Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Nov 8, 2019 at 11:38 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I bet my T100 could fit 6. Tons of room for activities under the hood.
  2. Nov 8, 2019 at 11:48 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Challenge given!
  3. Nov 8, 2019 at 12:03 PM
    Reh5108
    Idaho
    Does ample amount of money come with the challenge?
    If I still have the truck and have the cash someday I'd like to put twins in it. I'm not really sure what it is about that truck but I like it as my daily/work truck. I'm impressed with how much better it handles weight than a first gen taco. It just lacks power and the auto trans is only a small step up from a 3rd gens.
    buyobuyo likes this.
  4. Nov 18, 2019 at 11:12 PM
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Anyone have experience with Urd spec u full exhaust system? Trying to fathom spending 1600(with hawaii shipping) on it.
  5. Nov 19, 2019 at 5:53 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Not me, with a 3rd Gen.
  6. Nov 20, 2019 at 12:41 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Who has the 5VZ with the turbo that is routed directly to the TB? I think there was a picture posted in here. I'm thinking about removing my IC.
  7. Nov 21, 2019 at 8:04 AM
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    Just saw the NetFlix with him in it. Crazy story, seems like an awesome guy.
    yota243[QUOTED] likes this.
  8. Nov 21, 2019 at 8:05 AM
    BlackSportD
    Los Angeles
    I need to hunt it down but there is a thread out there somewhere where I saw a guy with a 5vz turbo setup where the IC was mounted up high in teh front vs. the CXracing mounting down low- so low you can't run the skid plate or an aftermarket bumper. Is that why you are going IC'less, its in the way?
    * Ninja edit, here is the thread
    https://www.tacomaworld.com/threads/if-i-keep-it-ill-have-to-upgrade-turbo.618938/#post-21078281
    He fixed what is my big apprehension of installing the CX kit, the low mounted IC.
    05Taco4x4 likes this.
  9. Nov 21, 2019 at 11:10 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    To run an IC in the grill, I would have to re-route the AC hard lines. Where its currently mounted, its obstructed by the bumper and next to useless. The extra charge pipes aren't worth it IMO.
  10. Nov 21, 2019 at 11:25 AM
    Reh5108
    Idaho
    Have you considered an air to water setup? It's extra weight and a little more complex but water is more efficient at pulling away heat than air. Usually less charge pipe too.
  11. Nov 21, 2019 at 11:51 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I have.
    I'm not sold any which way, I'm just curious how the Turbo was routed to the intake. Its not too difficult; may a 60* from the intake and a 100* bend from the turbo, but the turbo outlet is 2.5" and the TB is closer to 2.75". I'm not sure how three off the shelf pieces can make that direct connection or how well the MAF handles that short stroke of air.
    Reh5108[QUOTED] likes this.
  12. Nov 21, 2019 at 1:08 PM
    BlackSportD
    Los Angeles
    I cringe at non-intercooled. One thing I hate about my TRD S/C (5vz) and having a pingy motor. Granted Turbos are more efficient, it doesn't matter, compression air will get hot, period.
  13. Nov 21, 2019 at 1:12 PM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    Isn't water to air for racecars. Ice bags and such? I imagine in a daily the water box would heat up pretty quick. But I may be wrong.
  14. Nov 21, 2019 at 1:16 PM
    BlackSportD
    Los Angeles
    Lots of street setups with water/air- 2nd gen TRD setups, various S2000 S/C setups, I'm sure lots of other examples.
  15. Nov 21, 2019 at 1:18 PM
    Reh5108
    Idaho
    Another radiator is installed. As long as air is moving past it things should remain close to ambient temperature. I think the old celicas used them.
  16. Nov 21, 2019 at 1:18 PM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    Got ya thanks
  17. Nov 21, 2019 at 1:56 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I've never seen anything to suggest the 5VZ is a "pingy" motor. The 5VZ has a reputation for "4th gear knock" because the TRD S/C had terrible volumetric efficiency.
    Given that I'm not going to run boost over 6-8 PSI and I'm able to monitor air intake temperatures (unlike the TRD blower which charged/heated the air post MAF -> i big issue as the ECU was measuring ambient intake temperatures and setting appropriate timings), I'm reasonably certain that risk is slim to none.
  18. Nov 21, 2019 at 2:08 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    You spraying too right?
  19. Nov 21, 2019 at 2:25 PM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    Yeah, you'll be fine with no IC at those levels. Not like you're at those levels for a few seconds at a time anyway.
  20. Nov 21, 2019 at 3:48 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Me? No.
