Turbo or supercharger
Discussion in '1st Gen. Tacomas (1995-2004)' started by sosadrex, Apr 28, 2025.
  1. Apr 28, 2025 at 1:25 PM
    sosadrex
    sosadrex [OP] New Member
    2002 tacoma
    New to forums but been reading them and trying to decide if i want to turbo or supercharge my 02 tacoma 3.4 but not sure where to begin on either or so want some help and will answer all questions or concerns as best as i can just looking for guidance and some advice
  2. Apr 28, 2025 at 2:52 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Low boost with methanol injection (~6-8psi): Supercharger (+50-100HP) mostly bolt on with supporting mods
    Medium boost with Intercooler (up to 16psi): Turbocharger (+100-250HP) but a lot more work and you'll want a full aftermarket ECU like the Haltech 2500
    Both end up costing similar, but turbo will be more labor and tuning
    High boost with intercooler (16psi+): turbocharger & complete rebuild of engine required and manual transmission recommended.
    Places to start:
    https://www.tacomaworld.com/threads/turbo-bs-thread.481844/
    https://www.tacomaworld.com/threads/3-4l-supercharger.629337/
    https://www.tacomaworld.com/threads/1st-gen-haltech-ecu-discussion.772300/
  3. Apr 28, 2025 at 3:09 PM
    Nano909
    Nano909 Stirrer Of Pots
    Xcab 3.4 4wd 5MT
    Assuming you do everything correctly and don't cut corners:
    Turbo = cheaper dollar/horsepower ratio, can easily achieve more power than supercharger, better for going fast.
    Supercharger = pretty expensive, not good dollar/horsepower ratio, easy to install, better for rock crawling.
  4. Apr 29, 2025 at 7:17 AM
    1997tacomav6
    Denver
    Supercharger is expensive but can be installed in an afternoon and will run well over 100k without any issues.
    Supercharger you will not hurt the motor with boost,
    turbo there is no plug and play kits available that fit perfectly and are not smog legal
    More power potential but a lot easier to blow up the motor.
    all depends on what you want and how mechanically inclined you are,
    turbo you get more boost and so you probably will need ARP head studs installed for long term, the stock head bolts are like 30 pounds, arp bolts are 80 pounds of torque
  5. Apr 29, 2025 at 7:38 AM
    treyus30
    Trey
    Mesa / AJ, AZ
    This bit is misinformation. Stock head bolts are TTY and are possibly carrying the most torque on my whole truck aside from the front CV axle nuts
  6. Apr 29, 2025 at 7:45 AM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    I'd start with whats the goal? Then I'd go to whats the budget? Then I'd decide who's doing the work? Then I'd go back to the budget. Then I'd start considering which better achieves my goal/budget.
    For me, it'd unfortunately be neither.
    Yossarian and ace_10 like this.
  7. Apr 29, 2025 at 8:51 AM
    02hilux
    Planet: EARTH
    Personally, I wouldn’t start there. The first and foremost question will be, do OP resides in a SMOG emission state. From there, OP can decide which route to go with. Personally, SC is sufficient on our little truck. I owned both SC (C30A, S52, 5VZ) and turbo (1JZ, 2JZ, B18, K24) engines, making power from 4-800hp+ and can say SC require less maintenance vs turbo. They’re tuned on e85 with AEM, Haltech, Hondata management with 8-1200cc injectors.
    Supercharge: simple and easy installation. Add meth injection and most of the issue will be eliminated. Provide decent amount of power between 6-12psi
    Turbo: complicated installation and not a drop and go setup. Requires some elbow grease and knowledge to get going. Provide good amount of power, depending on boost.
    Heck, a buddy had an all motor ITB K motor making 320ish HP and spanking turbo motor making 400HP. Lol
    1997tacomav6 likes this.
  8. Apr 29, 2025 at 9:00 AM
    Off Topic Guy
    We're saying the same thing friend. "Retaining SMOG compliance" would fall under 'whats the goal'. Determine the things that matter most first. Evaluate the budget. Make a decision.
    02hilux[QUOTED] likes this.
  9. Apr 29, 2025 at 9:05 AM
    02hilux
    Planet: EARTH
    Completely missed that part, lol.
    Off Topic Guy[QUOTED] likes this.
  10. Apr 29, 2025 at 9:09 AM
    Off Topic Guy
    Thats okay, I like to argue with people just to argue too sometimes :thumbsup::boink:
    Also, where's the build thread on the turbo 1jz you mentioned? If only I was worthy enough for a soarer/chaser build:bowdown:
  11. Apr 29, 2025 at 9:29 AM
    02hilux
    Planet: EARTH
    No thread for any of my built. 1JZ single turbo, with 2 fuel map (91 & e85) making 520 to the wheel in a classic 70 Toyota.
