transmission flush 2015 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Eddy650, Feb 20, 2019.
  1. Feb 20, 2019 at 10:23 AM
    Eddy650
    Eddy650 [OP] Active Member
    2015 tacoma trd off road
    Hello, I have a 2015 Toyota Tacoma TRD PRO 4x4, automatic with about 78,000 miles on it.
    My question is when would you recommend doing the Transmission flush, differential oil, and transfer case fluid exchange?
    The only thing I haul is my atv when I do some here and there off-roading. The only thing I've replaced is the motor oil change/ filter and new brake pads with rotors. any suggestions ....thank you in advance .
  2. Feb 20, 2019 at 10:27 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Do the differential and transfer case.
    Transmission, can do a pan drop and refill as well.
    Diff and transfer are somewhat easy.
    Eddy650[OP] and BassAckwards like this.
  3. Feb 20, 2019 at 10:32 AM
    UBYBC
    UBYBC Well-Known Member
    2014 Tacoma TRD OR
    Ive read not to touch the transmission many times on TW, and to consider the full flush at around 100K. Seems to be lots of uncertainty around the transmission service interval.
    I change both diffs, transfer case and grease zerks (4x4) every 15K-20K.
  4. Feb 20, 2019 at 10:38 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
  5. Feb 20, 2019 at 10:47 AM
    Eddy650
    Thank you, I will do this soon, looked at vids and it does look easy.
  6. Feb 20, 2019 at 10:48 AM
    Eddy650
    Okay will be waiting to do around 100k, will do the rest soon
  7. Feb 20, 2019 at 1:26 PM
    mikalcarbine
    mikalcarbine Well-Known Member
    Phoenix, AZ
    2015 AC TRD OR
    Full flush the transmission and then start doing pan drains at regular intervals
    Eddy650[OP] likes this.
  8. Feb 20, 2019 at 2:22 PM
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
