NEVER used lock-tite. Unless you have an ongoing issue with lug nuts falling off, you won't have problems with the nuts holding the spacers. 99.9% of these mythological "issues" are anecdotal 3rd party comments from people who repeat what they heard from other people who have never used a wheel spacer. The balance of reported "issues" come from people who are a threat to human life when they have a screwdriver in their hands.
    For every one story about alleged issues, I can find you 1000 people who've used them with NO issues.
    And...Too many people assume an additional 1" or two of track width is well beyond acceptable limits. The hubs are not built so under engineered that a minor change in track causes failure. With wheels that widen track width, I no longer NEED spacers. That said, I wouldn't hesitate one second from using them. Actual high use experience has taught me that they are NOT a risk. Only risk is someone who shouldn't even own a wrench gets ahold of them. In that case, NOTHING is idiot proof.
    TAC1, DarthPow and Lurkin like this.
  7. Jan 24, 2019 at 5:18 AM
    #107
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    :thumbsup: Good reminder. I'd forgotten to post that. I have 3/4" spacers, but my wheels do have the between-lug reliefs.
  8. Jan 24, 2019 at 5:35 AM
    #108
    bgreyc
    bgreyc Well-Known Member
    Brad
    Albuquerque, NM
    '19 Silver TRD Off Road DCLB
    Lighting: BD S2 Sport Flush Mount Rear Bumper Lights (Work) BD Squadron Pro Driving/Combo Fogs (Amber) BD S2 Pro Ditch Lights (White, Off Camber Hood Bracket) KC Hilites Cyclone Under Hood Lights KC Hilites Cyclone Pair - Shell Lights 30" Rough Country Black lower grill light bar Raxiom Bluetooth Light Switch Accessory Controller Suspension Teraflex 2" Falcon Load/Haul Suspension Tires BFG T/A KO2 C 265/70R-17 Wheels Fuel Wheels - Vector Gun Metal (17x8.5) MESO Mods Coin Tray Dome Light Map Lights Key Fob - Orange/Red Keys @OneMoreTaco Radio Knobs TRD Pro Grill - Runnin4Tacos ARB Single compressor (Underhood) GTFO Expedition Compressor Bracket Runnin 4 Tacos - White Grille Lights - 4 Caliraised Bed Stiffeners Redline hood struts Bedrug Bedliner KTJO4x4 Tail Gate Auto Lock Kit Dual camera setup - Anytime front/rear Camera Runnin4Tacos - TRD Off Road Emblems Victory Blitz Rock Sliders Victory Top Rack Ordered (delivered, need time) Victory 4x4 Center Console Molle Wish List Victory 4x4 Blitz Front Bumper Victory 4x4 Strike Rear Bumper
    I purchased Spidertrax spacers, I see a lot of you using Bora, is there any difference?
    Bluegrass Taco likes this.
  9. Jan 24, 2019 at 5:37 AM
    #109
    WickedAx
    WickedAx Well-Known Member
    I figured as much. The reason I asked was one post that stood out while I was researching spacers on 3rd gen ORs (from this thread: https://www.tacomaworld.com/threads/anyone-put-wheel-spacers-on-a-3rd-gen.496705/#post-17995914):
    Thanks for the info, fellas! It's much appreciated!
  10. Jan 24, 2019 at 5:37 AM
    #110
    Bluegrass Taco
    Bill
    Mt Washington Ky
    BORA offers more choices in thickness. (3 sizes thinner than Spidertrax offers) Other than that, they are BOTH of good quality, and both seem to be within pennies of each other, cost wise...
  11. Jan 24, 2019 at 5:43 AM
    #111
    bgreyc
    Brad
    Albuquerque, NM
    Ok good, Thank you!
  12. Jan 24, 2019 at 6:04 AM
    #112
    eltacoutah
    eltacoutah Well-Known Member
    Ben
    Utah
    2010 TRD Sport
    It's no different than having a rim with a bigger offset. You notice it rides differently. If your tires stick out past the fenders wells you're going to get some mud/debris kicked up.
    WickedAx[QUOTED] likes this.
  13. Jan 24, 2019 at 7:53 AM
    #113
    DarthPow
    DarthPow Well-Known Member
    2012 DCLB TRD Sport 4x4
    Must be different for you for whatever. I posted this earlier: I went to America's Tire, and they had no issues working on my truck with bolt on spacers. They said they wouldn't touch the other kind though.
    TAC1 likes this.
  14. Jan 24, 2019 at 7:56 AM
    #114
    gurneyeagle
    Sorry I missed your post. Just getting old I guess.
    The difference in my case, was that my spacers were not bolt on.
  15. Jan 24, 2019 at 7:57 AM
    #115
    gurneyeagle
    You make a great point; my spacers were not bolt on. For some reason, bolt on were frowned upon for track days.
    TAC1 likes this.
  16. Jan 24, 2019 at 7:58 AM
    #116
    DarthPow
    "reliefs" That's what they're called! Thank you for this, I currently have 1.25" spacers on my truck, and I have the .75" Bora's sitting around waiting to be installed. Was wondering about stud fitment, and figured that those recesses would give me enough clearance for whatever amount of stud sticks out. Thanks for giving me a name and the kind-of-confirmation that they'll probably fit without issues!
  17. Jan 24, 2019 at 8:02 AM
    #117
    DarthPow
    gurneyeagle[QUOTED] likes this.
  18. Jan 24, 2019 at 8:12 AM
    #118
    gurneyeagle
    TAC1 likes this.
  19. Jan 24, 2019 at 9:00 AM
    #119
    FiveStripes
    FiveStripes Well-Known Member
    Cliff
    2018 Tacoma TRD Sport Inferno
    Nitto Terra Grapplers on American Racing AR901
    Everything I have read and researched regarding spacers is this. Only two brands worth getting...spidertrax or Bora. Next is making sure you use the Red Locktite and torquing the nuts properly. The custom offset guys say they even tow 10k pounds with a truck on spacers with zero issues.
    TAC1 likes this.
  20. Jan 24, 2019 at 10:06 AM
    #120
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Spacers do reduce the effective spring rate at the wheels.
    Actually...
    Increasing positive scrub radius reduces effective spring rate at the wheel.
    If you don't compensate for the added scrub with more toe in, you'll be toe out driving down the road. Both wheels toed out is...not good.
