TPMS question
Discussion in 'Wheels & Tires' started by KrnTaco08, Feb 18, 2018.
  1. Feb 18, 2018 at 11:01 AM
    KrnTaco08
    KrnTaco08 [OP] Well-Known Member
    LA
    2017 Taco
    Hi,
    I’m getting ready to install my new SCS Ray 10s and tires on my 17 TRD OR.
    I want to purchase a set of TPMS sensors for the Ray 10s. Where is a good place to buy them or am I just wasting my money?
    I just want to leave the TPMS sensors on the OR rims and not mess with em’.
    Any input will help. Thank you.
  2. Feb 18, 2018 at 12:18 PM
    PacoDevo
    PacoDevo Well-Known Member
    Pops
    Bazetta Twp. Ohio
    2016 SR5 DCLB white "Quinn the Eskimo"
    @gunny1005.......just ordered mine last week $55+ each
    Should add, they are genuine Toyota OEM ones.
    gunny1005 likes this.
  3. Feb 18, 2018 at 12:20 PM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Do you have stock steel wheels?
  4. Feb 18, 2018 at 2:03 PM
    KrnTaco08
    LA
    2017 Taco
    @Tiedie Whatever the 17 TRD OR wheels are that’s what I have.
  5. Feb 18, 2018 at 2:17 PM
    Tiedie
    David
    WFOY
    Aluminum Wheels than it is so just have them move old sensors to new wheels.
  6. Feb 18, 2018 at 2:27 PM
    WOTaco
    WOTaco Well-Known Member
    NY near the old capital
    2016 MGM DCSB TRD OR MT
    I'm in the same boat. Using a set of winter tires/ on OEM wheels right now but have a set of summer wheels and need TPMS for them. I want my OEM set cloned so that I can swap wheels without any reprogramming. I took the codes off my OEM sensors when I put the winter tires on because I read that you could order a set of the EZ sensors pre-programmed (cloned). I thought these would work but called Tire Rack and Discount Tire both said they don't have one listed for my vehicle.
    http://www.schraderinternational.co...-Schrader-EZ-sensored61.html?sc_lang=en-US-NA
  7. Feb 18, 2018 at 2:39 PM
    Tiedie
    David
    WFOY
    I'm answering my own questions to you. Go to Rockauto and buy the TPMS sensors for the Aluminum wheels
    TOYOTA2017TACOMA3.5L V6WheelTire Pressure Monitoring System (TPMS) Sensor
    $41.89 each
    You can only program 1 set at a time
  8. Feb 18, 2018 at 2:45 PM
    WOTaco
    You can only program 1 set at a time[/QUOTE]
    Please elaborate. If you clone your OEM sensors then the truck will read whichever set is one the vehicle and rotating. It would not know there are 8 of the same sensors in existence.
  9. Feb 18, 2018 at 3:13 PM
    KrnTaco08
    LA
    2017 Taco
  10. Feb 18, 2018 at 3:15 PM
    KrnTaco08
    LA
    2017 Taco
    So I can add these to the new rims? Do I need the code prior to going to the tire shop? I want to make sure I’m dialed before installing the rim and tires
  11. Feb 18, 2018 at 3:34 PM
    WOTaco
    Unless you clone your original TPMS you will have to go to the dealer to have your truck programmed to read them every time you switch wheels. Your truck will only read one set of sensors. You can buy the ones mentioned above and have your truck set to read them but your truck will then no longer recognize your original sensors. Make sense? This is why I want to have my OEM sensors cloned, to avoid having to bring my truck to the dealer (or tire shop I guess) every time I switch wheels.
    KrnTaco08[QUOTED][OP] likes this.
  12. Feb 18, 2018 at 4:15 PM
    Tiedie
    David
    WFOY
    no you don't need the code.
    Tire shop should be able to program them when on the truck. I had stellies and went with Alloy wheels and needed the sensors for alloy put in. Firestone did it, now I would'nt say I didn't need to go back once to get the program to stick. Probaly because I had steel wheels in bed when we tried to program. They hooked up to computer and set the codes.
  13. Feb 18, 2018 at 4:23 PM
    KrnTaco08
    LA
    2017 Taco
    Do you know how much the dealership charges?
  14. Feb 18, 2018 at 4:24 PM
    KrnTaco08
    LA
    2017 Taco
    Good deal. thanks for your help. I’ll check out that link also
  15. Feb 18, 2018 at 4:26 PM
    Tiedie
    David
    WFOY
    I hope this helps went searching and found what you were asking, good read.
    KrnTaco08[QUOTED][OP] and WOTaco like this.
  16. Feb 18, 2018 at 4:30 PM
    Tiedie
    David
    WFOY
  17. Feb 18, 2018 at 7:17 PM
    KrnTaco08
    LA
    2017 Taco
