Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Apr 16, 2017 at 8:26 AM
    #461
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Well transmission finally let go.
    First gear weird clicking sounds
    2nd doesn't work
    3rd clicks bit smoother
    4th slight click smooth
    5th barely used it but felt ok
    Reverse not pretty sounding
    Best part made it home 130 miles without a tow.
    Wish I had video. The section of dirt I was hitting was sweet. Bouncing off the rev limiter and skipping over some pretty big stuff for the truck.
    Jstand, MrCrowntown and Brice like this.
  2. Apr 16, 2017 at 10:27 AM
    #462
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I am missing out on all of the fun in here.....
    New used transmission in your future?
    Drill out or replace that restricted feed.
  3. Apr 16, 2017 at 2:20 PM
    #463
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    If you have the ability or availability to do some machine work with a lathe you can use a 5vz 5spd tranny
    MadTaco461 likes this.
  4. Apr 16, 2017 at 2:37 PM
    #464
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Which transmissions does LCE build?
  5. Apr 16, 2017 at 2:46 PM
    #465
    MadTaco461
    CA
    Kinda stock
    Think I'm going to jump to a r155 transmission. The bell housing is the same pattern as mine. Think all I need is a 3rz flywheel and clutch. Might need to shorten my driveshaft. Used those transmissions are pretty affordable. Think 500-600 out of a junkyard. Prefer to stay away from a 4x trans since I don't plan to 4x convert.
    MrCrowntown likes this.
  6. Apr 16, 2017 at 2:47 PM
    #466
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Anyone got a picture of the fpr mod on the stock fpr on the 1gr askin for a friend...
  7. Apr 16, 2017 at 2:52 PM
    #467
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Quite possibly but nothing's set in stone until I start spending money.
    MadTaco461, Torspd[QUOTED] and Brice like this.
  8. Apr 16, 2017 at 3:16 PM
    #468
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Lies
  9. Apr 16, 2017 at 3:26 PM
    #469
    yota243
    E.J.
    north Alabama
    Ok.... I dont have any friends... So u got a pic or not?
  10. Apr 16, 2017 at 3:43 PM
    #470
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  11. Apr 16, 2017 at 3:45 PM
    #471
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Close in that thread. I have a a vacuum block, which I use to supply a vacuum/boost source for the FPR.
    Without that, you need to add multiple Tee or Y taps.
  12. Apr 16, 2017 at 4:02 PM
    #472
    yota243
    E.J.
    north Alabama
    Ok so i can just t into the boost line goin to may wastegate and hook that little line (1\8"?) to it
  13. Apr 16, 2017 at 4:05 PM
    #473
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Ouch. Sounds like TOB or clutch? Weird that all the gears went at once...
    MadTaco461[QUOTED] likes this.
  14. Apr 16, 2017 at 4:07 PM
    #474
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Pretty much.
    yota243[QUOTED] likes this.
  15. Apr 16, 2017 at 6:09 PM
    #475
    MadTaco461
    CA
    Kinda stock
    It didn't sound like throw out. Clutch felt normal and smooth still. When I'd roll you hear a click... Click... Click and speed up with rpm. 2nd just grinds. My buddy out there with me said it sounds like synchro. Either way it sounds bad and should pull it. The truck would jerk too. Maybe input shaft bearing. Ill grab a quick video in the driveway before I pull it.
  16. Apr 16, 2017 at 7:42 PM
    #476
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  17. Apr 17, 2017 at 5:59 AM
    #477
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    @James Co. , just peeked into your thread. Ask away in here.
  18. Apr 17, 2017 at 8:28 AM
    #478
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    you sure the r155 shares the same bolt pattern as the W59?
  19. Apr 17, 2017 at 8:37 AM
    #479
    MadTaco461
    CA
    Kinda stock
  20. Apr 17, 2017 at 8:42 AM
    #480
    Blackdawg
    Monte
    Wyoming/St. Louis
