tow hook recommendations
Discussion in '2nd Gen. Tacomas (2005-2015)' started by southpier, Mar 7, 2011.
  1. Mar 7, 2011 at 7:49 AM
    southpier
    southpier [OP] Well-Known Member
    2011 tacoma.
    i want aftermarket tow hooks. dealer says 'T' slots in the frame work as such. i'm not satisfied with that response, but understand dealers have to do what the supreme high command dictates.
    Q: anybody suggest and aftermaket set (front & back) of tow hooks & related hardware?
    "search" took me down a long, long, road!
    thanks
  2. Mar 7, 2011 at 8:35 AM
    sicripp83
    sicripp83 Well-Known Member
    wboro
    sic
    i bought a sweet tow hook from harbor frieght that go;s in your reciever, i think it wsa $5
  3. Mar 7, 2011 at 9:02 AM
    musty40
    musty40 Well-Known Member
    Alan
    Duluth, MN
    2010 DC SB TRD OR
  4. Mar 7, 2011 at 9:33 AM
    Sighless
    Sighless Well-Known Member
    TORONTO
    10 SR5
    i just use the pin that holds my receiver in the hitch.. drop your tow strap on the pin, put your clip on it.. and pull...
    worst comes to worst if you bend something its gonna to be the retaining pin, instead of a tow hook.
  5. Mar 7, 2011 at 9:35 AM
    Sighless
    TORONTO
    10 SR5
    i realize what i said may not be very clear.. so what im saying is put the towstrap loop on the pin, and put the pin into your hitch as you would normally do..
  6. Mar 7, 2011 at 12:05 PM
    lrak
    lrak Well-Known Member
    Why were you asking the dealer about aftermarket ones? If you are going to ask the dealer, ask them order the TRD hook (P/N: 51961-35080) and the two bolts (P/N: 90119-A0193) for the front.
    For the rear, I like the Tow Ready 63046 (aka Draw Tight 63046 aka Hidden Hitch 63046 aka Reese 63046) tow ring. It is less expensive and heavier duty than the other hitch mounted ones I've seen on the market. Be warned it is HEAVY.
  7. Mar 7, 2011 at 12:28 PM
    kd8awe
    kd8awe Well-Known Member
    Rocky
    Ohio
    4x4 TRD Off Road
    Fog mod, 3" lift, ShoMe stobes, MicroLight LED Strobes, HiLift Jack, RCI 2950, Yaesu 8900r, 20% Tint, ScanGauge II, Weathertech Side Window Deflectors, *** New Mod's (parts on the way) *** U-Bolt flip kit. Tom Woods 1 Piece Double Cardan Drive Shaft. 3* Axel Shims
    Reese Hook
  8. Mar 7, 2011 at 6:09 PM
    southpier
    wrong choice of words. i was more concerned when the parts guy told me he used to work for a towing company and the process was to use a long hook into the slot on the chassis (rear) or the back axle, and on the tie down hook or control arm on the front, and yank!
    but i appreciate the parts numbers and will check them out; thanks
  9. Mar 7, 2011 at 6:12 PM
    southpier
    are these a universal part & i could just find a single hole in the frame to bolt it?
  10. Mar 7, 2011 at 6:15 PM
    maxamillion2345
    maxamillion2345 Leaves the bay but brings all its problems
    Max
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Looks like a receiver mounted hook. I'd go shackle instead.
  11. Mar 7, 2011 at 6:51 PM
    lrak
    They go in your hitch and you put your hitch pin through it...as does their shackle one I posted the part number above.
  12. Mar 7, 2011 at 7:11 PM
    pojo82
    pojo82 Well-Known Member
    Josh
    NE Wisconsin
    06 TRD double cab
    flowmaster exhaust, URD cold air intake, URD MAF calibrator, Thorley Headers Billy 5100s set to 2.5 lift in front, Billy shocks with add a leaf in the rear Wet Okole seat covers
  13. Mar 7, 2011 at 8:30 PM
    musty40
    Alan
    Duluth, MN
    2010 DC SB TRD OR
    I would stay away from a hook, find something that you can securely attach a d-shackle to.
    Same goes for a recovery strap. No hooks, use looped ends.
  14. Mar 8, 2011 at 3:35 AM
    southpier
    that's helpful; thanks.
    i am trying to be weight conscious. i am not considering receiver hooks or shackles because as soon as the stock bumper is changed to an Armor Tech unit, it's coming off.
  15. Mar 8, 2011 at 4:13 AM
    maxamillion2345
    Max
    Nevada
    Cummins, tons, 40s
    Use the hitch pin then. Slide the loop of the strap inside the receiver hitch. Stick the pin through. Call it a day.
  16. Mar 8, 2011 at 4:17 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I added the TRD hook and also have the factory loop on other side up front and have receiver shackle for the back.
  17. Mar 8, 2011 at 4:42 PM
    southpier
    when i put in the shackle, do i have to shim so there's no side to side play?
    thanks
  18. Mar 8, 2011 at 8:03 PM
    maxamillion2345
    Max
    Nevada
    Cummins, tons, 40s
    There are rubber isolators you can buy that will prevent rattle, otherwise no.
    Remember when tightening your shackle for a recovery, all the way finger tight, turn back 1/4 - 1/2 turn.
  19. Mar 9, 2011 at 1:22 AM
    southpier
    that's a good tip; thanks
  20. Mar 28, 2011 at 7:28 PM
    SR54x4
    SR54x4 Well-Known Member
    Mark
    Hudson Valley
    2008 4x4 TRD SR5 Tundra
    Magnaflow 12588, TSC lo-pro extra deep toolbox, step bars and bull bar
    do a lot of people do it this way? what are the chances of bending or breaking the hitch pin? also, by pulling directly from the hitch pin is there a chance for the holes in the actual hitch to get "oval" or "egg" shaped?
