truck box
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kiddwvman, Apr 14, 2010.
  1. Apr 14, 2010 at 5:01 PM
    kiddwvman
    kiddwvman [OP] Well-Known Member
    leon
    WV
    06 4 banger
    weathertec floor liner,tinted windows,bilstein 5100 front .85,5100'S rear,window vents,K@N air filter
    what kind of truck box,places to get a truck box,any buddy have pics of their truck boxs , thanks
  2. Apr 14, 2010 at 5:16 PM
    kiddwvman
    leon
    WV
    06 4 banger
  3. Apr 14, 2010 at 6:15 PM
    Logically Insane
    Logically Insane Well-Known Member
    Wes
    TN --- USA
    2010 PreRunner Access Cab
    Kobalt toolbox mounted with J-Hooks, Locks on storage compartments in bed, Window Visors, Toolbox LED Lights, Underbody Lights, More to come.
    Like toolboxes?
    I got a Kobalt low profile from Lowe's for $250ish+ tax
  4. Apr 14, 2010 at 8:07 PM
    philobeddoe
    philobeddoe ΜΟΛΩΝ ΛΑΒΕ
    - philo
    Nashville, TN
    2010 Gray Tacoma TRD
    Tom Woods Custom Driveshaft
    i was in home depot, and they told me they don't carry 'em no more
    don't know if it was just that location
    checked out Pep Boys ... didn't like 'em
    i like the look of that Lowe's Kobalt
    think i'm gonna check out Costco
  5. Apr 15, 2010 at 5:14 PM
    kiddwvman
    leon
    WV
    06 4 banger
    thanks,i looked at northern tool,autoparts warehouse,and racepages i just don't know,i am wanting to go with black,i like the look of the low pro :)
  6. Apr 15, 2010 at 5:21 PM
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
  7. Apr 15, 2010 at 5:23 PM
    kiddwvman
    leon
    WV
    06 4 banger
    do u know where he got it ???? thanks
  8. Apr 15, 2010 at 5:32 PM
    MY50cal
    Mojo
    Camden County, NC
    Yep.
    I can't remember... shoot him a PM and ask him.
    I ordered mine from a local Truck Supplies store.
  9. Apr 15, 2010 at 5:50 PM
    kiddwvman
    leon
    WV
    06 4 banger
  10. Apr 15, 2010 at 6:13 PM
    kiddwvman
    leon
    WV
    06 4 banger
    i got one on the way :D thanks NY50cal
  11. Apr 15, 2010 at 6:16 PM
    MY50cal
    Mojo
    Camden County, NC
    Yep.
    no problem :cheers:
  12. Apr 25, 2010 at 8:30 PM
    Rufus
    Rufus Well-Known Member
    SoCal
    2010 TRD PreRunner Sport
    OEM Truck Bed Extender, Window Tint, Tailgate Security Mod, OEM Spare Tire Lock, Cam Locks (storage compartments), OEM Bed Mat, OEM Skid Plate, Stant 11504 Locking Gas Cap, TW Edrin55 OEM Running Boards, Pop & Lock w/Back-Up Cam, Black WeatherTechs, Red Line Quick Lift Plus Hood Struts, Wet Okole Front Seat Covers-black/charcoal with red & white TRD graphic & back seat pockets, DIY Satoshi Grillcraft & Old School Toyota Badge, TW ZonKs Black UWS Low Pro Truck Box, Rear Suspension TSB, 3M Scotch Guard Paint & Headlight Protection Film 8mm Urethane, Flyzeye V2 Wired Amber/White/Amber Interior LED Lights w/Silver Case, Sleek Looking Black LED Tail Lights from K2 Motors (Identical to OEM, but black).
    How did you install your truck box? Did you use J-hooks fastened to the rail? Are the rails sturdy enough to secure the box? I like the black poly foam Delta box. I like it cuz the edges are rounded & it is low profile. But it only comes in full size & compact size. I'm not sure if the compact size is the right fit-may be too small. Anyone know if this box will work on our Taco's? :notsure:
  13. Apr 25, 2010 at 8:59 PM
    Rufus
    SoCal
    pm sent.
  14. Apr 25, 2010 at 9:07 PM
    MY50cal
    Mojo
    Camden County, NC
    Yep.
    Hey Rufus... Send PatHLC128 a pm. I was just whoring his truck out for him. I dont have the box yet.
  15. Apr 25, 2010 at 9:15 PM
    Rufus
    SoCal
    Ok. Thanks Mojo. :cool:
  16. Apr 25, 2010 at 10:02 PM
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Just picked up one from Lowes also.$165 for the low profile narrow width one .Only 12inches wide .Got the short bed so went with narrow one.Mounted with the D ring that slides in the rail.Just cut off the end part and bolted box down with 3inch stainless bolt.2 holes on D ring lines up perfectly with holes in box.
  17. Apr 26, 2010 at 7:30 PM
    Rufus
    SoCal
    Can you post pics? I don't know what D-rings that slide into rail are. What end part did you cut off? Thanx!!!!!! :confused:
  18. Apr 26, 2010 at 10:32 PM
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    I guess you could call it cargo tie downs.The one that slide in side rails.Cut off tape portion so you can slide it under the 2 holes in box each side)Holes in the tie down line up perfectly.When lined up tighten tie down and bolt up.I used 3inch bolts with some flat washer as spacer.Also used stainless so no worries latter.Pics hope it helps.Will be making spacers this weekend to put between box and cargo hold down to make it more solid.
  19. Apr 26, 2010 at 10:53 PM
    nuckinfuts
    nuckinfuts NyQuil on the rocks.
    Pacific NW
    '06 AC TRD Off-Road
    DT Long Tube Headers, Empire O2 simulator, catback, Shrockworks Sliders, Old Man Emu 3" lift with 885 coils (with 1/2" top plate spacer and Dakar Leaf packs), Hi-lift mounted in bed with 4XRAC mounts, WT floor liners, other stuffs
    Those black low-profile UWS boxes look badass. I looked into one a while back and found a place called "Rack n Road" that sells them. http://www.racknroad.com/ They wanted I think $300 for it (it was $299 or $399, can't remember). It's on the neverending list of cool shit to buy for the truck. Looks like they're mostly west of the rockies, but you can use the store locator on UWS's website to check around you. Or just call them.
    http://www.uwsta.com/
  20. Apr 26, 2010 at 10:58 PM
    Kyle
    Kyle Mckeown343
    Arcata
    05 PreRunner
    3 inch toytec, magnaflow exhaust, KNN intake, URD MAF, HID 55 watt, Hella 500 HID, Smoked tail lights LED running lights, Pioneer deck with 8 inch infinity sub, Focal 165VB and 165CVX with JL 320/4, Tinted all around 3%, Tinted interior lights.
    UWS Low Pro Deep. I love mine the best out there in my opinion. I have seen some with really bad welds and well UWS is a welding company so.....
