Torn - Do I get UCA's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by invisionz111, Oct 22, 2009.
  1. Oct 22, 2009 at 3:32 PM
    invisionz111
    invisionz111 [OP] Well-Known Member
    2010 DC BSP
    5100 Bilstein’s (.85) w/ Eibach Springs | ¼ inch Taco Lean Spacer | 2” Add A Leaf Springs | 5100 Bilstein Rear Shocks| Light Racing UCAs | 955 B MotoMetal Wheels | Nitto Terra Grappler All Terrain 285/75/17 | ToyTec Diff Drop | AFE Pro-Dry S Air Filter | Tint | Westin Bull Bar | Raptor Side Steps | UWS Toolbox | Weathertech Floor Mats | Weathertech Side Vents |
    I have searched but it seems like I can't get exactly what I am looking for, so here it goes.
    I have a 2010 TRD Off Road and I am having the following installed:
    5100's all four corners
    2" AAL (toytech)
    Front Diff Drop (toytech)
    Moto-Metal 955 B (17x9, 4.5 backspacing, -12 offset)
    Nitto Terra Grapplers AT (285/70/17)
    Here's the big question, should I put on UCA's?
    My concerns are:
    1. I have the money, but I don't want to spend it if I don't need to.
    2. I am weighing premature tire wear if i don't get them versus the money I would save from premature tire wear if I had the UCA's installed.
    3. Do UCA's address one or two issues, are they installed to save tire wear or improve drive-ability at higher interstate/freeway speeds?
    4. Will my new tires rub the stock UCA's and possibly cause tire a premature failure?
    I want to join in on the group buy, but I need to find satisfy my concerns before jumping in. If the issues are something I can live with then I won't spend my money, but if the issues cause more problems or money to deal with then I will buy them.
    Thank folks for checking this out and helping me to make my decision.
  2. Oct 22, 2009 at 3:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    How high is the front lifted?
  3. Oct 22, 2009 at 4:06 PM
    PPD934
    PPD934 Well-Known Member
    Western Kentucky
    06 silver double TRD
    Running bars, tinted window (, TSB mod ,885 coils, OME shocks up front, AAl and procomp 9000 out back, partially debadged/black out the others, weathertech floor mats, grillcraft grill, TRD skid plate
    i ran a 3 inch spacer with on the factory rugged trails for about the last 15,000 miles or so. I only got 30,000 out of the tires but I think it has to do more with the factory set. I am about to spend 800 on a new set of michelins. ( why because I am just a loyal fan) I just bought the LR uca in the group buy because i am getting new tires.. My mechanic says although the alignment isnt right on due to the lift, that it should not affect the tire wear that much. My truck is a bit more darty after the lift on the stock UCA's. By darty i mean its very responsive to minor movements in the steering wheel. Very noticeable from stock but I have gotten use to it and it drives fine. Chris sbove won;t steer you wrong he will let you know whats best just my 2 cents...
  4. Oct 22, 2009 at 4:27 PM
    invisionz111
    2010 DC BSP
    I am planning on setting them at the 2.5 mark
  5. Oct 22, 2009 at 4:39 PM
    Canadianboy
    Canadianboy Taco love in East Van
    James
    Vancouver, BC
    09 TRD Sport S/B 4x4 Auto in Mag Grey
    Icon Stage 3, Goodyear Duratracs and KMC Addicts!
    If you have the money, I would get them and have a lift thats done right. And I'm sure it will handle better as you will be able to get the alignment in spec
  6. Oct 22, 2009 at 4:42 PM
    Padilla1880
    Padilla1880 "Let's Ride!"
    Daniel
    Temecula, CA
    05 TRD OffRoad V6 SR5 PreRunner
    Aftermarket UCA's aren't needed, but are HIGHLY RECOMMENDED.
    Aftermarket UCA's help to get alignment near factory specs. Also helps to keep truck from floating/wandering feeling while driving.
    As long as you have a good alignment and proper tire inflation, you won't have to worry about premature tire wear.
    As long as you have proper backspacing you shouldn't have a problem with tires rubbing on stock UCA's.
    If i left anything out im sure someone will chime in.
    There is this current group buy going on through toytec:
    http://www.tacomaworld.com/forum/to...n-5100-lift-kits-lr-ucas-ends-11-17-09-a.html
  7. Oct 22, 2009 at 8:01 PM
    chad68
    chad68 Master Jedi Member I am...
    Chad
    In a (Toyota) van down by the river! Sonoma Cownty
    2009 4x4 reg cab. Modded with more to come
    Polished 16x8 Pro Comp 1069's 4" BS Nitto Mud Grapplers 305/70/16 Magnaflow & glasspack muffler Stainless tip K&N 63 series Aircharger Vent visors Autometer volt and dig. temp. gauge custom mounted Factory chrome rear bumper (not black factory, one) TRD pedal covers TRD skid plate Hurst T handle shift knob Rear Tint Clear bra on the sides Chrome extinguisher Icon non resi coilovers, ICON RR shocks, black seat covers. And some other crap
    I'm still up in the air about replacing the stock UCA's. Only reason I want them is so my tires last longer from the slight positive camber. On the other hand I do like my quiet stock arms and don't like the idea of spending hundreds of dollars to listen to a bunch of noises that may or may not fix the alignment 100%, so I may just spend money on tires instead or arms.
  8. Oct 22, 2009 at 8:03 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The Total Chaos UCA's are silent, if installed propperly. The Light Racing arms are just as quiet as OEM.
  9. Oct 22, 2009 at 8:06 PM
    testedone
    testedone Speak English..it's America
    Rick
    U.S.A.
    2010 Tacoma TRD Sport
    Weathertec Mats, Pioneer AVIC-X930BT, Pioneer GEX-P920XM (SAT), Pioneer Premier TS-D602P 6.2, Blaupunkt THb 200A Sub, Trimmed Mud Flaps, BF Goodrich AT/KO 285/70/17 ... Toytec Ultimate Lift, Tuffy Bed Box, A.R.E. Cover, Pop-n-Lock, TRD Exhaust
    But with 2.5" up front does he NEED them or is it OK to go with out, I am in the same boat...I am going to bypass getting them for now as I need to save and get a cover for my bed and more ammo for the impending worlds end :)
  10. Oct 22, 2009 at 8:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I would say "Yes". Keeps the alignment in spec. as the truck was designed.
  11. Oct 22, 2009 at 8:09 PM
    testedone
    Rick
    U.S.A.
    aw man...I need to skip ammo this month....:(
  12. Oct 23, 2009 at 10:08 PM
    invisionz111
    2010 DC BSP
    First, I want to thank you all for your posts. They have been enlightening and have made me consider more things and regrettably spend more money than I really want too. So here is where I find myself, please continue to provide your positive and negative feedback as both are valuable to me.
    Using the current toytech GB listed at
    I am planning on installing Option 4 & 5.
    -The 5100 will be set at .85 and the Eibach Springs provide 1.6 inches of lift. I hope to achieve near 2.5 inches and have a decent ride (not too harsh)
    -1/4" Spacer on the drivers side to correct my taco lean
    -LR UCAs to replace the stock ones (I hope they don't make a lot of noise)
    -Front Diff Drop
    -5100 in the back and the TSB AAL (I think the back will sit a little higher than the front. I prefer it to be level but it is okay if the back is just a LITTLE bit higher than the front. I tow my boat and utility trailer.)
    -My tires will be Nitto Tera Grapplers 285/70/17 on Moto Metal 955B's
    I hope it all comes together, cause this is a ton of FRICKIN MONEY! But Grandaddy always said, 'Do it right the first time and you won't worry about having to do it over again.'
    This is my first ever lift and I hope it is right.
  13. Oct 23, 2009 at 11:50 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    what is there to make noise? they use a ball joint just like the OEM arms...
  14. Oct 24, 2009 at 1:21 AM
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    Icons, Bilstein 5100, Rear Leaf TSB, 17x9 American Racing Chamber Teflon, 275/70/17 Goodyear
    the ammo is probably more important. I have been running for 10,000 + miles on my stock UCAs and Icons set at 2.5. It drives fine going straight, but in the turns the camber gets even more positive and you can hear the tires scraping. I have a little noticable wear on the out edges of my bfg all terrains, but nothing that would make for the cost of getting UCAs. I had TC UCAs on my truck for a couple thousand miles and took them off because they move the tire way back in the wheel well and it looked weird and rubbed like crazy on my frame and fenders. I kinda had to take them off. I am fine with the stock arms. The perfect setup would be set the 5100s at 1.75, leave the rear stock height, and keep the stock UCAs. Then run 275-70-17 good year silent armors, these are bad ass tires for the street where you do 99.99999999999 of your driving anyways, at least most of us anyways.
  15. Oct 24, 2009 at 1:23 AM
    sincitytaco
    Las Vegas
    You should be good with this setup if you go LR UCAs because they have adjustable caster and you can move the tire forward if you have to.
  16. Oct 24, 2009 at 5:31 AM
    dalsmthme
    dalsmthme Well-Known Member
    Ithaca, NY
    '09 Double Cab 4X4 SR5
    Ha, up in the air.....in a lift thread. I am amused. Simple pleasures I guess........
  17. Oct 26, 2009 at 3:26 PM
    invisionz111
    2010 DC BSP
    OK Folks,
    Thanks to Toytech for evening out everything for me. I ordered all of the parts and I am going forward on the lift when all parts come in.
    I want to thank ALL OF YOU for your contributions, they were immensely helpful when conducting my research. I know that these questions are asked often and with so many different combinations of products and the pricing of these products, a reasonable person would try to do their due diligence before taking the plunge. You folks have been great answering my questions and being able to search the forums as well has proven Tacoma World to be a great resource that all Tacoma owners should frequent.
    Thanks for allowing me to be a part of this great forum.
  18. Nov 10, 2009 at 9:45 PM
    invisionz111
    2010 DC BSP
