Toyota Tacoma 3.4L K-Line ECU Reflash interest
Discussion in '1st Gen. Tacomas (1995-2004)' started by OVTune, Jul 25, 2017.
  1. May 11, 2025 at 7:17 AM
    #381
    Rocan
    Rocan Well-Known Member
    2001 Tacoma 4x4 5 Speed XtraCab
    3" Lift, BFG K0, URD Short Throw Shifter with Extended Shift Knob, Air Box Mod, Filled right boot with lead
    Bumping this from the dead. Any progress? Any way I can get my hands on this or contribute in some way? Is ovtune still around?
  2. May 11, 2025 at 8:42 AM
    #382
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    Could be wrong here...but uhhhh
    This ain't comin back
    I was super hopeful when it was first posted, but quite frankly the tech in the majority of 3.4 ECU's is simply too old and unknown theses days to make tunable, atleast to a degree anyone would invest time in.
  3. May 11, 2025 at 9:48 AM
    #383
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    You would be better off investing in a haltech ECU. There are Plug and Play kits out there now and quite a large community of support. On top of that most major tuners know how to tune haltech ecus
  4. May 11, 2025 at 9:59 AM
    #384
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Not only that, but I have multiple 03-04 ECUs (a mix of Japan made and TN made) and OV said not a single one is tunable. So it seems only very specific ones can be done, if any at all. The whole thing was confusing.
    BTW I’m fairly certain OV is no more and the new company is under VFtuner.
    also, Split Second, the company that actually made all the piggyback computers for URD is no longer operating so, not sure what URD is going to do but maybe there’s a silver lining? Either Gadget is going to work out rights to continue manufacturing the old SplitSec stuff, he’ll use his contacts to come up with something hopefully better, or just stop producing the 7th kit all together.
    It might get interesting because if Gadget can’t continue with the same Tech then Magnuson spent all that TVS1320 R&D and CARB approval cash for a dead application. Magnuson says you don’t need tuning but thats legal verbiage to protect them legally. They know damn well you need to alter timing/fueling so while they’d probably never get officially involved they would probably provide at least direction to their vendor in coming up with a solution.
    Rocan likes this.
  5. May 11, 2025 at 10:04 AM
    #385
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    The split second stuff was pretty outdated back in 2010 even, I'm amazed they made it this long
  6. May 11, 2025 at 10:11 AM
    #386
    Shortman5
    Supercharged TRD
    Im not disputing that, what I’m saying is that if that goes away you wind up with the only solution, a $4000+ ECU. That brings the total investment much higher than it previously was and URD likely won’t have a solution because they historically have not offered standalone ECUs
    Im just interested to see what URD is going to do.
  7. May 11, 2025 at 10:33 AM
    #387
    Speedytech7
    Can do a Haltech for a good bit less than $4000 and it'll actually work. Those split second units were so hamstrung by the stock ECU, even if they were cheap as dirt, they never really worked well. The SS units weren't the only piggy's on the market though
    Shortman5[QUOTED] likes this.
  8. May 11, 2025 at 10:40 AM
    #388
    Shortman5
    Supercharged TRD
    I’ve built a cart on SNP. $3579 for 03-04 w Auto trans. Still would need to get injectors/pump etc. I’d need to rely on remote tuning too as the closest tuner is hours away so there’s cost in that. Can you link to a cheaper option?
    I’m calculating the SNP kit, injectors, pump, and 8.5% sales tax to get $4K
  9. May 11, 2025 at 10:45 AM
    #389
    Speedytech7
    There's your prob haha
    What features do you want. I can likely find everything you need cheaper and as far as tuning goes I've got a hookup there for you :)
    04Pre_Runner and Digiratus like this.
  10. May 11, 2025 at 10:59 AM
    #390
    Shortman5
    Supercharged TRD
    I’m always interested in options and future value so I can take it with me for future applications. Ideally trans control, electronic TB control, etc. I’ve always leaned toward the 2500 for that reason. IMO Trans control is important. I can drive around the knock but simply driving around shift points.
    But most importantly, a complete wiring harness. I really need to be able to plug and play.
  11. May 11, 2025 at 11:06 AM
    #391
    Speedytech7
    I'll PM you this afternoon when I've got a computer in front of me. But I can tell you now that none of the harnesses on the market currently do all of that even if the computer supports it. I don't think anyone has done the R&D directly on it. But its something I've been working on. Done trans control, DBW (the Toyota one is a nightmare control wise)... But also no one should be buying 2500s anymore, it's about $200 more at the dealer pricing level to get an S3 which has more features and a built in wideband module so really it saves you about $150 over a similarly featured 2500.
  12. May 11, 2025 at 11:10 AM
    #392
    Shortman5
    Supercharged TRD
    Good to know. I appreciate the help and looking forward to hearing more.
    Dalandser likes this.
  13. May 11, 2025 at 1:51 PM
    #393
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Zane and Jayson can definitely help you get to where you want to be. With the exception of the electronic tb, my setup is the same as what you have. Full trans control is amazing. And with a Jayson tune, 240 hp at the wheels is easily attainable.
    Don't give your money to Gabe.
  14. May 11, 2025 at 6:46 PM
    #394
    Rocan
    I appreciate everyone's response. Without a doubt standalone offers many many advantages, and I've built and tuned a handful - haltech, MS, motec to name a few. I would much preferto go standalone. I also see a few new "parallel" systems, ie true injector /ignition controllers as opposed to 'piggyback' systems. My reason for wanting to get into the factory dme is to try and make some changes, find the limitations, and maintain obd2 and emissions compliance for inspection purposes. Despite approaching classic territory it seems my state will retain emissions inspections on any obd2 vehicles, and that is unfortunate as I have been considering a turbo system for a while.
    Has anyone played around with the rusefi system?
    www.youtube.com/watch%3Fv%3DaIs7p9RIKZM&ved=2ahUKEwjb4uOf55yNAxVrEVkFHcgdNVAQwqsBegQIFRAG&usg=AOvVaw1ZItOgVmrfTm1XJO4N65C6
  15. May 11, 2025 at 7:50 PM
    #395
    Speedytech7
    Unfortunately yes
  16. May 12, 2025 at 12:05 PM
    #396
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
  17. May 12, 2025 at 7:16 PM
    #397
    Rocan
    I'm curious to hear your thoughts.
  18. May 13, 2025 at 1:49 PM
    #398
    Robb235
    Robb235 Well-Known Member
    Chattanooga, TN
    1999 Turbo 4Runner
    Turbo 5vz uaEFI Standalone ECU 231mm Tundra Brakes RR Diff Lock Hayden 699 Transmission Cooler
    I am currently running rusEFI's uaEFI in parallel with my stock ECU for my turbo 5vz, and so far I really like it. Complete control over fueling and ignition, and let the stock ECU handle the rest. Next step for me now is I need to grab larger injectors.
