Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Nov 6, 2018 at 10:13 AM
    #9141
    Nomad_Pilot
    Nomad_Pilot I need to pewp
    Clay
    Ft Collins
    My question is, how many psi will the stock computer handle? If I decide to turbo instead of engine swap.
  2. Nov 6, 2018 at 10:13 AM
    #9142
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    If you plum it in after the cat, back pressure shouldn't be a big issue.
    Brake Weight likes this.
  3. Nov 6, 2018 at 10:15 AM
    #9143
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    buyobuyo[QUOTED] likes this.
  4. Nov 6, 2018 at 10:18 AM
    #9144
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    I believe the ecu can be tuned now with ovtune
  5. Nov 6, 2018 at 10:21 AM
    #9145
    Nomad_Pilot
    Clay
    Ft Collins
    Even the 2nd Gens?
  6. Nov 6, 2018 at 10:27 AM
    #9146
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    The 2TR is getting shit on by them. It's up to the individual to make all motor (best we can) or turbo boost and R&D on our own. Read as: they're only giving attention to the V6s and said there isn't enough interest for 4 banger, when there definitely is.
    Torspd likes this.
  7. Nov 6, 2018 at 10:29 AM
    #9147
    Nomad_Pilot
    Clay
    Ft Collins
    Hmm. I wanna turbo it, but I want to keep the reliability of the electronic, and plus I have no idea how to tune
    dirty deeds likes this.
  8. Nov 6, 2018 at 10:30 AM
    #9148
    dirty deeds
    Nick
    Eastern KY
    I said in here that I plan to get the LCE header, and I will soon enough. 100% certain.
    Would upgrading to the Walbro 255 be a good idea as well too? Or similar fuel pump upgrade kit? Suggestions and ideas welcome.
    Trust, I'd rather boost mine and run a reliable 7psi on everything as stock as I can stay to be budget-friendly (cheap AF!), because I'd be willing to buy a nice turbo and accessories to make up for keeping stock internals and ECU.
    EDIT: I also off road several times a year, so that's a concern of mine, too. Want something useful on the low end, and strong enough to handle the abuse and mud.
  9. Nov 6, 2018 at 11:58 AM
    #9149
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Once a few of these members with a 2TR get theirs running on a Haltech, they could possibly throw you a base map. You'd need one as well though.
  10. Nov 6, 2018 at 12:02 PM
    #9150
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It doesn't understand PSI. Only Mass Air Flow, in grams per second. MAF sensor based.
    The Map-ECU3 can kind of help, but your ecu is reluctant to relinquish control of closed loop. Cheaper and easier than the Haltech though. Just has less capability.
    boostedka likes this.
  11. Nov 6, 2018 at 12:47 PM
    #9151
    Nomad_Pilot
    Clay
    Ft Collins
    Doesn't it say MAP when hooked too the scan Guage 2? I could have sworn it did. I also heard rumors the stock electronics could handle 7 psi. Is that true or is that bullshit?
  12. Nov 6, 2018 at 12:52 PM
    #9152
    dirty deeds
    Nick
    Eastern KY
    Heard the same :playball:
  13. Nov 6, 2018 at 1:18 PM
    #9153
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Mine does too on torque pro, but that is just a calculated value to make you think you have a map sensor.
    Torspd and boostedka like this.
  14. Nov 6, 2018 at 4:43 PM
    #9154
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It has a MAF sensor. 100%.
    My friend is running 11psi URD S/C', with a MAP-ECU3 , and upgraded 5th injector.
  15. Nov 6, 2018 at 4:49 PM
    #9155
    Nomad_Pilot
    Clay
    Ft Collins
    Can someone link me to the whole extra injector idea, cause I don't get it. And also, isn't a super charger awful on fuel mileage?
  16. Nov 6, 2018 at 7:07 PM
    #9156
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    It's all awful on gas mileage if you squeeze the Go button hard enough
    dirty deeds, Torspd and MadTaco461 like this.
  17. Nov 7, 2018 at 5:27 AM
    #9157
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    His 2TR does quite well. He's getting around 400 miles on a tank. In tuning and driving style.
    URD may have a 5th injector kit on their website. www.urdusa.com
  18. Nov 7, 2018 at 5:36 AM
    #9158
    dirty deeds
    Nick
    Eastern KY
    So again...
    Is upgrading the fuel pump worth while having only all-motor upgrades? With plans to turbo at a later date?
    If so, which one?
  19. Nov 7, 2018 at 5:42 AM
    #9159
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    not really. id only do it if you need one.
    dirty deeds[QUOTED] likes this.
  20. Nov 7, 2018 at 6:04 AM
    #9160
    Jcyr
    Jack
    North east
    You’ll need it for turbo but unless you’re doing legit head and valve work on your motor no intake/exhaust upgrades would warrant a bigger fuel pump.
