TPMS Reset and will not come back on or read pressures
Discussion in '3rd Gen. Tacomas (2016-2023)' started by epluribusunom, Jan 8, 2017.
  1. Nov 5, 2018 at 11:43 AM
    #41
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It could have been an error programming them to start with? If not at the factory, then did your dealer or someone else install new wheels for you?
    That said, you can either ask the dealer, or a tire and wheel shop, to scan the TPMS codes with a handheld tool. From there, you can check to see if they are correctly programmed into the ECU yourself with the Carista app.
    See the TPMS pic in this post:
    https://www.tacomaworld.com/threads/carista-app.515086/page-4#post-18962762
    els3286[QUOTED] likes this.
  2. Nov 5, 2018 at 11:52 AM
    #42
    els3286
    els3286 Member
    Everything is stock. They said that it was reading like it was learning the tire locations and to drive it 25 miles. I've got to go in again next week to have them install a new dome (mine developed a short), so I guess they'll just have to look at it again.
    tonered[QUOTED] likes this.
  3. Nov 5, 2018 at 11:56 AM
    #43
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    They will reset and start reporting even when going less than 25mph (at least mine does). You just have to drive a long enough trip that seems longer than 15min to me. I've run into this when airing down for trails. It takes a long time and it is hard to do 25 or more around here.
    At this point, I'm not sure that it will help you, but be sure to be stopped and hold the TPMS reset button until the dash light blinks a few times. Then, go for a drive where you are not stopped for about 15min or so?
  4. Nov 5, 2018 at 12:01 PM
    #44
    els3286
    els3286 Member
    From what the guy at the service department told my, I needed to drive 25 miles in distance, not speed. I did try to do the reset myself yesterday coming back from a camping trip, but I didn't follow the directions very closely (oops), so I'll give that another try... maybe it'll save me another hour or two at the dealership.
    Mack411 and tonered like this.
  5. Nov 5, 2018 at 12:08 PM
    #45
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    No big deal, but the OM (Page 467 to 469) says 25mph or more for about 10min. My experience has been a bit different than that (< 25mph for what seems to be more than 15min?).
    I will say that when rotating tires, resetting the positions using the same procedure on road, they started reporting pretty quickly (> 25mph for just a moment or two).
    Good luck! :cheers:
    Edit: I have been trying to imagine how one antenna installed in the Taco can determine the wheel location for each sensor all by itself. The only thing coming to mind is that it compares internal RPMs to what what is reported by the ABS tone rings and steering wheel angle sensor when going around corners? All four tire RPMs will be slightly different. I'm no programmer or electron expert though.
  6. Nov 5, 2018 at 2:30 PM
    #46
    els3286
    els3286 Member
    Well, I did the reset as instructed in the manual. Drove for a little more than an hour; mostly around 60mph on long back roads, aaaaaaaand.... still not reading. Guess I'll be spending a couple hours at the dealership next week, oh well.
  7. Nov 5, 2018 at 2:35 PM
    #47
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You gave it your best. Hopefully, it is something simple.
    The antenna module is either in the headliner or behind on the rear pillar trim. I can't exactly remember. If it is in the headliner and they need to get at it, it might be worth asking them to take a look at the third brake light to make sure it is sealed tightly. There were issues with them in the past, esp on the DCs.
    els3286 likes this.
  8. Nov 5, 2018 at 2:36 PM
    #48
    els3286
    els3286 Member
    Thanks for the heads up!
  9. Nov 5, 2018 at 2:41 PM
    #49
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    No problem. :cheers:
  10. Nov 13, 2018 at 4:52 PM
    #50
    msifuentes84
    msifuentes84 New Member
    2016 Tacoma TRD 4x4 Double Cab Long Bed
    I have a 2016 Tacoma and was having the same issue with the dash “- - -“ not picking up the tire PSI. I was advised by a Toyota Specialist to bring my tire PSI down under 30PSI then try resetting again and take it for a drive for about 5min. Well within 2min. all the monitors started picking back up on the tires PSI again. Hopefully this will help anyone else who has been having this issue.
    vuTron, Old97 and tonered like this.
  11. Nov 30, 2018 at 7:20 AM
    #51
    els3286
    els3286 Member
    Sorry for the slow response. I went in about a month ago, they said they had to open a tech case. I waited patiently, and got busy with the holiday and stuff, realized it had been a month since I went in, so I called to check on the status... not only was the ticket closed, but my service rep no longer works at the dealership. They've had my truck now for going on 3 days with no results; they did pay for a rental, that just means I'm driving a very disappointing Nissan Frontier. It's pretty ridiculous that certified Toyota mechanics at the Toyota dealership can't fix the issue. I've just about run out of patience with the dealership... maybe if I make enough fuss I can get some free stuff out of this, lol.
    tonered likes this.
  12. Nov 30, 2018 at 8:53 AM
    #52
    Blacklodge
    Blacklodge Well-Known Member
    Houston, TX
    2017 TRD Offroad
    2888 - Old Man Emu Coil Springs 90021 - Front Old Man Emu Nitrocharger Sport Struts (5mm Trim Spacer x2) 60091 - Rear Old Man Emu Nitrocharger Sport Shocks EL095R - Rear Old Man Emu Leaf Springs Total Chaos Uniball Upper Control Arms TRD Pro Grill American Racing 16" Wheels Falken Wildpeak A/T3W 285/75/16
    I had this problem, took it to dealer and they told me I had to have my tires taken back off the wheels so they could get the SN off the after market TPMS'. Took it to NTB, same thing. Went to Pep Boys and was in and out in 15 min, cost me $10. Guy over there told me he gets it all the time, something about the reader they use.
    els3286 and tonered like this.
  13. Dec 1, 2018 at 6:51 AM
    #53
    els3286
    els3286 Member
    Finally got my truck back yesterday; still not fixed, but they are "pretty sure" the problem is with the dome light wiring harness. Apparently the the tpms is tied into it... I'm not holding my breath. Gotta go back when the harness comes in, probably some time next week. We shall see. So far dealing with the service dept at the dealership has been a real sh*t show. I called to check on the truck yesterday because I hadn't heard anything the day before and was waiting for a call back. The rental company called wondering when I was bringing the rental back because the dealership called them and said that I had picked up my truck!
    It's been a trying time :annoyed: haha
  14. Jan 17, 2019 at 5:23 PM
    #54
    Shayne
    Shayne Well-Known Member
    Shayne
    South Shore, Mass
    2018 Inferno TRD Sport DC 4x4
    Any updates?
  15. Feb 21, 2019 at 2:35 AM
    #55
    vbb
    vbb Well-Known Member
    2018 MBM TRD Sport DCSB 4x4
    Volk TE37x 16x8 265/70/16 Duratrac TRD exhaust 35% tint
    Bumping this up because I'm having the same thing happen. After putting my new wheels and tires on the truck (with the Toyota TPMS sensors) everything was reading just fine for about 5 miles until I decided to reset the system when I got home. Since the reset, I'm just getting the "---" blanks at all 4 corners. I've followed the reset procedure in the manual to the letter, 3x, and nothing. Now I have the (!) yellow light on in my dash.
  16. Feb 21, 2019 at 5:04 AM
    #56
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    Did you reuse the original sensors from the old wheels?
  17. Feb 21, 2019 at 5:16 AM
    #57
    vbb
    No. Bought brand new TPMS sensors for the 3rd gen Tacoma from Toyota.
  18. Feb 21, 2019 at 6:03 AM
    #58
    RichVT
    Rich
    Northern Vermont
    Did someone program the new sensor ID codes into the truck's ECU (using a tool that connects to the OBDII port under the dash)?
    vbb likes this.
  19. Feb 21, 2019 at 6:11 AM
    #59
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    THIS!!^^^
    G.
  20. Feb 21, 2019 at 8:07 AM
    #60
    vbb
    I ASSUMED so, but didn't specifically ask. So obviously that's my next move now...to ask. Thanks!
    Silly question, but does this require a dismounting and remounting of the tires?
