TSB List for 2005+ Toyota Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Angus_NB, Mar 25, 2008.
  1. Jan 29, 2014 at 9:00 AM
    #881
    SwimNdrive
    SwimNdrive Member
    CA
    07 SR5
    T-SB-0066-11 is about the clutch based on what I have read. However, I could not find the Toyota official information on this.
  2. Feb 8, 2014 at 9:53 PM
    #882
    duppers1957
    duppers1957 Active Member
    steven
    ukiah,california
    2006 preruner sr5
    throttle body spacer ,jba headers with flomaster.17"tires Volant cold air induction
    I have a2006 Tacoma double cab and recently replaced the propeller shaft and still have an intermediate problem with the "bump-from-behind" sensation which has me wondering what to do next.:)
    thanks for your help,
    the duppers
  3. Feb 9, 2014 at 4:52 AM
    #883
    OneMentalCase
    OneMentalCase Well-Known Member
    South Florida
    10 Pyrite LB
  4. Feb 10, 2014 at 6:00 AM
    #884
    Rolf
    Rolf Well-Known Member
    Rolf
    Philly
    09 taco sport crew 4 x4 long bed
    Deaver 6 stack Leaf Springs 3/4 ton Bilstean adjustible shocks 3.0 Liter turbo diesel from Toyota Hilux in japan
    My 2009 TRD sport used in Harrisburg pa area lots of road salt only has surface rust in certain areas I wire wheel cleaned and treated with permatex rust treatment , just had the engine swapped the shop did a full POR-15 prep and coat on frame will update how long it holds up
  5. Feb 10, 2014 at 6:04 AM
    #885
    Rolf
    Rolf
    Philly
    Also I forgot to mention I paid $800 fir a custom set of Deaver 6 leaf spring pack rated at 1 ton springs Are progressive so ride is stiffer but tolerable, the springs lifted rear end 2.5 Inches had to install Bilstean 5100 adjustable front shocks to level out truck now it has 2.5 lift but no more sag issues with 1,500 pounds on back still not at bumpers
  6. Feb 10, 2014 at 9:20 AM
    #886
    WillRunner05
    WillRunner05 Well-Known Member
    WIll
    Houston, TX
    TRD Off Road
    ICON Suspension, LR UCA's
    I got approved for the TSB. I have an ICON Stage 2 Lift sitting in the garage. I wonder if I can still use the AAL on the new 4 leaf pack Toyota will be installing on my truck??? :confused:
  7. Feb 10, 2014 at 9:29 AM
    #887
    duppers1957
    steven
    ukiah,california
    2006 preruner sr5
    thanks for your help I'll go down to my shop see what happens, however if anyone finds any kind of solution I would appreciate any input as I don't like that feeling . I'm one of those o.c.d. people and have a hard time living with things like this otherwise have a great day.:D
    thanks duppers 57
  8. Feb 10, 2014 at 10:09 AM
    #888
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
  9. Feb 11, 2014 at 4:03 PM
    #889
    ramirezsergio63
    ramirezsergio63 Well-Known Member
    Sergio
    Mecca california
    2012 Tacoma Prerunner SR5 2.7
  10. Feb 12, 2014 at 5:16 AM
    #890
    The_Hodge
    SC
  11. Mar 5, 2014 at 8:13 AM
    #891
    tony2018
    tony2018 Well-Known Member
    How much does the dealer charge to reflash the ecu? Whats the estimate you guys were charge, if out of warranty? I'm just trying get a ballpark before scheduling this in
  12. Mar 10, 2014 at 12:52 AM
    #892
    Ragamorph
    Ragamorph Well-Known Member
    Austin
    Honolulu, HI
    ‘06 TRD Off-road 4x4, Manual, Access Cab
    Fab Fours pre-runner front/rear bumper, Anzo projector Head/tail/3rd brake lights. JL door speakers, JL amp, JL StealthBox (center console), Double din aftermarket deck. Weather tech floor mats, SOS Concept Sliders, 3” lift, steel skid plate, Fuel 20x10 wheels, 285 tires, low profile steel bed rail and tailgate caps, K/N high flow intake, Warn winch, and so much more.
    I didn't read all 900 posts here so sorry if this was asked and answered.
    I have an 06 TRD and have had issues with it bottoming out empty after going over bumps. The TSB for the rear springs was put out in 2010 so it was already well past the 36 mo (and I was past 36k). Do you think there's a chance Toyota will fix it?
    Toyota here in Hawaii is a joke (you have to make an oil change appointment a month in advance to get in and emergency maintenance has to wait at least a week before they can get you in). I just don't want to go there and spend hours of my time to be told to bug off. Thanks!
  13. Mar 10, 2014 at 5:11 AM
    #893
    The_Hodge
    SC
    if they do, i'd be amazed. if you had many documented issues before a TSB came out and you went in again right after the warranty ended, then maybe. this late you are just better off getting an aftermarket pack or buying someone else's stock pack after they've upgraded.
  14. Mar 15, 2014 at 5:53 AM
    #894
    MattinMA
    MattinMA Active Member
    Boston
    2013 TRD Sport
    Just read this in the automotive section of the ny times - "TOYOTA A vibration in the seat and floor may be felt by some Tacoma pickup owners. In T.S.B. SB0008-14 issued on Feb. 3, Toyota said some 2005-14 vehicles with automatic transmissions could develop the problem, most noticeable at 15 to 25 m.p.h. Replacing the engine mounts and leaf springs, and installing a steering damper, should solve the problem"
    Might be old news?
  15. Mar 24, 2014 at 11:41 AM
    #895
    5280Transplant
    5280Transplant Well-Known Member
    Luke
    NoVA by way of CO
    05 TRD Sport SR5 Rad Red
    Sorry to ask another TSb question. I was looking at my rear spring pack and I only have 3 leafs in the springs. I have an 05 and they have sagged quite a bit. I thought about an AAL, but remembered there is a TSB about it.
    I looked on the Toyota service website and talked with a local dealership and neither show an outstanding TSB for my AAL. Do I not qualify for the TSB?
    Thanks...
  16. Mar 25, 2014 at 4:59 AM
    #896
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    3years/36k miles for that and most TSBs. You are unfortunately way past that.
  17. Apr 6, 2014 at 9:30 PM
    #897
    14TACO4X4
    14TACO4X4 Mmmmm... Beer
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    I've read through a lot of this thread, but didn't find an answer to this question:
    Were the suspension issues resolved for the 2014's or can I expect my ass end to drop like a stone if I try to tow something or load my bed?
  18. Apr 7, 2014 at 5:40 AM
    #898
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Your Sport should already have the 4-leaf pack unless they changed things up again. I think the Sport and SR5 now come with the 4-leaf pack from the factory. It should hold up fine to the occasional 800 lb load or reasonable trailer load.
    Supposedly they redesigned the Off Road 3-leaf pack, but I have yet to see a part number comparison that proves it is different from the previous pack. I do think my '12 sags less under load than my '09 did. I put Firestone Ride Rites on and tested it with a load of mulch this weekend. It dropped about an inch with about 800 lbs in it. 25 psi in the bags leveled her off again.
  19. Apr 8, 2014 at 7:55 AM
    #899
    danysurf77
    danysurf77 Member
    daniel
    anaheim, ca
    05 prerunner 6 speed
    did the 2005 uca fit 2012 model
  20. Apr 9, 2014 at 10:27 AM
    #900
    Bu11etWhisperer
    Bu11etWhisperer My Taco is Blue!!!
    Mark
    Douglasville, GA
    2010 Prerunner, SR5, TRD Sport, Speedway Blue
    It's a shame that they come out with the TSB after I hit the 60,000 mile mark. Deal with the problem for the life of my tacoma, NOW I'm stuck with it!:mad::confused:
