TPMS light staying on
Discussion in 'Wheels & Tires' started by PhilRR, Nov 17, 2011.
  1. Nov 17, 2011 at 8:39 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
  2. Nov 17, 2011 at 9:25 AM
    PhilRR
    PhilRR [OP] Member
    Phil
    2007 Tacoma
  3. Nov 17, 2011 at 9:26 AM
    PhilRR
    PhilRR [OP] Member
    Phil
    2007 Tacoma
    I seen some threads that said you'd have to drive a few miles for it to turn off after reset. And also in the manual, I couldn't find how to reset it. I had to look online
  4. Nov 17, 2011 at 9:59 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    The stock tires were set between 29 and 32 PSI. If the sidewall of your tires say 44 PSI for Max Loading, then you should be running in the low 30's. Do the chaulk test to determine the correct pressure for your tires (draw a chaulk line across the tire, drive a short distance and see where it's worn off. If worn off on the edges only, then too little pressure, if only worn in the middle then too much pressure).
    Well if I said it then it must be true :D I'll have to check the manual on how to properly reset the light but I think it's just holding the button, wait for the flashes and you're good to go. Driving a little bit helps warm the tires and if you have a TPMS light on in the winter, driving can make it go away because as the tire warms, the pressure rises slightly.
  5. Nov 17, 2011 at 11:47 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Toyotas come from the factory with the tires overinflated(55-60PSI). This prevents flat spots on the tires and shuts off the transmitters on the sensors in the tires.
    Any time there is an excessive tire pressure differential from the set pressure, the TPMS warning light will illuminate.
    Set 5 tires to door spec, ign on while holding reset button, wait for 3 flashes of the TMPS light, light goes out, you're done!
  6. Nov 17, 2011 at 12:01 PM
    jeremiekc
    jeremiekc Well-Known Member
    Jeremie
    Vilseck, Germany
    07 Regular Cab Base Model
    Secondary Air Filter removed, Painted Brake Calipers, AFN Drop in air cleaner, OEM Chrome Bumper, OEM Chrome grilll, OEM Cruise Control, OEM Interval Wipers, Hard Wired Garmin Nuvi 670, X-Runner Rims, Devil Horns, 6000w HID's, Bling Light Fogs with Blue Halo, OEM Bilstein Rear Shocks, 12V Plug in Truck Bed pocket. Debagged, 13" Antennax, Color Matched Satoshi Grill, URD Short Shifter, WeatherTech Floor Mats, PainLess Wiring Switched Fuse Box, Black Sand Pearl X-Runner Badges
    On an 07 you wont have to drive it to make the light go off at all. Just take it to the air pump and ensure that they are all inflated to what it says on the tire. As long as the pressure is above what it says for stock tires you wont have a problem. I have an 07 and every time my TPMS comes on it has always been the spare. Try filling up the spare and if it doesn't go off make a trip to discount or the dealer and they will be able to tell you if there is a problem. Always go to discount before you go to the dealer since they normally do not charge like the dealer does.
  7. Nov 18, 2011 at 8:07 AM
    PhilRR
    PhilRR [OP] Member
    Phil
    2007 Tacoma
    Discount?
  8. Nov 19, 2011 at 11:32 AM
    jeremiekc
    Jeremie
    Vilseck, Germany
  9. Nov 19, 2011 at 11:39 AM
    11SuperwhiteTRD
    11SuperwhiteTRD Well-Known Member
    George
    Beaverton, OR
    11 Super White TRD Off Road w JBL
    AFE cai, MBRP cat back, TonnoPro hard folding cover, Weather Tech's
    not sure about tacomas but i know that over inflated tires will set it. had four tires mounted and balanced on my wifes car... later that day i move her car out of the garage and her light is on. i checked the psi.. 2 set at 52 and 2 at 60...and this was from a tire shop! her tires should be at 32. i called the place and lost my mind on them then let out the pressure to normal. no more light.
  10. Nov 21, 2011 at 9:55 PM
    jeremiekc
    Jeremie
    Vilseck, Germany
    I am wondering if the system is set with a minimum and maximum air pressure. I am really old school and am used to checking my pressure with a pressure gage, not having a computer tell me that my tires are low.
  11. Dec 2, 2011 at 3:38 PM
    nwb3160
    nwb3160 Well-Known Member
    Nick
    Cartersville, Ga
    2008 Tacoma TRD Sport
    5100s OME 885 2009 tail lights 6000K HID Pioneer 4400 DVD Viper Alarm/Remote Start Avid Offroad Bar/Side Steps Wet Okole Seat Covers Husky Floor Mats Toyo Open Country MT 265/70R17 BANKS Monster Exhaust Ultraguage
    yea same here my tpms is on right now and i filled all 4 up to 40psi reset the sensors and filled up the spare to 29psi but im scared to put anymore air in it cause its so hard with air the tire doesnt flex any when i press it, and i checked the spare and i dont know where the sensor would be cause theres nothing going to the inside of the spare tire to determine if the pressures low
  12. Dec 2, 2011 at 3:47 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    OP did you ever figure out what the issue was? Was it the spare? I keep my tires just around 32psi along with the spare. Every couple of years my TPMS light will come on cause its always from the spare. I'm sure with the spare just sitting there for a long period of time and with the weather conditions I live in with blazing summers, freezing winters and everything in between, the tires are going to lose air sooner or later. I just refill the spare back to 32, hit the set button and then it shuts off, I never had to drive around for it to reset.
  13. Dec 3, 2011 at 10:07 AM
    PhilRR
    PhilRR [OP] Member
    Phil
    2007 Tacoma
    No, I haven't. When I took her in for an oil change they said the light will keep coming on cause the weather is getting colder.
  14. Dec 3, 2011 at 10:35 AM
    g35man
    g35man Discount Double Check
    League City, TX
    2012 MGM DC 4x4 OR
    Icon Stage II lift kit, LR uca's, Weather Tech floor mats, FX-R retrofit, Morimoto factory fit LED fogs, flyzeye designs cup holder lights, wet okole seat covers, upgraded Entune system
    It's the spare. Mine did the same thing on my 07. Fill your spare.
  15. Dec 3, 2011 at 11:02 AM
    #35
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Yep...same thing happens with my 07. I think the tires heat up after driving and the spare stays cold resulting in a psi difference. To get the tpms light there needs to be a difference of 20-25% which ends up being around 8psi. I could be wrong here but I thought I read once where someone mentioned they add more pressure (like around 4-6 psi) to the spare during the winter to help keep the light from coming on as often.
  16. Dec 3, 2011 at 11:17 AM
    #36
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Have you checked your spares PSI yet?
  17. Aug 27, 2018 at 12:55 PM
    #37
    Benchboy2007
    Benchboy2007 New Member
    2007 Tacoma V6 4wd
    Same issue... hope this fix helps. the tire shop inflated the tires including the spare. Since the light was still on and will not reset..
    Tire Guy proceeded to recalibrate each tire using some kind of gadget reader... and attached a cord that went under the left side of the driver steering wheel.. It reset the sensors with the correct tire pressure so the computer can read it. Light went away
