TPMS sensor question
Discussion in 'Wheels & Tires' started by lIlOtAcO, Jul 18, 2010.
  1. Jul 18, 2010 at 4:06 PM
    lIlOtAcO
    lIlOtAcO [OP] Well-Known Member
    Chad
    Jax, FL.
    2010 S/C PreRunner SR5
    Brand FlippiN New
    Will stock 16" steel wheel TPMS work in 16" trd wheels? about to buy some wheels and just wondering if I can take me TPMS and they will work in the upgraded wheels?
  2. Jul 18, 2010 at 4:08 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    should
  3. Jul 18, 2010 at 7:42 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    The steel wheels sensors have a different angle than the alloys. One is 20 degrees, the other is 40. There are ways around it with a retrofit kit or having the sensor mounted differently inside the rim. There are threads on here somewhere that explain it. But to swap them directly doesn't work.
    Here is a thread that has the strap kit a few posts down.
    http://www.tacomaworld.com/forum/wheels-tires/92714-tpms.html
  4. Jul 18, 2010 at 7:44 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    18 PreRunner TRD OffRoad DCSB
    follow up, can you mount all 5 in the spare? Also, do they not work in after-market wheels, or just the TRD wheels?
  5. Jul 18, 2010 at 10:36 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    Stock for now
    Some do the pipe bomb or wheelbarrow tire trick, don't know if anyone has put them all in their spare. :notsure:
    Others get their installers to turn them 180 degrees when mounting the new tires on the rims
    There has been a slew of tricks, mods, pull the bulb, use tape, ground the wire behind the HVAC controls.
  6. Jul 20, 2010 at 6:41 AM
    kramer2k
    kramer2k Well-Known Member
    Jacksonville, FL
    08 DC PreRunner TRD OR
    I posted the above in the Tire & Wheel subforum, but in an attempt to get more eyes on the question, I'm double posting it in here.
    He did disconnect the battery yesterday for a while to clear the ECU, to no avail. I'm stumped because the sensors on my truck that were originally on his work fine on my truck. I'm getting no alert. I thought that it may have been due to mixing the sensors between trucks (i.e. My spare matches the four now on his truck. And vice-versa, his spare tire sensor matches the four on my truck right now.).
    This is throwing me for a loop b/c there was no TPMS warning light on my truck with the setup that is currently on his truck. I'm stumped. I'd prefer to not do any wire cutting or taping over the light on his truck. If it were mine, I'd have no problem.
  7. Jul 22, 2010 at 10:34 PM
    BobbyG99
    BobbyG99 Member
    Bobby
    Lakewood, CA
    07 Tacoma
    Quick question since it may be related to this thread. I had the my OEM Steel will repalced with the 17" Aluminum TRD Sport rim. I want to use my old TPMS but they obviously don't fit. I plan on purchasing the TPMS strap kit but does anyone know which one I would need? The website below is from another post.
    http://www.revolutionsupply.com/strapkit.aspx
