TPMS system and new wheels...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BlkTaco47, Nov 1, 2015.
  1. Nov 2, 2015 at 3:50 PM
    BlkTaco47
    BlkTaco47 [OP] Unhinged
    2018 TRD PRO Midnight Black Metallic
  2. Nov 2, 2015 at 9:42 PM
    mulishan909
    mulishan909 Well-Known Member
    Mulishan909
    2017 Tacoma TRD Sport
    Was it easy as 1-2-3 to swap over the TPMS to the new wheels?
  3. Nov 2, 2015 at 11:15 PM
    knhorn
    knhorn Well-Known Member
    San Diego
    2016 TRD Sport DCSB Quicksand
    Icon Stage 5 set at 3", Toyo ATII, Fuel Throttle
    Yes. I'm not quite sure why this is still being discussed. Swap your OEM TPMS to your new wheels and everything will be fine!
  4. Nov 3, 2015 at 1:58 AM
    BlkTaco47
    It's still being discussed because not all rims accept the tpms modules so no, you
    won't be fine if you just swap them into any wheel.
    Herniator and mulishan909 like this.
  5. Nov 3, 2015 at 4:51 AM
    NoDak
    NoDak Well-Known Member
    JR
    Minot, ND
    16 Tacoma TRD Sport 4x4 Blazing Blue
  6. Nov 3, 2015 at 9:38 PM
    knhorn
    San Diego
    There must be a small minority of wheel manufacturers that don't accept the OEM TPMS. Almost everyone on here who has installed aftermarket wheels didn't have to use an aftermarket TPMS.
  7. Nov 4, 2015 at 3:08 AM
    BlkTaco47
    good to know. I've seen a few that said it's not working or I'll put tape over the blinking light.
  8. Nov 11, 2015 at 8:43 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Even OEM wheels can have problems with OEM TPMS.
  9. Nov 11, 2015 at 9:08 AM
    AZInferno
    AZInferno Well-Known Member
    2016 TRD Sport Inferno
    Couldn't agree more, what did we all do before TPMS was forced into our lives? Does any vehicle come with an electronic dipstick yet, I am tired of checking that thing manually. Next thing you know we will have self driving cars.
  10. Nov 11, 2015 at 9:37 AM
    ScTuna
    ScTuna Well-Known Member
    Texas
    2016 Tacoma
    Can't check your pressure while driving at 65 mph
  11. Nov 11, 2015 at 11:57 AM
    Gerrrr
    Gerrrr Well-Known Member
    Jeremy
    Ottawa, Canada
    2017 Blazing Blue Metallic (Limited 2013 Silver Streak DC Auto - Retired)
    Starting over.......
    I had hoped Toyota would move to a TPMS system that would hold two sets of sensors in the configuration or auto learn to ease the winter summer swap like many other manufacturers offer.
    The "clone" sensors are still a bit of a black art to many tire shops. It looks like the pressurized ABS tube is still a good option, at least my spare is monitored and I can check the others with a gauge.
  12. Nov 11, 2015 at 12:27 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    What happens when you rotate yer tires... now the sensors are on a different wheel but the ECU still thinks they are where they were from the factory?... If ya get a low reading on the RR, then it's likely the RF...Right..????
  13. Nov 11, 2015 at 12:43 PM
    OnceARunner
    OnceARunner War Eagle!
    Georgia
    2016 DCSB TRD Sport Tacoma
    Georgia requires emissions testing in metro-Atlanta counties and they do not fail you for a TPMS light. They are looking at emissions results only. Not sure about states like North Carolina that also do a "safety inspection" in addition to emissions.
  14. Nov 11, 2015 at 12:45 PM
    BlkTaco47
    Very true, I had clones from a vendor here that just would not sync up on my 2011.
  15. Nov 11, 2015 at 1:15 PM
    #35
    ScTuna
    Texas
    2016 Tacoma
    It's reading psi in tire so it doesn't matter how you rotate your tires or where to on truck. Yes? Someone post pic of this please my sensors are off truck. Thanks. It's easier to understand with pic yes.
  16. Nov 11, 2015 at 1:32 PM
    #36
    over60
    Muskoka, Ontario
    I guess you didn't know that the '16 Tacoma shows a heads up display indicating pressure in each tire... if you rotate the sensors, the ECU will show them in the wring position...
    Corneeeeelius likes this.
  17. Nov 11, 2015 at 1:39 PM
    #37
    Dean724
    Dean724 Well-Known Member
    Upland, CA
    Each sensor has an ID code. When the tire is rotated the ECU recalibrates to recognize the new location with a built in antenna.
    FAQ via Tirerack:
    Do I need to get my sensors re-registered after a simple tire rotation?
    Answer: Some systems that display the tire pressure at each location require a sensor re-learn procedure to be done after the tires have been moved to a different corner of the vehicle. But others use antennas in the vehicle’s wheel well to “see” where the old wheel moved.
    If the sensor with the ID code of 1234567 was at the left-rear location, but now the left-front TPMS antenna is reading that 1234567 ID code, then the system will update its TPMS display to correctly show the wheels and the tire pressures at their new locations. The most common system only displays a “Low Pressure” light on the dash and those systems normally don’t need to be reset when a tire rotation has been done. You may want to consult the 2007 Mitchell1 TPMS Guide for a specific answer concerning a TPMS-equipped vehicle.
  18. Nov 11, 2015 at 2:15 PM
    #38
    ScTuna
    Texas
    2016 Tacoma
    You mean this ee92f9cc4601808c45657b5c20014765_f52b2df1db1f2f21f99904b923be8dabfb38ae3f.jpgjust had a hard time explaining it to the last guy.
  19. Nov 11, 2015 at 6:20 PM
    #39
    over60
    Muskoka, Ontario
    HUH..?? What U say'in..?
    I figured you did not know cuz your data shows you as a 2011 Tundra man..!!
  20. Nov 11, 2015 at 6:24 PM
    #40
    over60
    Muskoka, Ontario
    Oh, well it's all to no avail anyway.... I just put on my winter Michelins (no sensors) and the tires with the sensor thingies go into the garage..... I've got to get out the Black electric tape and cover the stupid light.... Geese... I wish there was a way to deep 6 this stupid system...!! I've used a tire gauge for 50 yrs. and never had a problem... I'm not about to now either...TPMS or not..
